Old 07-05-2005, 02:39 PM   #1
darkwaterz
Member#: 65165
97 OBS
i miss my RS...
News NEED IMEDIATE INPUT!!! (please)
hello,
I just put a prodrive oval tip axelback from a wrx(2.5") on my NA 2.5rs with a custom 2.5" center pipe(eliminating the after-cat resonator). 2 problems!!
1. Low end torque! where'd it go!?? I don't care what anyone says, The 2.5 is TOOOOO big, feels fantastic above 4000 but there's no pull below 3500!
2. WOW this is pretty loud. Not so much when cruising above 35mph but from a standstill it sounds like I'm lining up to race... EVERY TIME. haven't caught the attention of any PD yet....I just moved here, what does it take?
MY SOLUTION----THIS IS WHERE I NEED SOME FEEDBACK:>>>
I have an appointment to have a 2.25 pipe made, using the old resonator right after the cat. GOOD??
Last edited by darkwaterz; 07-05-2005 at 06:57 PM. Reason: RESOLVED!! check it out!
darkwaterz is offline   Reply With Quote
Old 07-05-2005, 02:56 PM   #2
wht052.5
Member#: 79527
2005 2.5RS(I NDTRBO)
Chipped Crystal Gray
2.5 too big, huh?
Damn, That is what I was planning on. I've always had good luck with 2.25, though.
Your plan sounds good, Let us know the results.
wht052.5 is offline   Reply With Quote
Old 07-05-2005, 03:14 PM   #3
DreddRS25
Member#: 51642
2008 WRX
That's what I did from the get go. I used a custom 2.25" midpipe to a WRX axleback. Increase in sound with little to no change in performance. Maybe a little above the 4000rpm mark.
Possibly any leaks? That will kill some low end torque.
For an inspection I had to take my borla headers off (larger diameter ~2.25 infront of the converter). And I noticed that when I put them back on I definitely had more low end over stock. I also have a ganzflow intake, so I got more flow in matched with the increase in exhaust flow.
Did you reset the ECU? Never hurts. GL!
DreddRS25 is offline   Reply With Quote
Old 07-05-2005, 03:41 PM   #4
mc_866
Member#: 84885
99 2.5 RS
Silverthorn
I just got done doing a bunch of upgrades to my 99 RS. I started with the cat back and noticed the same thing. I used a 2.5 cat back and noticed a little low end disappearance, but when I installed my COBB CAI, it evened things back out, with a lot more pull across the entire band. You may want to look into a CAI. Also my cat back seemed really loud compared to stock until I put the headers on, now itís more of a rumble and less of a high pitched rev. I say pick up some headers and a CAI, you will notice a big difference.
mc_866 is offline   Reply With Quote
Old 07-05-2005, 04:26 PM   #5
Impreza2003
Member#: 67247
2003 2.5RS BRP
SQC 189
too loud could be exhaust leak!
Impreza2003 is offline   Reply With Quote
Old 07-05-2005, 04:57 PM   #6
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Darkwaterz, Do you have any other mods?
Tim Sanderson is offline   Reply With Quote
Old 07-05-2005, 05:10 PM   #7
hendo2.5
Member#: 89912
2005 Impreza 2.5rs
Inexplicably rusting.....
yeah, that happened to my '91 MR2 and it ws a gasket
hendo2.5 is offline   Reply With Quote
Old 07-05-2005, 05:28 PM   #8
Millencolin!
Member#: 88219
1992 Legacy SS
EJ22t + 16g = :)
Its because on N/A engines you have to even out the circulation of gases. In your case the exhaust is able to be pushed out easily but the intake air cannot go in as fast. I would suggest doing what mc_866 did and get a good CAI to even out the air flow.\
As for headers you can't go too big or you will lose the backpressure that N/A engines need to help pull exhaust out of the combustion chamber. Go to Unabombers manifesto and go through the Exhaust section. There are 2 links, one goes to Cobb's website and one goes to Vishnu tuning. Read the parts more N/A engines and maybe it will make more sense
Millencolin! is offline   Reply With Quote
Old 07-05-2005, 06:51 PM   #9
darkwaterz
Member#: 65165
97 OBS
i miss my RS...
Cool Resolution!
first off, thanks for the quick feedback, I was checking it frequently before my appointment.
This is what I did:
I reset the ECU...That actually did help a bit, but not to my satisfaction.
I had the guy remove the front gasket at the weld and the rear gasket a few inches from the weld, he attached the resonator up front and followed it with 2.25 tubing. The 2.25 overlapped(or underlapped ) the small piece of 2.5 and welded at its end so that when I want to go back to a 2.5 all the way through(like when I go EJ20t), I can just cut it at the weld and take it from there.
SO, The sound is a little tiny bit quieter when cruising and alot softer from a stand still....still roars like a beast when I punch it. AND>>> I HAVE MY TORQUE BACK!!!!!!!!!!!!! It may still be a bit gentler real low(can't really tell) but it definately feels improved over stock above 4000...(but not as much as with the 2.5)
You're right, I do need to invest in the CAI for power AND balance, Cobb sounds good if it works with that stupid MAF.
Thanks all.
z.
Old 07-05-2005, 10:12 PM   #10
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
You must be smoking crack, because i sure didn't lose and lowend torque with my 2.5in cat back. You have to reset the computer and give it a whole tank of gas to really learn your "not stock set-up". But i also have intake too.
Fine, maybe at idle up to 1500 rpms there is less power then stock. I can say for sure there is more torque at 2500 rpms with 2.5in.
RS_to_WRX_swap is offline   Reply With Quote
Old 07-06-2005, 06:55 PM   #11
DragonRM
Member#: 14365
Yeah... need an intake too and a computer chip of some type would help... otherwise the exhaust doesn't have enough flow or the right fuel ratio to really work well. As far as volume you could get the midpipe resonated to cut the sound down a bit.
DragonRM is offline   Reply With Quote
May need a new(er) laptop. Need some input. wizzman New England Impreza Club Forum -- NESIC 21 10-29-2005 02:47 AM
Need IMEDIATELY- Rear studs for R160/R180 MK19_ South East Region Forum 9 05-11-2005 10:57 PM
Engine Management question (MRT input please) WRX Ver.7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-28-2002 11:29 PM
Greg555 - need your input mykrrrr Mid West Subaru Owners Club Forum -- MWSOC 5 12-29-2000 12:19 AM
New Business Idea, Need Your Input johnfelstead General Forum Archive 3 06-27-2000 06:42 AM
