Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 07-05-2005, 01:09 PM   #1
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Default any chips for 1.8l ecu?
Are there any sources for an add on chip for the 1.8l ecu? I noticed an extra spot for a plug in IC or module in my ecu when I had it apart. Is there one available I could get to improve the ecu's performance/speed or processing capability to help my poor little 1.8 out?
2slofouru is offline   Reply With Quote
Old 07-05-2005, 11:05 PM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Nope.
Engine swap, turbo kit, or drive down a steep decline.
Old 07-06-2005, 09:46 AM   #3
stickfiguredanny
Member#: 60408
1995 Impreza L
SeaFoam green i think
its an underpowered little motor but you can still have fun in it work on your handling first
stickfiguredanny is offline   Reply With Quote
Old 07-06-2005, 10:56 AM   #4
ImprezaRallystyle
Member#: 48918
2006 Forester XT
1993 impreza RALLY
one easy thing you can do is swap the 1.8 for a 2.2L
they are basicly the same motor same connector on wiring harness, the only difference between the 2 motor is in the piston size, when subaru decide to built the 1.8 they took the 2.2 motor and resize the cylinder with smaller piston, they told subaru mechanic's that this motor will be one of the toughest motor ever built by them because execpt for the piston size every thing else is from the 2.2 mechanic.
i done this swap in my rally car, and i even kept the 1.8 ecu and tranny.
it was very easy to do and work very good.
usually the 2.2 motor is pretty easy to find and cheap to ( mine cost me 600$ canadian when i both it )
ImprezaRallystyle is offline   Reply With Quote
Old 07-06-2005, 07:51 PM   #5
DragonRM
Member#: 14365
Perfect Power would probably work for you but you won't get much more out of a 1.8... swap that sucka out hehe
DragonRM is offline   Reply With Quote
Old 07-06-2005, 11:44 PM   #6
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Or you can do a 2.2 shortblock with the 1.8 heads. Wont require any rewiring or anything really, other than changing out the shortblock... It works because you end up with like a 11:1 compression ratio which gives it even more hp than a regular 2.2.
Old 07-07-2005, 12:59 AM   #7
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Yeah, and since I would already have the 1.8 heads... Thanks for all the replies. I'm learning some cool things about these cars. I already thought they were awesome. You guys are making them sound better by the minute. I thought it would be difficult to mod mine. Not like the civics that you can buy mods at Autozone for, ha ha. I might actually lower the car a little to make it have a more agressive stance AFTER I get a little more power under the hood! Thanks.
Old 07-07-2005, 09:12 PM   #8
josh...just josh
Member#: 82273
97 impreza L
now with wrx brake love!!
the 11:1 comp will give you about a 150hp peak up from the 2.2's stock 137hp from an internal effeciantcy increase of something like 10% (Icant remember the exact #"S it's been awhile since Ifigured it up), you'll have to run premo gas to keep the thing from igniting as well. another point to condider is the possible machining costs , ie resurfacing costs, to mate a worn head to a different worn block
josh...just josh is offline   Reply With Quote
Old 07-08-2005, 08:02 PM   #9
jamesonc
Member#: 49629
'87 Dodge Ram 50
1.8L's are pretty underpowered.....i'd do what everyone else is doing and swap it out.
jamesonc is offline   Reply With Quote
Old 07-09-2005, 05:29 PM   #10
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
You could always attach a rocket to the car. Sure, it'd only work once, but it'd go really fast while it was going.
(In case you haven't noticed, Al's feeling eccentric today.)
Al_Smokemcrack is offline   Reply With Quote
running EJ25 engine w/ 1.8L ECU??? SubaruPreza Subaru Conversions 16 12-15-2008 12:51 PM
Fuel/Timing Control for 1.8L ECU Sko Normally Aspirated with bolt-on Forced Induction Powertrain 14 02-09-2007 04:44 PM
JDM 95 WRX ECU 95 USDM 1.8L ECU sti_95imp Private 'For Sale' Classifieds 8 10-03-2005 07:36 PM
Runnin SOHC EJ25 off a 1.8L Ecu and Harness PumpsGOTAWD Normally Aspirated Powertrain 1 07-03-2004 02:37 AM
Needed: 95 Impreza 1.8L ECU pinouts Aspen_2.5RS Subaru Conversions 10 11-13-2003 01:14 PM
