Old 07-04-2005, 06:35 PM   #1
sidewayz
Member#: 5810
2001 S366 2.5RS
Default Dyno results
Not too bad IMO.
Cobb intake
Borla p.o.s. gen4
Apexi cat-back
UR crank pulley.
oh yeah... a ZEX 65 shot
128.9hp (couldnt hit 129 or 130 could ya!) and 148.8 ftlbs
and on the bottle
191.1hp 225.0ftlbs .. holy torque!!!
a/f were a bit scary when the run started..they shot up to about 17.5 then mellowed out during the run after a few hundred rpm and stuck a steady 14.3 . Im pretty happy with the results.
sidewayz is offline   Reply With Quote
Old 07-04-2005, 06:50 PM   #2
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
Did you dyno at englishtown yesterday? If so, I watched both of your runs, pretty sweet. Great looking GC too. What gear did he dyno your car in? It seemed like 2nd, but at 70 and 90 it must have been third.
OppositeLock is offline   Reply With Quote
Old 07-04-2005, 07:16 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
14.3:1 seems a little lean to me. I realize that theoretically 14.7:1 is the best, but from what I've seen on my car and others at a couple Subaru dyno days the cars seemed happiest at 13:1 or so.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 07-04-2005, 09:01 PM   #4
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Some dynos run a little richer than the actual read out. For instance, with a cat converter installed, the dyno I go at reads 1 point higher than what it actually really is. So with a 14.0:1 readout on the dyno plot, you are actually getting a 13.0:1. Without a cat converter, a 14.0:1 is actually a 14.0:1.
I don't know if this is the case where you went but in either case, your car is reading too lean. You typically want to be no leaner than a 12.0:1 running nitrous. Just be careful whatever you do. An EGT gauge would tell some of the story on what is actually going on. For some reason, perhaps how lean you are running isn't causing any high cylinder temps. I doubt it but I've seen stranger things. It's hard to really read the air/fuel ratio scale because it's so funky.
On a positive not, NICE numbers. I likey!
Kevin Thomas is offline   Reply With Quote
Old 07-04-2005, 11:10 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Yeah, I assumed the 14.3:1 was the N/A run. sidewayz, if you're running 14.3:1 on NO2, your engine is a timebomb.
Pat
Old 07-05-2005, 12:13 AM   #6
sidewayz
Member#: 5810
2001 S366 2.5RS
yeah Pat.. I didnt clarify. The 14.3 was NA. that dyno graph sucks but my copy if you look really really close, you can see my N2O run was hovering around 12.5-13. and at about 4,600RPM it chases 12 down to 11 steady. At that RPM in NA mode she swallowed around 13.5 down to 13 at 6k
Old 07-05-2005, 12:33 AM   #7
Impreza2003
Member#: 67247
2003 2.5RS BRP
SQC 189
I saw your run at e-town too... pretty cool and i wanted to know your mod list, but thats answered.
Impreza2003 is offline   Reply With Quote
Old 07-05-2005, 11:01 AM   #8
sidewayz
Member#: 5810
2001 S366 2.5RS
thanks guys. Mod list is pretty vague.
Magnecor wires (dont do squat)
ACT clutch
Exedy flywheel
thats really it for power adders. everything else is suspension
Old 07-05-2005, 11:05 AM   #9
FriedIceCream
Member#: 84154
2010 S&M WTF
Trans Purple
nice!!
FriedIceCream is offline   Reply With Quote
Old 07-05-2005, 11:25 AM   #10
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Soooo...what was your 1/4 mile result?
HamFist is offline   Reply With Quote
Old 07-05-2005, 12:11 PM   #11
sidewayz
Member#: 5810
2001 S366 2.5RS
NA I ran a 14.9.. I gotta hit the track with the juice..She should hit high 13's.. Im hoping for a best of a 13.5.
Old 07-05-2005, 12:36 PM   #12
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
That's cool. I'll hopefully hit the dyno today with the E85. We'll see how she does.
Old 07-06-2005, 12:47 AM   #13
beastSTI
Member#: 87633
2005 Impreza WRX STI
Nice #S n/A IS yummy
beastSTI is offline   Reply With Quote
07 WRX, VF-30, e-Tune, Deceiving Dyno Graph silverf0x Proven Power Bragging 79 07-08-2010 12:05 AM
Latest dyno results and dyno video. 536 hp / 470 tq STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 42 10-25-2004 12:54 PM
STI Accessport Dyno results....dyno plot attached GameOver Engine Management & Tuning 59 06-12-2004 04:17 AM
Completely stock dyno VS turboback + uppipe dyno RESULTS! billmidd08 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 12-10-2003 12:01 AM
Dyno results posted from NW i-club Dyno Day! sponaugle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 06-04-2001 10:30 PM
