Old 07-07-2005, 03:19 PM   #1
G.Subramaniam
Member#: 64528
Default Going from NA build to Turbo build
I have a NA build
Borla headers
CAI
ProECM torque chip
High flow cat
2.25 Inch Catback
Mild Cams
I am considering switching to turbo of say 4-5 psi
Which of my current mods can I retain
I know that the 2.25 inch catback limits me to 300 hp or less
G.Subramaniam is offline   Reply With Quote
Old 07-07-2005, 03:23 PM   #2
gc8impreza00
Member#: 81107
2000 2.5rs
silverthorn/Carbon Fiber
right there with ya man -- going from NA to turbo at 5 psi... Ur going to need to get rid of the CAI for sure.. not too sure about the torque chip either... are you wanting a kit or to piece it together yourself?
gc8impreza00 is offline   Reply With Quote
Old 07-07-2005, 03:36 PM   #3
G.Subramaniam
Member#: 64528
Piece it together
Old 07-07-2005, 05:08 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
YOu can keep everything but the chip and the CAI...
Old 07-07-2005, 05:39 PM   #5
G.Subramaniam
Member#: 64528
Where exactly does the turbo tap into the exhaust gases to spin
Engine - header - cat convertor - catback ?
Old 07-07-2005, 08:14 PM   #6
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
I thought the chip had a built-in voltage limiter so the map sensor does not see boost?
(I guess this would only be useful if the guy decides not to use a standalone)
cRayZee is offline   Reply With Quote
Old 07-07-2005, 08:15 PM   #7
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
Engine - header - up pipe - turbo - downpipe - (cat if u want to have one) - catback/turboback.
ps... please buy my turbokit: http://forums.nasioc.com/forums/showthread.php?t=624573
Old 07-07-2005, 08:23 PM   #8
G.Subramaniam
Member#: 64528
I am curious, when these things blow, as a sizable number seem to do,
the only thing that has to be replaced is the short block ? correct ?
Old 07-08-2005, 12:19 AM   #9
maxitout77
Member#: 78793
GGA
AP Stg 2
they dont all blow, only some
if a turbo is placed on a NA car and tuned right and the boost doesn't go to high it can see many happy miles
maxitout77 is offline   Reply With Quote
Old 07-08-2005, 01:10 AM   #10
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I just blow pistons. So I just replace them.
Old 07-08-2005, 01:17 AM   #11
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
It depends how catastrophic the short block failure is. Usually the heads are salvageable but sometimes not.
no-coast-punk is offline   Reply With Quote
Old 07-08-2005, 02:03 AM   #12
gc8impreza00
Member#: 81107
2000 2.5rs
with 4-5 psi and a good tune you have a lower risk of blowin the engine than say 8-9psi. Every pieced together kit is different though depending on where you spend your money and how much HP you want to produce... As long as you don't get hit with the boost bug you should be ok.
Old 07-08-2005, 01:29 PM   #13
Matt Monson
Member#: 832
99 2.5RS, '85 911
I've got a $1000 low mileage STi shortblock available that will drop your CR to the 8's and let you run more and more relaible boost...
Old 07-08-2005, 01:35 PM   #14
G.Subramaniam
Member#: 64528
I recently upgraded to your Frankenscoobie idea
EJ25 short block + Ej22 heads for 11:1 compression
Can this take 4-5 psi boost ?
Old 07-08-2005, 01:59 PM   #15
Matt Monson
Member#: 832
99 2.5RS, '85 911
I forgot about that. That's a lot of compression to boost. Not suggested. PM me, I may be able to help you put together a longblock. I've got some core heads in addition to that shortblock.
Or, use your old Ej22 bottom end with some Ej25 heads (which I have) for 8.5:1 cr and boost it that way. But 11:1 is scary for boosting...
Old 07-08-2005, 02:05 PM   #16
G.Subramaniam
Member#: 64528
2.5L displacement and 11:1 compression will give extremely strong low end and no lag
So I am just aiming for 4-5 psi boost, not high boost
( use a very small turbo )
This way you get the best of both NA and turbo
I am thinking of adding a J&S to the minimise risk
Old 07-08-2005, 02:15 PM   #17
Matt Monson
Member#: 832
99 2.5RS, '85 911
With that kind of compression, you are going to want a stand alone EM. Detonation will come very easily on that set up without perfect tuning...
Old 07-08-2005, 02:15 PM   #18
no-coast-punk
Member#: 49087
If you were running beefy connecting rods and pistons 11:1 would be safe. But even a little bump in compression has a radical increase in combustion pressures on boosted engines.
Old 07-08-2005, 04:38 PM   #19
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I have detroyed three pistons (two motors) by running just 9.5-1 and 8 psi. But that was with a standard NA ecu.
Old 07-08-2005, 04:54 PM   #20
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
Exclamation Not a good idea!!
11:1 + boost= bad news. Your static compression ratio will be sky high! Unless you run primo fuel and have a really good tune. You will detonate.
Even 9:1 You won't notice to much of a lost of bottom end, and it will be a heck of a lot easier to tune.
John2.5RS is offline   Reply With Quote
Old 07-08-2005, 05:36 PM   #21
G.Subramaniam
Member#: 64528
What compression does STI short block + 2.2L heads give ?
9.5??
If so, would this combo give both excellent low end as well as be boost reliable ?
How much low end do I lose by going to STI short block
instead of RS short block
Old 07-08-2005, 09:27 PM   #22
Tats
Member#: 5692
WTF? YES! I am
better than you!
9.5??
MAYBE more like 8.8-9.0.
Tats is offline   Reply With Quote
Old 07-08-2005, 09:34 PM   #23
G.Subramaniam
Member#: 64528
How much low end torque would I lose by going to a CR of 9 as opposed to a CR of 10 or 11
Old 07-09-2005, 05:37 AM   #24
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
It won't make that much difference and you will have more reliable and tuner friendly motor. I would also stay with a 2.5 head preferably a sohc if you want to upgrade valves,cams etc cause it's cheaper and they flow better than the 2.2 heads.
speed_freak27 is offline   Reply With Quote
Old 07-09-2005, 11:47 AM   #25
Matt Monson
Member#: 832
99 2.5RS, '85 911
Yeah,
The STI block with your 2.2l heads will be around 9:1. And your driveability off boost will be fine. Most people don't realize that for most of the life of the 911 Porsche was running CR of between 7 and 8.5 on their non-turbo cars, and down in the 6's on the turbos. Only on the modern water cooled cars have they moved up there.
If you boost the car, you want to be hitting somewhere around 12:1 effective CR. As No-coast mentioned, if you start high, even the slightest boost give you huge gains in effective compression. Much easier to tune, and much safer to run something like 9:1 and then boost it. And if you run a small little turbo like a TD04 from a WRX, you will be getting spool up at or below 3000rpms, and have a very useful and effective power band...
Looking to go from Stage 0 to Stage 2.5...Need Expert Advice jsavage Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 08-19-2005 03:00 PM
Going from VS 1 to VS 2, how to tune MikeWRX-NJ Engine Management & Tuning 2 09-17-2003 10:33 AM
What is the conversion factor to go from Wheel HP to Crank HP? makofoto Proven Power Bragging 11 06-11-2003 03:19 AM
going from N/A to turbo.. Maybe booger Normally Aspirated with bolt-on Forced Induction Powertrain 9 07-17-2002 03:28 PM
Going from N/A to Turbo bahboy20 Normally Aspirated Powertrain 1 07-03-2001 11:46 AM
