Mid Atlantic Impreza Club
Old 07-08-2005, 09:08 AM   #1
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
Default My car just died on me, ***?
I was driving along on rt 28, normal, no problems... and the car just quits. I actually didn't notice until I tried to accelerate again and couldn't. Pull over, and try to start it again, no dice.
Every time I try to start it, I put the key in "accessory mode" or whatever, to let the fuel pump prime, because that's what I always do. Whenever I did this, it didn't work, nothing would happen.
So I pulled the key out, tried again, but just turned it all the way in one shot, and the car fired up, but not very willingly.
Fast forward to this morning and I started the car normally (wait for the fuel pump) and the car started, but, again, not willingly.
Oh also, if I put it in "accessory mode" I get the battery light, the oil light, and the CEL. Don't remember if that's normal, but my oil is topped off.
What could be the cause?
-Ben
Capt Crunch is offline   Reply With Quote
Old 07-08-2005, 09:14 AM   #2
MidnightSti05
Member#: 74064
Water?
MidnightSti05 is offline   Reply With Quote
Old 07-08-2005, 09:14 AM   #3
D_Block
Member#: 64127
2001 PY ITR, 2012 X5
on order
-Ben
That is normal.
Bad alternator? Wish I was more help.
D
D_Block is offline   Reply With Quote
Old 07-08-2005, 09:18 AM   #4
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
By “not very willingly” do you mean it cranks and cranks then eventually fires and starts?
Could be a fuel delivery issue. Possibly as simple as fuel filter?
xcntrk75 is offline   Reply With Quote
Old 07-08-2005, 09:27 AM   #5
WRX11
Member#: 26638
May want to check your battery if it's still the same one that came with the car. Mine died in 3 years. Did you ever replace the fuel filter just in case that's clugged? Bad plugs? Bad gas should only run rough.
WRX11 is offline   Reply With Quote
Old 07-08-2005, 09:31 AM   #6
Capt Crunch
Member#: 10852
could be the fuel filter... I haven't replaced the battery, I think I'm gonna run over to Mach V and get a redtop
Old 07-08-2005, 09:38 AM   #7
WRX11
Member#: 26638
Red top was what I was going to do but I needed one fast so got a Sears Die hard.
If you have a volt meter, take the battery cables off and measure the voltage. If it's below 24 volt, it's not a good sign. Put the cables back on and turn on the car and measure it again to see if the voltage rises, if it does, I am pretty sure your alternator is ok.
Make sure to follow the suggestion/procedure for changing the fuel filter, wouldn't want you to get gasoline in your eyes and paint.
Old 07-08-2005, 09:43 AM   #8
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
check fuse, pump shouldnt be bad, filter shouldnt cause a problem to occur "all of the sudden", batter/alternator possibility.
or even the electrical connections, maybe a nut/bolt that supplied the power is a bit loose, tight enough to let it work however maybe over bumps it lodges itself in an unoptimal way.
psyber_0ptix is offline   Reply With Quote
Old 07-08-2005, 10:05 AM   #9
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I forget if you're pushing any kind of stereo equipment, but I'd go for a yellow top over the red.
-- Dave
AcquaCow is offline   Reply With Quote
Old 07-08-2005, 10:17 AM   #10
ydant
Member#: 43447
2009 STI
The Good Grey
24 volt?
ydant is offline   Reply With Quote
Old 07-08-2005, 10:22 AM   #11
N/A
Member#: 133
TBA TBA
TBA
Take the battery to an Advance and have them do a load test to it. If the battery is getting drained then its not the battery as the car should still run after starting assuming the alternator is charging all the way. If you can get the car or the alternator to Advance then let them test the alternator for you to see if it is bad. If both are good then start with check your fuel pressure and spark to see if one of those is the problem. No sense in buying an Optima for no reason when there are other batteries out there that offer more CCA and CA then an Optima. The only reason to get an Optima would be serious stereo use or if you need to mount it in the trunk of your car and need a sealed battery. The Optima might be pretty and the In thing to have but it doesn't mean its a better battery.
N/A is offline   Reply With Quote
Old 07-08-2005, 10:22 AM   #12
Jared703
Member#: 17030
my battery died in more like 2.75 years. It was not wanting to start easy for a while, and I put off getting a getting a new battery for a few weeks. I just got back from a week in Florida and the car was dead. Got a new one and all is well. I'd look into the battery.
Jared
Jared703 is offline   Reply With Quote
Old 07-08-2005, 10:36 AM   #13
sabreofsd
Member#: 48943
2004 95%*STi Blu/Gld
www.dcawd.com
-- Dave
I have the yellow top and couldn't be happier. I bought it for around 130$ shiiped IIRC. I can look up the exact amount and where if you want.
sabreofsd is offline   Reply With Quote
Old 07-08-2005, 10:40 AM   #14
AaronWRX
Member#: 7194
2011 997.2 Turbo
^^^ best advice. Get you battery and charging system tested before doing anything. advanced auto, autozone, etc will do this free. Also, check costco for optima batteries if you want the best price. I saw them there 1 month ago. (but you know how costco is.. they dont stock the same items all the time)
AaronWRX is offline   Reply With Quote
Old 07-08-2005, 10:41 AM   #15
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Indeed.
I destroyed my stock battery, stock alternator and then a DieHard battery with my stereo.
The yellow top doesn't seem to mind.
-- Dave
Old 07-08-2005, 11:02 AM   #16
WRX11
Member#: 26638
Originally Posted by ydant
24 volt?
haha 12volt. I am troubleshooting a system at work and mixed it with his car battery. Thanks.
Old 07-08-2005, 11:05 AM   #17
WRX11
Member#: 26638
most times yes but maybe only my dealing with charge system test was bad. One guy insisted that I need a new alternator, etc or even with the new battery, my car will die somewhere on the side of the road soon. I bought the new battery and never had any issues after that.
Old 07-08-2005, 11:13 AM   #18
N/A
Member#: 133
TBA TBA
TBA
In order for that to happen you have to have a battery that is completely dead as in a bad cell and not just one that is slowly going dead. That means there has to be signs ahead of time to warn you of it. A totally dead battery on a modern car will make it die but that only happens if there is absolutely zero voltage being put out. Just like the old cars would continue to run if you disconnected the battery (redneck alternator test) but a modern car will die if you disconnect the battery. This could also be a bad fuseable link or battery cable causing the same symptoms.
Old 07-08-2005, 11:52 AM   #19
Capt Crunch
Member#: 10852
replaced the battery, car starts consistently now, but it still starts up a little lumpy...
Old 07-08-2005, 01:05 PM   #20
WRX11
Member#: 26638
I woudl check the charging system previously mentioned. So if it is a bad connection or bad alternator, it wouldn't kill your new battery. I would keep a set of jumper cables in the car just in case.
2.0 Just died on me. drewwrxrogers Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 08-21-2007 05:48 PM
car just died on me this morning MadDogSTi Service & Maintenance 10 11-16-2006 06:24 PM
Huh...the crowbarn just died on me Charge Off-Topic 4 06-16-2005 01:12 AM
Help! My car just died! Dougeefresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-08-2002 02:35 AM
Ok, my car keeps dying on me...what's up? Sauginius Southern California Impreza Club Forum -- SCIC 6 11-07-2000 12:01 AM
