Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 07-07-2005, 01:10 AM   #1
Quest 4 STi wagon
Member#: 60493
2008 STI
Default Best Tire/Wheel measurements for wagon
I'm looking into getting a set of new rims and tires for my 02 WRX wagon and since ive heard of issues with rubbing on the fenders i was wondering what would be the best balence of rim size/offset and tire size to keep agressive look yet some decent ride comfort and prevent road rashing.
Quest 4 STi wagon is offline   Reply With Quote
Old 07-07-2005, 07:58 AM   #2
Member#: 86939
2006 GTI
DriveFast is offline   Reply With Quote
Old 07-07-2005, 09:15 PM   #3
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
That article is only for 48 offset tires and is very true.
Get wheels with an offset of 53 and run 225s. 04 STis work nice, many of the SSRs can be had in the 50+ offset range too.
It is that easy. No rubbing.
dbrier is offline   Reply With Quote
Old 07-07-2005, 09:26 PM   #4
Member#: 16318
2002 WRX Franknwagen
Grime over Sedona Red
^^^motion seconded...with caveats.
I personally run Prodrive P1 (ET53), with Michelin PS(just ordering PS2s), 225x45/17, with no significant rubbing. I phrase it that way because I have seen a couple of rub marks in the fender wells presumably resulting from RallyX exuberance; no problems, and no rubbing in normal use.
There are a number of threads buried in this forum discussing just how far people have pushed the limits of <wheel size / offset / tire size> on wagons that might give you additional info...or at least opinions
One thing to be aware of: different makes/models of tires with the same nominal size can vary significantly in actual total width, and this can be a critical issue when you start pushing the limits of wheel/tire combos.
GravelRash is online now   Reply With Quote
Old 07-08-2005, 01:14 AM   #5
Member#: 81016
2005 lgt ltd
regal blue
i've got 18x8 volks +50 offset with 225x40/18 on my wagon. lowered just a bit. no rubbing at all. the ride may be a little rough for what you want.
tomswrxwgn is offline   Reply With Quote
best tire wheel combo for 2007 sti stock height SHAG SCOOB Tire & Wheel 10 01-18-2010 06:43 PM
18" wheel/tire track setup for wagon? REXMASS Tire & Wheel 1 06-08-2007 01:38 PM
Measurements for wagon front sway bar? wylie Brakes, Steering & Suspension 14 09-15-2005 11:10 PM
best rota set up for wagon???? daphunkie12 Tire & Wheel 4 10-31-2004 01:04 PM
max tire/wheel size for sedan and wagon wantasti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-31-2002 05:05 PM
