Old 07-04-2005, 03:36 PM   #1
paulw
Member#: 4507
05 STI
Aspen White- No wing
Default Ecutek OL/CL crossover point?
I have a reflashed 05 STI with Green, FMIC and all other supporting mods. I have been experiencing hesitation and loss of power under light throttle from 10mm vacuum up to around zero psi. This is just at the point where the turbo starts to spool. If I go up a hill and hold the car right in this MAP range at around 2800-3000 rpm the car seems to lose power and bucks a bit. Give it more throttle and positive pressure and it runs fine.
I was thinking that it might be right at the transition point from closed to open-loop. Does anyone know what parameters Ecutek uses to make this switch?
paulw is offline   Reply With Quote
Old 07-04-2005, 04:59 PM   #2
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
you migh want to return to your tuner so that they can iron it out for you..
jigga is offline   Reply With Quote
Old 07-04-2005, 05:16 PM   #3
paulw
Member#: 4507
05 STI
I will be going on the dyno in 2 weeks for a re-tune but thought I would ask anyway.
Old 07-04-2005, 09:15 PM   #4
hondaeater69
Member#: 60324
I believe ECUtek can change the crossover point, so it's going to depend on what they have it set at. . .
Old 07-04-2005, 09:42 PM   #5
crazymikie
Member#: 56321
2006 Honda El Camino
Green
There are a whole slew of parameters involved with the CL/OL crossover- TPS, load, rpm and the actual length of the delay values under different circumstances.
You might want to get some datalogs under the conditions where you are experiencing the problem and check them out. You might be able to see something in there. Please let me know if you need a hand.
Mike
crazymikie is offline   Reply With Quote
Old 08-15-2005, 01:55 PM   #6
paulw
Member#: 4507
05 STI
After much diligent logging with Tim B. from PDXTuning, we have figured out that the problem is some anomalous flow characteristics of the Perrin big maf in certain flow regions. At low flow, the maf voltage will briefly plateau or dip instead of ramping up smoothly as the car accelerates. Occasionally, the maf voltage spiked causing the fuel correction to go negative. This "tricks" the ecu into dropping or adding fuel since it looks like the maf flow is decreasing/increasing. This is more pronounced with the A/C on as the second fan's airflow must be causing some turbulance around the air filter which makes the problem worse.
Tim adjusted the maf curve as much as he could and the car runs much smoother now but still has the intermittent "cough". We are going to move the filter to the fender which should help with the fan turbulence issue.
Old 08-16-2005, 11:18 AM   #7
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
The shape of your MAF housing is causing turbulence around the MAF sensor itself. Basically, at certain engine loads and speeds, the air doesn't get pulled in fast enough and circulates around the sensor giving it bad readings.
The curve can be adjusted but it can never be perfect because you're basically going to be reading two different situations as the same(low speed, where the engine isn't pulling much air, so it backs up over the MAF giving you a "double reading", and higher speed where the engine IS pulling the air in and you're getting a correct reading). I believe the only real solution is to fix the hardware problem
mrbell is offline   Reply With Quote
Old 08-17-2005, 08:25 PM   #8
paulw
Member#: 4507
05 STI
Yes, Tim and I decided that the maf is acting exactly as you describe and tuning will only go so far. Do you know of any other "large mafs" that do not have this issue?
Old 08-31-2005, 08:15 PM   #9
byroll01
Member#: 611
'05 E55 AMG
GetADomTune.com
any news paul? you have PM
byroll01 is offline   Reply With Quote
Old 09-01-2005, 04:23 PM   #10
The Donnn
Member#: 33178
SQC 106
Yeah Update ?
The Donnn is offline   Reply With Quote
Old 09-01-2005, 05:19 PM   #11
paulw
Member#: 4507
05 STI
Nothing new to report with my car. Still doing the same old thing.
However, I have noticed a number of other posts on the board with stock STI's having the exact same problem. Someone also mentioned that some of the 05 Legacy's are also having this. Makes me think it might be electrical or ecu related rather than the maf.
Old 11-08-2005, 01:58 PM   #12
RainMaker
Member#: 93301
06 CGM STI SM#17
Now with alot less verve!
I have a very similar issue. Tim has been workign on mine as well. Hopefully we can work out the hardware issue ( the BigMAF) with some help from Jeff P and the PDXTuning folks. It really is the chink in the Green'd STI 's armor.
chris
RainMaker is offline   Reply With Quote
Please help with the OL/CL delay problem accelguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-09-2006 04:26 AM
Light knock around 4k...OL/CL? shemoves Engine Management & Tuning 11 05-03-2006 12:54 PM
STX map and OL/CL nate49509 AccessPort 1 03-04-2006 05:35 PM
prevent ol/cl delay? dypeterc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 09-26-2005 01:37 PM
Question about 04 WRX OL/CL modding issues Gfunk720 Engine Management & Tuning 40 07-17-2005 11:21 PM
