Old 07-07-2005, 08:47 PM   #1
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Default The Infamous Plug wires popping off
Ever since i got my car the plug wires have been popping off. The day i got it i found 2 of them just sitting in there not fully connected. I did a search and found this to be a problem with alot of the magnecor wires. Well i went out and looked to see what kind of wires i had. They are blue NGK wires. I can't find anything bad about these wires on here. Is it possible that i am experiencing the same as the magnacor's. That the spark plug isn't long enough for these wires??
Heres the old magnecor thread
http://forums.nasioc.com/forums/show...park+plug+wire
plug wires ain't cheap...but i should probably get them replaced anyway as it is quite annoying
Old 07-08-2005, 03:38 AM   #2
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
Go with the stock plug wires. You can get them for about 30 dollars. Nothing is better than stock when it comes to plug wires. Nothing! Why pay a lot of money for something that doesn't do a thing for your car, except cause problems. Stock ones were designed for your car and will work flawlessly. Just my opinion though.
X4 SRT is offline   Reply With Quote
Old 07-08-2005, 10:59 AM   #3
Slack
Member#: 17548
Stock plug wires. I made the mistake of buying magnecor wires and they ended up going bad on me (and popping off randomly).
Mick
Slack is offline   Reply With Quote
Old 07-08-2005, 11:29 AM   #4
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
I think there's a how-to on how to keep them from popping off here or on scoobymods.com
do some searching . you'll find it.
iamrazor is offline   Reply With Quote
Old 07-08-2005, 11:32 AM   #5
DreddRS25
Member#: 51642
2008 WRX
OEM plug wires are like $30 from a dealer, maybe, $40.
DreddRS25 is offline   Reply With Quote
Old 07-08-2005, 12:08 PM   #6
Master2192
Member#: 83254
98 2.5 RS
04 WRX
I think i'll go with the OEM wires, they sound alot cheaper too...
The main thing is these wires came on the car when i got it
Old 07-08-2005, 12:11 PM   #7
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Mick
Well, they have a lifetime warranty and the pop-off problem has been solved......
rob is offline   Reply With Quote
Old 07-10-2005, 09:33 PM   #8
DragonRM
Member#: 14365
Heard it's usually not the plug wires but the plugs themselves not being the right size... there's a fix thread somewhere... I know there's some recent activity on rs25.com on a thread about the fix.
DragonRM is offline   Reply With Quote
Old 07-11-2005, 10:29 AM   #9
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
I had the same issue with Bosch wires as well. They tended to get loose and burn up where they connect to the coils (the coils that have the output that looks like the top of a spark plug).
Stock wires seem to be the least hassle for any model year Suby.
Old 07-11-2005, 03:49 PM   #10
DragonRM
Member#: 14365
Could always just paint the wires the color you want
Old 07-12-2005, 12:27 AM   #11
prescottsti
Member#: 84902
04 Chevy Silverado
Duramax Diesel 500Hp
My dad had a 98 RS that he put Ngk's on and they popped off too. Although I highly recomend Ngk wires, stockers are the only ones that seem to stay on phase I EJ25's
prescottsti is offline   Reply With Quote
The final solution to Magnecor wires popping off rob Normally Aspirated Powertrain 14 03-14-2005 01:56 AM
Spark plug wires popping off Machine Age Victim Normally Aspirated Powertrain 14 10-01-2003 02:08 PM
Could it be the spark plug wires? SubaruImpreza_power Forester Forum 0 06-03-2003 01:26 PM
('93-'01) Are the spark plug wires the same for the Impreza 1999 to 2001 2.5rsMI Impreza Forum 0 06-11-2001 06:15 PM
Did the headunit plug wiring change between '97 and now? dvancleve Car Audio, Video & Security 4 06-04-2001 05:32 PM
