Old 07-06-2005, 10:17 PM   #1
chris124816
Member#: 47413
1999 impreza obs
black
Default I have no idea where to tap in for water cooling my turbo
Im building my own turbo i have everything worked out except i have no idea where to get the water lines. i tryed hooking up to the outlet heater hose but it wasnt pushing any water, any ideas where i can tap into.
chris124816 is offline   Reply With Quote
Old 07-06-2005, 11:32 PM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
mine is taking off of the heater core hoses, the two that run parallel, just T'd in and ran one to each nipple.
Ben
Old 07-06-2005, 11:40 PM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
for that big juicy gt-42r?
that things needs so much flow
just T into the main radiator feed
Old 07-07-2005, 12:26 AM   #4
ThuotRDX
Member#: 16106
1992 T3/T4 turbo SVX
with a 5 speed
take it off of the throtle body
ThuotRDX is offline   Reply With Quote
Old 07-07-2005, 07:28 AM   #5
PunKidd
Member#: 8533
2002 2.5 RS-T
LudeSpeed S. III W/ FMIC
The TB lines aren't going to give you much flow. The Heater core lines are a typical place to tap in. Make sure to use the supply and return from the heater core, otherwise you won't get flow when the heater is off.
PunKidd is offline   Reply With Quote
Old 07-12-2005, 09:02 PM   #6
chris124816
Member#: 47413
1999 impreza obs
black
So the reason i wasnt getting flow was because i only tapped in to the cool line from the heater and i need to t into the in and the out
offset question only because i have NO idea how to even search for this.. naggg Newbies & FAQs 4 07-13-2009 02:16 PM
I'd like to buy a juicer, but have no idea where to start. Drink Off-Topic 6 05-30-2009 12:36 AM
So I'm ready to start my own business, but have no idea where to start. Protege Menace Off-Topic 27 07-30-2008 01:44 PM
good locations to tap in for water temp & oil pressure ? SportyBry STi Forum Archive 4 08-23-2003 03:25 PM
Where to tap in for boost gauge??? WRBLUEWAGON Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-18-2002 02:33 PM
