Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 07-07-2005, 10:18 AM   #1
cnewhou
Member#: 90734
Default Cant change my tire.
I feel kind of stupid about this, but I went through all the steps of changing a flat on my 98 impreza and the damn thing wont come off. The car is jacked up, the 5 nuts are off, and it wont budge at all. Am I doing something wrong? Anyone?
cnewhou is offline   Reply With Quote
Old 07-07-2005, 10:30 AM   #2
fliz
Member#: 30342
The rim has rusted to the brake rotor. Hit it with a rubber mallet to break it loose. Be careful not to knock the car off the jack.
If that doesn't work, you may have to lightly replace the lugs and drive around the block to break it loose. Just be careful that you don't damage the lugs or wheel.
fliz is offline   Reply With Quote
Old 07-07-2005, 10:58 AM   #3
cnewhou
Member#: 90734
Thanks, I'll give that a try.
Old 07-07-2005, 11:22 AM   #4
cnewhou
Member#: 90734
it came loose when I lowered the car with the nuts loose,
thanks again.
Old 07-07-2005, 04:22 PM   #5
LordBass
Member#: 3266
2006 Jetta 2.0T 6MT
2009 Jamis Aurora Elite
Originally Posted by fliz
Hit it with a rubber mallet to break it loose...
I just went through this over the weekend. A spray around the hub with penetrating oil and a whack on the backside of the rim with a rubber mallet did the trick.
LordBass is offline   Reply With Quote
Old 07-07-2005, 04:51 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
.....the easiest way is to put the lugs back finger tight, and lower the car.....if putting the cars weight on it dosen't make it pop.....push on the car and rock it, side to side.......if that dosen't do it.....drive the car(in a safe place/way) a bit until it does pop.
Old 07-09-2005, 02:56 AM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Or just kick the damn thing, which is my preferred technique. If you're strong enough to kick your car off the jack then you're, ummm, really frickin' strong!
Pat Olsen
'97 Legacy 2.5GT sedan
Old 07-09-2005, 01:40 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
Pat Olsen
...Pat....I've seen rusted on wheels that you could have a mule kick for a week and not come off.....lowered the car and drove around the block with the lugs finger tight and, done deal.
When do I change my tires over? jcote02 New England Impreza Club Forum -- NESIC 377 10-28-2011 11:42 AM
Camber wear? Odd tire wear I cant put my finger on cucamelsmd15 Brakes, Steering & Suspension 19 02-03-2011 04:06 PM
Cant change base map AP V2... BBBsti LTD Engine Management & Tuning 0 06-01-2007 12:00 AM
Went to get my tires changed... Xeight General Community 30 12-06-2006 10:02 AM
i cant log in to change my mods M E R C U R Y General Forum Archive 1 10-13-2000 01:41 AM
