Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 07-05-2005, 10:47 PM   #1
Member#: 48862
Default Chewed up my O2 sensor, can I do without it?
Well, I screwed up my front O2 sensor when trying to install my new motor. I should have not put it in until after I installed the motor. It is in the stock location just below the uppipe.
Anyway, when I was putting the engine in it rubbed against the frame and cut some wires where they go into the sensor, so no way can I splice and fix it.
I have several questions, here are my mods.
Stock 2003 WRX motor, DNPerformance catback exhaust, DNP uppipe with 2 bungs (1 for O2 sensor 1 for stock EGT), UTEC, Walbro fuel pump and WORX BOV.
#1) Do I need this O2 sensor for the engine to run well if I am using the UTEC ?
#2) I know it will throw a CEL without it, will an O2 Simulator fix that?
#3) In the spare bung on the DNP uppipe can I install an EGT for my use?
F15DOC is offline   Reply With Quote
Old 07-05-2005, 11:19 PM   #2
Member#: 81106
2014 Baby Mobile
Whitey White
1) You have to have the o2 sensor for your car to make correct judgments on air fuel ratios.
2) Possibly don't know why you would want to try after response to question 1
3) yes.
Happy tuning!
Anub1s is offline   Reply With Quote
Old 07-06-2005, 10:28 AM   #3
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
1) You absolutely need the front O2.
2) Buy a new O2.
3) Uppipe EGT sensor aren't very good since the exhaust flow cools alot before the uppipe.
mbiker97 is offline   Reply With Quote
Tire shop F^%&s up my wheel, What can I do? 2.5 Blue Roo Mid Atlantic Impreza Club -- MAIC 26 11-08-2006 08:22 PM
Damaged my O2 Sensor - does it matter? cwepruk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 10-09-2006 08:36 PM
how do i replace my o2 sensor? snowb0ardin04 Normally Aspirated Powertrain 6 02-04-2006 01:26 AM
Dealer Bench testing o2 sensor? Can it be done? ShawnRS Normally Aspirated Powertrain 1 11-21-2004 06:13 PM
Greddy A/F in '94 WRX...can I use my O2 sensor? annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-18-2002 03:15 PM
