View Poll Results: Which Front Rotors would you Purchase?
FrozenRotors (Front) Plain Non-slotted $230 per pair 9 40.91%
FrozenRotors (Front) Slotted $???? per pair 2 9.09%
RacingBrake CG Slotted Rotors (Front) $280 per pair 2 9.09%
Stoptech Slotted OEM Replacement $200 per pair 9 40.91%
Voters: 22. You may not vote on this poll
Old 07-07-2005, 05:09 PM   #1
WRXem
Member#: 35769
Default Poll Which Front Rotors? + Opinions on H6 Rear Brake Upgrade
I'm currently deciding on which Front rotors to go with. The car will be tracked at most 2 times out of the year with a couple of autox a month.
1. FrozenRotors Plain (Front) $230 per pair
2. FrozenRotors Slotted (Front) $??? per pair
3. Stoptech Slotted OEM Replacement (Front) $200 per pair
4. RacingBrake CG Slotted Rotor $280 per pair
I'm also debating whether it would be worth doing the H6 Rear Brake Upgrade. or leaving it the stock size and getting plain FrozenRotors in the rear. What are your opinions?
This will be for a 04 WRX.
WRXem is offline   Reply With Quote
Old 07-07-2005, 06:52 PM   #2
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
The bias + heat capacity + looks improvement of the "H6" is almost a no-brainer IMO.
ss
subysouth is offline   Reply With Quote
Old 07-07-2005, 09:26 PM   #3
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
ss
Yay! Got mine all ready to go on at the weekend. Stoptech lines + Bobcats all round. I'm leaving the front rotors stock until they need replacing.
PMI but what exactly are aftermarket - but stock-sized - rotors going to do for you... apart from longevity maybe?
UkNuck is offline   Reply With Quote
Old 07-07-2005, 09:27 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
#1.....and just DO the 'h6'.....no doubt.
Old 07-07-2005, 11:27 PM   #5
BIGSKYWRX
Member#: 7958
09 GH B+
Old 07-08-2005, 12:27 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
I have the dba 4000's in front and the 657's in back
Old 07-08-2005, 12:30 AM   #7
WRXem
Member#: 35769
OOhhh very much interested in these.... what are your experiencces with them?
Old 07-08-2005, 12:42 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
...the slots take a bit of getting used to....a bit of noise and vibration.....but I have beat on these brakes a great deal and they do very well, I think
not cheap, but a quality, proven, product.
Old 07-08-2005, 12:44 AM   #9
WRXem
Member#: 35769
Would upgrading the rear rotors instead of using the OEM H6 rotors be of any benefit?
Old 07-08-2005, 12:45 AM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
NO.
DO the 'h6'....the dba 657 is an 'h6' size rotor
Old 07-08-2005, 12:57 AM   #11
WRXem
Member#: 35769
I understand that they are the same size... I was just wondering would using the 657's be of any benefit compared to using the rotors that are usually packaged up with in the H6 Conversion...
Old 07-08-2005, 12:59 AM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
.....the stock rotors are pretty good.....ya don't have to buy a 'package'....just the caliper brackets and whatever rotors ya want.
Old 07-08-2005, 01:57 AM   #13
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
frozen stock rotors are the best option. And yes, you should do the H-6 upgrade in the rear. Although I'm still searching to see if I should do the '02-'04 H-6 Legacy/Outback brackets and rotors, or the '05 LGT brackets and rotors. Some say the '05 LGT are bad, some say they're better, and I am left confuddled.
eltrouble is offline   Reply With Quote
Old 07-08-2005, 07:21 AM   #14
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Because... ?
Old 07-08-2005, 09:48 AM   #15
Siper2
Member#: 1134
2007 BMW 328xi wagon
Because the cryo-treating extends the life of the rotors by a LOT.
I love the looks of the StopTech and RacingBrake rotors, especially with the black hats. Cool-looking, and won't surface rust. Their quality I'm sure is excellent, too...
I don't know, tough decision.
Siper2 is offline   Reply With Quote
Old 07-08-2005, 10:23 AM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
....you are mixing your systems......
...the '05LGT requires the entire rear LGT brakes, including the calipers.....
.....the 'h6' requires the rotors and caliper brackets only(hafta remove/bend the rear dustshields)....
Old 07-08-2005, 12:23 PM   #17
DVN428
Member#: 26226
2004 Impreza WRX
WR Blue
Is the vibration you get from the dba 4000 a common issue with all slotted or just with that model?
I'm also deciding between the Frozen Rotors nonslotted and the DBA 4000
DVN428 is offline   Reply With Quote
Old 07-08-2005, 03:59 PM   #18
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
My mistake. Is there any advantage using the '05LGT over the H-6? I was pretty deadset on purchasing the H-6, but if the '05LGTs perform better...
Because... ?
Siper said it best...cryo-treating a rotor helps to extend its life. No it doesn't increase brake performance, but for the low cost of cryo-treatment, it's definitely worth it.
And those aftermarket rotors won't do much that your stock rotors can't...they're a perfectly good set of rotors. Unless of course you want that blingety bling bling cross-drilled look for a show car...or slotted rotors to prevent glazing and to clean contaminants off of the rotors. Although solids are preferred for most people...
Old 07-08-2005, 04:31 PM   #19
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Hehe... I was yanking your chain a little... it kind of amused me how you were so definite about "the best option" and what the OP "should do [the H6 upgrade]"... but you're still deciding... I guess I need to get out more
The LGT rear setup is vented (vs solid for the H6) BTW. Personally, I can't justify it when the H6 calipers are free.
Old 07-08-2005, 04:37 PM   #20
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
I WAS definite, and then all of a sudden people started talking about '05LGTs and I was like whaa?!?!
Vented setup WOULD be nice...not sure if the larger price tag justifies that difference though.
Old 07-08-2005, 04:39 PM   #21
ndw1138
Member#: 32433
2005 STi V370
black
I'd just like to add my 2 cents. I've had brake kits ranging from 378mm brembo racing, to 330 stoptech big brake kits, stock GT3 brakes, stock wrx, stock STi, and multiple rotors/pads/lines for STi - all in the last 5 years.
Cryo treated sure does seem to increase life, by at least 30% in my opinion.
I still think slotted it the way to go, but many people including touring cars opted for none.
Stoptech makes a great product and if we're just talking rotors/hats Ion performance seems to be very good, but the one thing everyone seems to be neglecting is weight savings! I know of at least two manufactures that offer aluminum or even titanium hats. 7-11 lbs per corner is huge people.. worse weight to have sitting on the wheels. I would just sugest adding in weight to you over-all 'which is best' factor.
nathan
ndw1138 is offline   Reply With Quote
Old 07-08-2005, 04:43 PM   #22
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
Of course Stoptech makes a great product, they along with Brembos are the biggest names in braking business. But for most people, our primary concern is money!! And Stoptechs and Brembos are not cheap. Of course if I had a pure track car for a professional event, I'd definitely spring an extra bit of money into the brakes...the most important aspect about a car is its ability to stop. But for now, cryo-treated stock rotors seem to be the most cost-efficient option.
Old 07-08-2005, 05:12 PM   #23
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
The only advantage to going to the LGT 290mm vented rear is more heat capacity. The "H6" rotor is more than a match for the heat the rears will see IMO.
That being said, I have the LGT style vented rears on my car, but thats because my stock rear calipers were incompatible with the H6 upgrade. I HAD to swap the entire rear setup so I figured why not go with the 290mm vented rear. Of course this was 3 years ago and well before there was a USDM LGT to source off os. Back then we had to go to Japan and get them off BE/BH B4 and GT-Bs.
If you have an older(generally 98 or older) Subaru that doesnt have an H6 compatible rear caliper, the LGT setup would still be my choice.
ss
Old 07-08-2005, 05:15 PM   #24
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
And I chose option one of the choices. If you are considering tracking the car, the slotted rotors would be a better choice.
ss
Old 07-08-2005, 05:49 PM   #25
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
ss
Ah I see, thanks for your help. I guess I'll stick with my H-6 rotors, even with the shifted brake bias, the fronts will definitely see more heat and abuse at the tracks. But I'm planning to go larger up front with Subaru 4-pot calipers.
ss
I do intend to track the car, and only tracks...possibly rallying when the car gets old and i don't really care about the paint condition much anymore. personally I think the concept of the autoX is sinfully boring...but that's just me.
But I'm not going to go out and do some crazy 20 or 30 lap runs like some guys do. I just plan to go out..do 8-10 laps per run, pit in, do maintenance checks, bleed brakes, take a shot of Red Bull, and off I go.
Front brembo + H6 rear brake upgrade on 02 bugeye gopsu Brakes, Steering & Suspension 3 02-14-2009 05:13 PM
H6 rear brake upgrade CRAZY KEN Legacy Forum 94 08-09-2004 09:38 AM
H6 rear brake upgrade... czo79 Legacy Forum 16 05-08-2004 03:42 PM
H6 rear brake upgrade. SuperRuWRX Forester Forum 3 12-14-2003 01:01 PM
Legacy H6 Rear Brake Upgrade Question P8S-WRX Brakes, Steering & Suspension 0 04-19-2002 11:17 AM
