Old 07-04-2005, 01:43 AM   #1
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
Default Boost Gauge Swap ..
Long story short, my dad doesn't want the boost gauge in his '05 STi. He said I could have it if it was a simple swap to my '05 STi.
Anyone have a write up or whitepaper on installation/removal of the gauge?
Thanks!
Car vs. Driver is offline   Reply With Quote
Old 07-04-2005, 02:16 AM   #2
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
There is a downloadable installation manual here:
http://www.subaruparts.com/guides/
In a nutshell, you'd have to open the center panel trim to detach the connector that supplies lighting to the gauge, and swap the steering column cover where the gauge is attached to. You will need to swap the hose that goes from the stock bypass valve to the gauge & the t-fitting.
satrya is offline   Reply With Quote
Old 07-04-2005, 09:47 AM   #3
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
Rock ... thanks satrya, seems easy enough
Easiest OEM boost gauge swap? Jackie Interior & Exterior Modification 4 07-06-2009 11:30 AM
Boost Gauge Swap buccilli15 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-20-2006 04:53 PM
stock boost gauge swap? Kydog Interior & Exterior Modification 4 11-07-2005 07:46 PM
Feeler: OEM Boost gauge + swap steering wheel cover Riot Type WRX Mid Atlantic Impreza Club -- MAIC 8 04-28-2005 10:34 AM
