Old 08-08-2001, 11:54 AM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default A/F gauge question
I have all Greddy gauges and now need to pickup an A/F fuel guage. The Greddy A/F gauge comes with it's own O2 sensor that is supposed to be able to read over a larger range. My question is do I replace one of the factory O2 with theirs and splice the factory wiring into it? Or should I just have another bung added for their O2 sensor. Also I would think that the O2 should be put either in the place of the second O2 furthest from the turbo or right next to that if I put a new bung in.
Joshua
Subaru Salesman
yebokmj is offline   Reply With Quote
Old 08-08-2001, 12:08 PM   #2
jeffg
Member#: 2958
2001 WRX (GC8)
I would install the O2 sensor in a new bung. If you change out the factory one, there is a chance that you will not have a similar enough O2 sensor to work with the factory ECU. You might hurt the ECU.
Anyway, placement of the AF guage on a turbo car is a bit tricky. Part of me wants to say install it before the turbo, in case the turbo somehow changes the oxygen content, but then I cant figure out how it would do that.
Hmm...
Jeff
jeffg is offline   Reply With Quote
Old 08-08-2001, 02:22 PM   #3
the Dabbler
Member#: 4540
MY00 2.5RS Sedan
Abnormally Aspirated
I would second Jeff's opinion on not replacing the factory O2 sensor. If the Greddy sensor is wide-band, as your post implies, then the ECU will certainly be confused and possibly damaged by it (the OEM rear O2 sensor is 0-1V).
I don't really have a good opinion on the placement of a new bung. Just off the top of my head, I would think before the cat would be better, as the cat is changing the chemical composition of the exhaust gas, but then again, I believe the high-accuracy O2 bench meters typically just sit in the tailpipe (i.e., after the cat). So maybe it doesn't matter.
the Dabbler is offline   Reply With Quote
Old 08-08-2001, 03:21 PM   #4
jeffg
Member#: 2958
2001 WRX (GC8)
I am certain you would want it before the cat, which is why if you cant use the factory o2 sensor. On a turbo car, I think the question is, does a turbo affect AF ratio?
Old 08-08-2001, 03:36 PM   #5
the Dabbler
Member#: 4540
MY00 2.5RS Sedan
As you mentioned earlier, I don't see how the turbo itself could affect the O2 content. But then again, I'm not a mechanical/chemical engineer.
Are you thinking maybe the O2 is combining with something else in the heat, and being left deposited in/on the turbo (and therefore, not being seen as gas past it)? Seems like any scenario like that wouldn't result in drastically different readings anyway, though.
:Shrug: Hey, shouldn't there be a "shrug" smilie?
Most important gauges?? also prosport gauges question! litowrx Newbies & FAQs 15 03-23-2012 05:12 PM
factory boost gauge gauge question philip_g Newbies & FAQs 14 08-20-2008 10:44 AM
Most important gauges?? also prosport gauges question??? litowrx Newbies & FAQs 2 08-11-2007 12:27 PM
defi D-Gauge AFR gauge question Kawikid20o2 Engine Management & Tuning 0 09-22-2005 06:17 PM
EGT Gauge Question....any that look stock gauges? de Rookie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-06-2003 11:05 PM
