Old 07-07-2005, 01:59 AM   #1
BenBortner
Member#: 50017
2010 Genesis Coupe
Default Help, acceralted hard, now car wont start!
abcde
BenBortner is offline   Reply With Quote
Old 07-07-2005, 03:13 AM   #2
Chi_San
Member#: 53558
2002 WRX Wagon
Originally Posted by BenBortner
Here's the deal. I was going 40mph in 4th, reved it up and put it into second and pulled through 2nd and 3rd. When I let off, the car died, as I rolled to a stop at a stop sign. Tried to start, didn't start right, kinda fumbled a bit. Turned it off, tried again and it started normal. Now tonight when I get back in to head home. The car wont start. The engine turns over and everything. But it wont start, at first it was kinda fumbling a little, now it wont go past cranking. It was making this weird ticking, sort of like a fan by the trottle body and the lights on the dash for the oil, CEL, etc were dimly lit and the seat belt was flickering dimly with the Accesories turned off and the key out. I pushed down a little on the wires on top of the trottle body and it stopped ticking and the lights went off. But still wont start. Did I loose a ground or is something wrong with the fuel system? Anyone have any ideas. It was dark so I wasn't able to inspect the engine too well and I didn't have any tools with me.
Touch the battery terminals to your tongue. If you wake up a minute later in a puddle of urine, then your battery is okay. If you don't, then you probably need a new alternator, battery, or both.
Chi_San is offline   Reply With Quote
Old 07-07-2005, 04:57 AM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Classic!!!
Seriously, that clicking noise you were hearing was probably the starter motor cranking over but it wasn't getting enough juice to turn the engine over, so it's little clutch was just slipping (clicking). Your high RPM blast may have killed the alternator for some reason (or maybe you threw the belt?), so I agree with Chi_San - a new alternator or new battery may be in order.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 07-07-2005, 12:42 PM   #4
Shoebaru
Member#: 89342
You may be low on blinker fluid, check the dipstick while in reverse, if its not that the flux capacitor going bad
Shoebaru is offline   Reply With Quote
Old 07-07-2005, 12:44 PM   #5
HamFist
Member#: 2112
That's great!
HamFist is offline   Reply With Quote
Old 07-07-2005, 05:53 PM   #6
wht052.5
Member#: 79527
2005 2.5RS(I NDTRBO)
Chipped Crystal Gray
Timing belt anyone?
Would it still crank if he busted it?
wht052.5 is offline   Reply With Quote
Old 07-07-2005, 09:43 PM   #7
BenBortner
Member#: 50017
2010 Genesis Coupe
abcde
Old 07-07-2005, 09:47 PM   #8
hendo2.5
Member#: 89912
2005 Impreza 2.5rs
Inexplicably rusting.....
[quote=Chi_San]Touch the battery terminals to your tongue. If you wake up a minute later in a puddle of urine, then your battery is okay. If you don't, then you probably need a new alternator, battery, or both.[/QUOTE
i can remember waking up one morning, after going to a tequila party, and finding all of my clothes piled up, soaked with piss, and a samurai sword lying on top....
hendo2.5 is offline   Reply With Quote
Old 07-07-2005, 11:52 PM   #9
shftat6
Member#: 84819
2005 STI
CGM / Gold
So I take it you don't remember the party at all.
shftat6 is offline   Reply With Quote
Old 07-08-2005, 02:09 PM   #10
hendo2.5
Member#: 89912
2005 Impreza 2.5rs
i remember some of it. just not how it ended.
Old 07-08-2005, 08:19 PM   #11
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
i think it's safe to infer you were raped and pissed on by a samurai.
that's pretty badass man, not many people have that honor.
oh yeah, there's no way to tell what's wrong with your car from the info given.
Handsdown is offline   Reply With Quote
Old 07-08-2005, 10:13 PM   #12
hendo2.5
Member#: 89912
2005 Impreza 2.5rs
i hate it when that happens.
Old 07-09-2005, 01:13 AM   #13
Brandon24
Member#: 90849
2005 2.5RS
Crystal grey
are subarus interference engines?
Brandon24 is offline   Reply With Quote
Old 07-09-2005, 02:27 PM   #14
BenBortner
Member#: 50017
2010 Genesis Coupe
abcde
Parking lights wont work now car wont start inevitable_101 Electrical & Lighting 0 07-21-2009 04:51 PM
installed intake now car wont start King Fish Factory 2.5L Turbo Powertrain 13 07-25-2008 09:34 AM
Engine code madness, now car wont start.. shadymilkman129 Factory 2.5L Turbo Powertrain 10 03-23-2008 07:07 PM
autotuned hydra, now car wont start.... Joey_WRX Other Engine Management 7 01-23-2006 06:22 PM
misfire on cylinders 1 &3- now car wont start BrettS Factory 2.0L Turbo Powertrain 8 04-19-2005 10:54 AM
Message Board Statistics All times are GMT -4. The time now is 03:28 PM.
