Old 07-07-2005, 11:21 PM   #1
slingshot
Member#: 44668
'07 M5
Default STi Front Diff-filled fluid, diff slipping?
I checked my front diff fluid level, it was below the low line.
So I added just under a quart of 90-weight, as per the manual.
Now the car doesn't seem to pull as hard out of corners.
For example, when I gun it out of my complex parking lot (left turn onto a 4-lane street) the car normally wants throw me out of the seat.
Now it feels softer. It almost feels like the clutch is slipping, but it's not.
Is the center diff fluid supposed to be low? Or did I just overfill it?
slingshot is offline   Reply With Quote
Old 07-08-2005, 12:21 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
.....and what
90-weight
did you use???
Old 07-08-2005, 10:07 PM   #3
slingshot
Member#: 44668
'07 M5
API GL-5 80w90. That's what the owner's manual said to put in it.
I'm assuming the previous owner had regular gear oil in it. Maybe I should give him a call and make sure.
Old 07-08-2005, 11:25 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
What brand????and what particular type of oil??????
Old 07-09-2005, 12:41 AM   #5
slingshot
Member#: 44668
'07 M5
Not sure what brand. It's at work, I'll look at it tomorrow.
It's non-synthetic API GL-5 80w90 hypoid limited slip gear oil.
The manual didn't mention any additive, and I figured since the front diff had a dipstick, it's probably sealed off from the rest of the trans fluid.
Old 07-09-2005, 06:43 AM   #6
turbo2ner
Member#: 89385
many most all
WRB/blk/blk/blk/slvr/wht
You can't chnge the center diff fluid. The tranny fluid sound good to me. You are just crazy, I doubt adding a little gear lube will slow down car.
turbo2ner is offline   Reply With Quote
Old 07-09-2005, 06:45 AM   #7
turbo2ner
Member#: 89385
many most all
What type of front diffs do the 04 STi have? Viscous? If thats the case, you don't need the limited slip additives.,
Old 07-09-2005, 08:37 AM   #8
slingshot
Member#: 44668
'07 M5
I meant front diff.
Maybe it's just my imagination.
No, it's a suretrac diff...gearless mechanical limited slip. But the book didn't mention any additive.
Old 07-09-2005, 10:13 PM   #9
tcam33
Member#: 54515
05 WRX STi
WR Blue
The front diff and trans share the same oil. I believe the recommended weight is 75w90 GL-5 for all temp conditions
tcam33 is offline   Reply With Quote
STi rear diff fill plug (with thermostat electrical connector) nhluhr Private 'Wanted' Classifieds 0 03-23-2007 04:07 PM
Front Diff/Tranny fluid leak... Mohaj Transmission (AT/MT) & Driveline 0 06-24-2006 03:45 AM
Rear Diff. Fill plug STI AVANTI R5 Service & Maintenance 4 05-13-2006 01:02 PM
Any body know how much fluid goes into a Sti 6spd tranny and rear diff. underground-mpyre Service & Maintenance 1 07-10-2003 03:05 PM
Brake Fluid/Steering Fluid/Diff. Fluid/Transmission Fluid Jasno999 Brakes, Steering & Suspension 11 09-27-2002 11:22 AM
