Old 07-06-2005, 07:24 PM   #1
speakerman86
Member#: 90670
1993 Impreza L FWD
Metallic blue-green
Question 93 impreza L top speed?
I'm new to the whole forum thing so I apologize if someone already posted this question. Can anyone tell me the top speed of my stock 1993 Impreza L? Speedometer reads 140 but I have my doubts. Thanks.
speakerman86 is offline   Reply With Quote
Old 07-06-2005, 07:28 PM   #2
VTsuby
Member#: 81369
2007 STI
My 97 L 190000miles bone stock tops out a between 100 and 110 depending on day
VTsuby is offline   Reply With Quote
Old 07-06-2005, 08:12 PM   #3
bongchild
Member#: 28352
1993 1.8 helL (AWD)
'06 Corolla XRS!
damn, 190k miles?? impressive... My car tops out at about the same speed on even ground. I got it up to 140 once when i was driving downhill with a stiff tailwind.
bongchild is offline   Reply With Quote
Old 07-06-2005, 11:37 PM   #4
speakerman86
Member#: 90670
1993 Impreza L FWD
Metallic blue-green
so the car is capable of 140.......Just on a good day. What would help me reach that speed easier? Is there a gear ratio mod available for the 93?
Old 07-07-2005, 01:05 AM   #5
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
I have a 95 and it is green. There is no way it could make it to 140, not even downhill. It seems to run into a wall at about 105 and takes forever to get to 110. I have 172k on the odometer and it runs perfectly. Do you have a standard transmission? Maybe they put a limiter on in the models after yours.
2slofouru is offline   Reply With Quote
Old 07-07-2005, 09:51 AM   #6
drewdogg
Member#: 90003
2005 STi
does the fact that it's green make it slower???
drewdogg is offline   Reply With Quote
Old 07-07-2005, 09:53 AM   #7
stickfiguredanny
Member#: 60408
1995 Impreza L
SeaFoam green i think
ive gotten to 115 in my 95 1.8L with about 150k
stickfiguredanny is offline   Reply With Quote
Old 07-07-2005, 11:26 AM   #8
speakerman86
Member#: 90670
1993 Impreza L FWD
Metallic blue-green
Yes I do have a manual transmission. I've had it to 90 in 4th gear. I figured 5th would at least make it to 120.
Old 07-07-2005, 11:34 AM   #9
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Yes the green color does affect top speed. You see, bugs are attracted to it like crazy and the impact of hundreds of bugs commiting suicide on my grill and windshield slows me down!
Old 07-07-2005, 03:27 PM   #10
The_Black_WRX
Member#: 70964
99RS 04 wrx
07 wrx limited wagon
i had a 93 L wagon that i got up to 113 with 220K miles on it ran great untill it got totaled
The_Black_WRX is offline   Reply With Quote
Old 07-07-2005, 05:02 PM   #11
Ayrton Senna
Member#: 90426
2005 SAAB 9-2X Aero
Arctic Silver Metallic
220k miles? Holy crap. That's amazing.
Ayrton Senna is offline   Reply With Quote
Old 07-07-2005, 05:10 PM   #12
samoht_ackerman
Member#: 89144
1994 Impreza L
Green
94 1.8 w/ 170k 5 speed At 6000 for the elevation
i got it to 108 and increasing before a 70mph(recommened at 50) turn came up.
Depending on the temp and elevation i could go about 120 if i had room around 105 i was increasing slower
samoht_ackerman is offline   Reply With Quote
Old 07-07-2005, 05:41 PM   #13
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
99L: i have hit 105 on the freeway once....it had a lot left in it
svek is offline   Reply With Quote
Old 07-07-2005, 06:02 PM   #14
WRXMANDO
Member#: 17671
93 L with 210,000 and no more than 95mph
WRXMANDO is offline   Reply With Quote
Old 07-07-2005, 08:12 PM   #15
VTsuby
Member#: 81369
2007 STI
I've squeaked 110 out of my volvo 240 with 360000miles
Old 07-08-2005, 01:37 AM   #16
myobsej22
Member#: 88024
1997 OBS
red/gun metal two tone
do any of you guys have a speed limiter bypass or something, because i read somewhere that a lot of subarus have a speed limiter on them at 112mph..i know my car has one because i hit it on the highway and couldn't go any faster, so either some of you are full of it or there's no speed limiter on you car.
myobsej22 is offline   Reply With Quote
Old 07-08-2005, 10:02 PM   #17
Soob
Member#: 7631
1999 Impreza RS 2.5
Black Pearl
Hit 115 in my 99RS w/ 95000. It felt like it hit the limiter because I felt the gas cutting off
Soob is offline   Reply With Quote
Old 07-09-2005, 12:57 AM   #18
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
I think some have a limiter. Maybe the years after his, because that's exactly what mine feels like. It's pretty quick up to 95, then it gets weak quickly. I have new fuel pump filter, and perfect injectors, so it must be the ecu doing it. I know it should be able to hit 120-125 with 110hp, older cars with the same or less hp and heavier have done it.
Old 07-09-2005, 01:02 AM   #19
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
thought the only limit was the gears on an RS
moogoob is offline   Reply With Quote
Old 07-09-2005, 01:03 AM   #20
cabe
Member#: 55864
2002 WRX sedan
Sorry, but it didn't have a lot left in it, it cuts out at 112. I had a 99 impreza L 5 speed before my rex and it was fairly quick, but unfortunately cut out at 112 (still pulling ok to that point).
I was with my friend in his 93 L with a 1.8 and it got up to 125 fairly quickly. It was a slight downhill and he has an axle back and S-AFC, but I really doubt they helped too much.
cabe is offline   Reply With Quote
Old 07-09-2005, 02:48 AM   #21
Hawk296
Member#: 14555
1995 Impreza L
Baja
95 L 1.8 AWD 5speed I managed 127MPH and still had a few hundred RPM left. There is no speed limiter on the early Ls with manuals trans. They are limited by power and gearing (fuel cut occurs at redline in 5th gear).
The FWD Ls had taller gearing so in theory, with enough power, they will be faster. problem is they dont have enough power....
Hawk296 is offline   Reply With Quote
Old 07-09-2005, 03:19 AM   #22
imprezin04
Member#: 39482
2000 Impreza RS
SRP
ive hit 112. 96L with 98k miles now. i never hit the rev limiter but it took forever to get there and didnt see it moving any further up so i just slowed down.
imprezin04 is offline   Reply With Quote
Old 07-09-2005, 11:09 AM   #23
cabe
Member#: 55864
2002 WRX sedan
Yeah fwd makes a huge difference in the 1.8s, don't you agree? My other friend had a 1.8 awd and it was pathetically slow. On a good day it would be hard pressed to get up to 105.
Old 07-09-2005, 03:46 PM   #24
Soob
Member#: 7631
1999 Impreza RS 2.5
Black Pearl
Definitely felt like it started to top out, but I thought I read somewhere that it was capped at 115? Correct me if I'm wrong. But it definitely felt like the gas was cutting off
Old 07-09-2005, 04:38 PM   #25
SIL01
Member#: 33991
1998 Legacy GT Wagon
Brilliant Red
My 2001 L tops at 112.
140??? Yeah, good luck with that.
SIL01 is offline   Reply With Quote
1986 subaru gl trans on a 93 impreza fwd 5 speed soobxnoob Transmission (AT/MT) & Driveline 3 04-16-2010 03:39 PM
Fs: (de) 93 Impreza 5 Speed 4 Door Wrx Upgrades Sti Rear Seat 1700 Obo blueghost Private Vehicle 'For Sale' Classifieds 13 09-05-2008 01:19 AM
93 impreza blower fan, speed 4 only Nsantos23 Service & Maintenance 13 04-17-2008 09:15 PM
93-00 impreza sport top spoiler subby00 Private 'For Sale' Classifieds 20 05-08-2004 08:57 PM
I would like a picture from the top of a 93+ impreza rear spring ciper Brakes, Steering & Suspension 4 02-14-2003 03:07 PM
