Old 07-07-2005, 06:59 PM   #1
Lever2ooo
Member#: 51708
**** your hippy
Default Ideal Shift Points for Best Gas Mileage
As stated above, BTW: I own a 2004 WRX with TBE
Lever2ooo is offline   Reply With Quote
Old 07-07-2005, 07:14 PM   #2
lionken07
Member#: 13660
04 WRX 5 speed
05 Impreza OBS
around 2.5k RPM if you want the best gas mileage. but I generally shift around 3k rpm when I'm not messing around.
lionken07 is offline   Reply With Quote
Old 07-07-2005, 07:17 PM   #3
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
1 to 2 is at 15 mph, 2 to 3 is at 25 mph, 3 to 4 is at 35-40 mph, 4 to 5 is at 45 mph. This is just for best gas milage. If you want more performance you'll have to rev it out a little more. But you already know that....
subydude is offline   Reply With Quote
Old 07-07-2005, 07:20 PM   #4
nate49509
Member#: 22452
2016 WRX
/\/\/\/\ You stole suby_dudes name!
All you need to know is to shift before you start boosting. Yeah, its lots of fun.
nate49509 is offline   Reply With Quote
Old 07-07-2005, 07:31 PM   #5
firecordz
Member#: 58901
sold my wrx :(
and moved to japan :)
about as low on the tach as possible while still accelerating... then, turn into a new car dealer, and buy a hybrid
firecordz is offline   Reply With Quote
Old 07-07-2005, 07:32 PM   #6
sdogg3kgt
Member#: 38397
2002 Lovemachine
Look in the manual, it's in there.
sdogg3kgt is offline   Reply With Quote
Old 07-07-2005, 08:03 PM   #7
quazimoto
Member#: 70395
Its not about rpms as much as it is keeping the car out of boost.
quazimoto is offline   Reply With Quote
Old 07-07-2005, 10:51 PM   #8
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
^^agree; it's more important not to go past half throttle. If you have a boost guage it's easy to use it as a fuel economy guage.
Mike Wevrick is offline   Reply With Quote
Old 07-07-2005, 11:50 PM   #9
-Kevlar-
Member#: 82378
1k.......
-Kevlar- is offline   Reply With Quote
Old 07-08-2005, 12:08 AM   #10
Xymox
Member#: 410
First fill-up and I think I'm just barely gonna hit 300 miles. Eeep. Missing my Honda now.
Xymox is offline   Reply With Quote
Old 07-08-2005, 01:37 AM   #11
Blarghman
Member#: 84958
My WRX surprised the crap out of me the other day....I just broke her in and i was averaging about 22 mpg city and fwy. I just drove from LA to Denver and on one tank i got 29.5 miles per gallon averaging about 82 mph!
Blarghman is offline   Reply With Quote
Old 07-08-2005, 01:40 AM   #12
WarHawk187
Member#: 58518
04 WRX
Isnt it also bad to shift too low and lug the engine, thus causing it to use more gas to keep it running?
WarHawk187 is offline   Reply With Quote
Old 07-08-2005, 01:40 AM   #13
Jesse00
Member#: 78036
02 Impreza 2.5TS
Midnight Blue
this gives me an idea... can you mod your wrx's so you can take out the turbo... so that you will turn into an ordinary 2.0L engine... then your fuel economy will definitely increase.
Jesse00 is offline   Reply With Quote
Old 07-08-2005, 01:56 AM   #14
Blarghman
Member#: 84958
Lugging sucks for your car....I used to do it in my celica and p5s and after a while i could totally feel it in the clutch. The tranny started to soun dlike it was about to fall about too. Im being more careful to not like the WRX, which usually means not letting it go below about 1800 or so RPM.
Old 07-08-2005, 02:43 AM   #15
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
lugging the engine does a LOT more harm than simply using gas.
Some say lugging your motor is worse than redlining it...and that is quite bad. Just learn to shift through the gears to keep your rpms above 1.5k, it's pretty easy to lug the motor on our low displacement engines.
eltrouble is offline   Reply With Quote
Old 07-08-2005, 02:46 AM   #16
Newest
Member#: 88949
ok so if around 2.5-3k rpms is good to upshift. what about downshift, 1800?
considering i want to save fuel and not ruin any part of the car.
Newest is offline   Reply With Quote
Old 07-08-2005, 03:07 AM   #17
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
Check your manual, they tell you which gear you should be in for a certain speed range. They know the best way to conserve fuel.
Old 07-08-2005, 03:33 AM   #18
sonicsuby
Member#: 34162
2005 WRX wgn, 01 RS
White, White
before the turbo spools
sonicsuby is offline   Reply With Quote
Old 07-08-2005, 10:02 AM   #19
Mike Wevrick
Member#: 24654
1957 Taggart Comet
If you are slowing down for a speed zone, 1800 is OK to downshift. The correct RPM depends a lot on what you are doing, though. If you are accelerating or climbing a hill you need higher RPM.
Old 07-08-2005, 11:36 AM   #20
REX8
Member#: 24038
I do the 4-5 at anything over 40...
Ideal shift point. 1 Stock Rex General Community 15 04-08-2006 04:57 PM
16" tire and size for best gas mileage? ten80 Tire & Wheel 8 04-11-2004 10:50 PM
ideal shift points gypsymoth Transmission (AT/MT) & Driveline 38 07-16-2003 02:26 AM
Ideal shift points for 97-99 Legacy GT's 2.5GT Legacy Forum 5 06-07-2001 05:33 PM
('93-'01) What are the optimal shift points for saving gas? myko011 Impreza Forum 4 05-17-2001 01:36 AM
