Old 07-06-2005, 02:00 PM   #1
Agkelos
Member#: 58163
2002 Stage 2 WRX
World Rally Blue
Default Gunk on oil pan...Oil leak?
Changing my oil today, oil pan was covered in gunk. Is this just normal dirt and grim from previous owner not cleaning it or should I be worried about a leak. All sides of it were covered in this gunk. I was concearned because my car was below low on oil level after 3k miles and I was worried when I found this. Bought the car a year ago used and every once in a while I find small "presents" the previous owner left me, so I get paranoid a lot.
Pics:
Thanks for help.
Agkelos is offline   Reply With Quote
Old 07-06-2005, 03:25 PM   #2
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Looks like it might be coming from the front main seal. Is it leaking just under the cam cover up by the oil pump?
Drac9 is offline   Reply With Quote
Old 07-06-2005, 03:34 PM   #3
Agkelos
Member#: 58163
2002 Stage 2 WRX
World Rally Blue
I will go put it on ramps and look again, so it is oil leak then?
Old 07-06-2005, 09:10 PM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Yes sir. You have "the leak".
Tim Sanderson is offline   Reply With Quote
Old 07-06-2005, 10:50 PM   #5
Agkelos
Member#: 58163
2002 Stage 2 WRX
World Rally Blue
What is "the leak?" Is it a common suby problem? What is estimated cost to repair? This sucks.
Thanks for help identifying.
Old 07-06-2005, 11:12 PM   #6
RootUsr
Member#: 39652
2007 WRX TR (UGM)
R.I.P d00m Wagon
Well, I just fixed "The leak" on my '98 OBS this past week (could have done it in a day, but things broke...)
if you know what you're doing (even if you've never done it before) , you could probably do it with $50 in parts and 5 hrs labor...
having the subaru tools helps I'm sure... but my friend and I managed with 2x$1.00 bolts and a 2x4 found in my backyard for the camshaft sprocket holder
I was offered to have it done for $230 from someone else on the forums. so that's another estimate...
RootUsr is offline   Reply With Quote
Old 07-06-2005, 11:26 PM   #7
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Oil can get swirled around the pan, and can come from almost any direction.
It doesn't seem like the oil pump/front main is leaking from the pics, I would take a look again though.
You might want to check the seperator plate, which is in the back of the block behind the flywheel/flexplate. This was more common problem on the older cars with plastic plates.
Check valvecover seals and cam seals from the timing belt cover.
From the looks of it, it seems to be minor seepage, and not exactly a puking leak. You should see the underbody of my car if you want to see an example of a "leak"
-paK +1
Pakin is offline   Reply With Quote
Old 07-07-2005, 09:23 AM   #8
Agkelos
Member#: 58163
2002 Stage 2 WRX
World Rally Blue
Ok thanks for all of the help, I'm going to keep an eye on the underside of the car daily and if I see anything again I'll start working on it.
Old 07-07-2005, 12:06 PM   #9
RootUsr
Member#: 39652
2007 WRX TR (UGM)
R.I.P d00m Wagon
Do you also get the infamous "cloud of blue smoke" at stoplights?
I had that...
Old 07-07-2005, 12:22 PM   #10
Agkelos
Member#: 58163
2002 Stage 2 WRX
World Rally Blue
No, no other symptoms other than the "gunk" and the low oil.
Dented oil pan... oil pickup clearance? Hokie-wrx wagon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 08-10-2009 05:17 PM
FS(pa) STI Parts, Upipe, Oil Pan, oil Pick up tube [email protected] Engine/Power/Exhaust 6 03-17-2009 03:01 PM
FS: VA:MD: EJ255 Heads w/cams, 3" S/S V-Band Clamps, EJ20 Oil Pan, Oil Cooler, etc. matt84 Engine/Power/Exhaust 49 03-09-2009 10:45 PM
FS: VA:MD: EJ255 Heads w/cams, 3" S/S V-Band Clamps, EJ20 Oil Pan, Oil Cooler, etc. matt84 MAIC Private Classifieds 42 03-07-2009 02:07 PM
Oil Pan Gasket leak? (Pic) my3awds Service & Maintenance 4 12-31-2005 09:14 AM
