Old 07-05-2005, 05:04 PM   #1
blackntan
Member#: 90591
Default Oxygen sensor replacement
Hello everyone, I was wondering if there are any resources here that would help me in changing my O2 sensor on my 1999 Legacy. I searched the forums and site, but didn't find anything. If someone can point me in the right direction I would appreciate it. Thanks.
blackntan is offline   Reply With Quote
Old 07-05-2005, 06:05 PM   #2
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
try www.scoobymods.com or, maybe the best option, buy a Hayne's Manual for your car's MY. They are available at Autoparts stores and book stores, or for the cheapest, www.ebay.com has them.
Jared
gtwagon941 is offline   Reply With Quote
Old 07-06-2005, 10:49 AM   #3
BigMattyD
Member#: 90610
1996 Legacy L 5MT
Brown
Basically, you find the O2 sensor, remove it with an O2 sensor socket and a long breaker bar, then replace it with the new one and attach the wire.
Depending on the position of the sensor, you may need to remove some parts or loosen the exhaust system to be able to reach it. There is one sensor just before the catalytic converter, and one sensor behind the 2nd cat.
At least on my car, there is.
An o2 sensor socket costs around 10 bucks, but it is essential, in my opinion.
The sensor is tight as heck and does not want to come out easily...
P.S. Some stores will let you borrow the socket..
Matt D.
BigMattyD is offline   Reply With Quote
Old 07-06-2005, 04:26 PM   #4
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Dab some anti-seize on the new sensor threads in case you still have it when it needs to be swapped the next time.
ss
subysouth is offline   Reply With Quote
Old 07-06-2005, 04:56 PM   #5
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
...and spray the old one down by the bung with liquid wrench or similar. Allow it time to work before attempting to remove. It would be a shame to strip the threads which can happen...
xcntrk75 is offline   Reply With Quote
Old 07-06-2005, 07:57 PM   #6
turbo2ner
Member#: 89385
many most all
WRB/blk/blk/blk/slvr/wht
7/8" open ended wrench. No big deal.
turbo2ner is offline   Reply With Quote
Old 07-07-2005, 06:43 AM   #7
Hiroki Tada
Member#: 8048
I highly suggest you use an oem piece and try to stay away from the aftermarket O2 sensors. even if it does cost much more. apparently for the universal fit pieces, you need to splice away at for the connectors from the orginal sensor and re-solder them onto the new one. its easy to mess up and its just alot more trouble than its worth.
Hiroki Tada is offline   Reply With Quote
Old 07-07-2005, 09:40 AM   #8
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
Meh. When I had an "emergency" o2 sensor need, all I could find at the parts store was a Bosch Universal one...
It was quite annoying to have to re-use the old connector, but it's not a huge deal. So long as you solder the wires properly and use some heatshrink, it'll hold up fine.
If you don't know how to do real wiring, or think that a crimp connector or wire nut is a proper connection, then you're gonna have problems.
-Brian
KD7000 is offline   Reply With Quote
Old 09-12-2005, 12:09 AM   #9
toxicavenger70
Member#: 95767
1997 Gt WGN
white
Default easy fix
hey bro buy a universal for about 40 dollars less and it has two white wires and one black one. u can either use a soldering iron or wire connectors but u have to use the shielding that comes with it to keep the heat off of the wires or else they will be melted. also there is a hanger that holds the wires off of the exhaust and use it or else it will also get melted. it is a very easy job just take ur time us PB blaster to get it out with a open end 7/8's. and also use anti-seaze to put the new one in!
toxicavenger70 is offline   Reply With Quote
Old 09-12-2005, 08:36 AM   #10
jedi_master
Member#: 62568
2005 Outback 2.5 XT
I usually just use an adjustable wrench and back it out of there with no problem- no need for a special socket.
jedi_master is offline   Reply With Quote
Old 09-12-2005, 10:33 AM   #11
Gil
Member#: 20872
t3h rubber-neckers
must die!
are there specific ones for each make/model?
Gil is offline   Reply With Quote
Oxygen sensor replacement warranty coverage gmanz Warranty Issues & SOA Problems 14 05-27-2009 11:31 AM
Oxygen sensors replacement DIY guide lil-bush Newbies & FAQs 4 07-19-2007 12:23 PM
Replacing rear oxygen sensor Fubaru Service & Maintenance 12 11-03-2005 12:00 AM
Can I replace just 1 oxygen sensor? nixx Normally Aspirated Powertrain 9 01-26-2005 07:21 PM
Oxygen sensor...time to replace? GooseMan Service & Maintenance 8 07-06-2004 08:03 AM
