Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 07-08-2005, 01:35 PM   #1
bdcz2
Member#: 39790
2004 WRX Sti
Default Calling all engineers, aerodynamicists, gear heads, and know it alls
Ok- you can make this question as complicated or simple as possible, some will decide to immediately flame me for posting a gas related question (I bought a sports car yada yada) and some people will actually offer an answer...
Is there a single speed that, taking into account aerodynamics, engine rpms, and turbo use, will give you the best possible highway mileage...
In other words, if I wanted to go as far as I could on cruise control, where would I set it?
bdcz2 is offline   Reply With Quote
Old 07-08-2005, 01:38 PM   #2
fireball_jones
Member#: 67536
00 AW GM6
And a bunch of parts
Lowest possible speed in your highest possible gear.
fireball_jones is offline   Reply With Quote
Old 07-08-2005, 01:39 PM   #3
Rokkit
Member#: 84181
NASA #530 GTS2
im not an engineer but i can give you my 2 cents...
I think its all relitive as being in the right gear at the right time + Throttle position.... higher the RPM the more fuel the car uses at a set throtle position...
So... low rpm + low throttle = low gas useage... but that = idle lol
I would say speed limit, without cruse control (it over/under compensates ) and go easy on the throttle... DONT BOOST
hah
Rokkit is offline   Reply With Quote
Old 07-08-2005, 01:45 PM   #4
Roy Dietsch
Member#: 88479
91 Mazda Miata
blue yellow
throttle position plays a big role...you can get some crazy lean a/fs while just crusing at low throttle...I would assume something like 40MPH in 5th or 6th
Roy
Roy Dietsch is offline   Reply With Quote
Old 07-08-2005, 01:51 PM   #5
Remnex
Member#: 83790
I actually know the perfect answer to this question, however you may not like the answer.
A good friend of mine told me shortly after I purchased my WRX and started complaining about the gas mileage, that if I couldn't afford to put gas in the gas, I shouldn't have bought it. Period.
You knew this when you bought the car. You stood there with the sticker right in your face. you bought a performance car and you're going to get performance car mileage. Deal with it, or trade it in.
Remnex is offline   Reply With Quote
Old 07-08-2005, 01:58 PM   #6
Prod
RIP
Member#: 59328
1967 M35A2
duh, winning
Winner.
Throttle makes a huge difference, but this would be a general answer. Basically apply minimum throttle in 5th or 6th, and coast down hills as much as possible.
Prod is offline   Reply With Quote
Old 07-08-2005, 02:02 PM   #7
cstratton04
Member#: 84489
2005 Toyota Corolla
2005 CBR600rr
It should say in your manual the best speed for gas mileage... i think it is 55 mph as it is the best rpm range (low, but not too low) in your highest gear and air resistance isn't too high.
Renmex - you answer wasn't really helpfull. I knew the gas mileage of the car when i bought it, but i still enjoy getting the best mpg i can when not driving hard.
cstratton04 is offline   Reply With Quote
Old 07-08-2005, 02:11 PM   #8
hyperlitenerd
Member#: 86504
1994 Rx-7
Green
there is a episode in top gear (british car show) the guy goes 800 miles in a desiel audi, in short he says take as much stuff that you do not need out of the car, dead bodies, chairs on the roof, etc. If you see a hill comming, gain speed before it, and coast up it, never brake, use no electronics, no ac no heater, nothing. Keep the car in the highest gear possible at the loswet acceptable speed, aka slow lane. you just think really hard about driving slow.
hyperlitenerd is offline   Reply With Quote
Old 07-08-2005, 02:23 PM   #9
cefoskey
Member#: 83961
2014 A5 S-Line 6MT
'06 Triumph D675
1.) Take the box kite wing off the STI.
2.) Stay out of boost
3.) Get up to speed slowly and drive in a gear higher than you usually would at the same speed.
But really, you're not going to change your driving behavior enough to really affect the overall mileage.
cefoskey is offline   Reply With Quote
Old 07-08-2005, 02:27 PM   #10
WRXXXual
Member#: 67784
Now with 100% more
STI short block!
^^^that, or:
You could always just push your car around
WRXXXual is offline   Reply With Quote
Old 07-08-2005, 02:43 PM   #11
BlackfeetVI
Member#: 40567
RIP Worcester 6
St Florian protect us all
Just get the JDM mad tyte pedal car conversion
On a side note, I got 29.5mpg crusing at 75 from Minneapolis to Milwaukee, and I think if I'd have taken it down to 70 or so it'd have gone up another mile or so per gallon. I don't think it'll get too much better, I'll take the higher cruise speed and trade off a little economy.
BlackfeetVI is offline   Reply With Quote
Old 07-08-2005, 03:05 PM   #12
kilroy
Member#: 75628
2005 Legacy GT ltd
regal blue
I would have to say the gentlest rate of acceleration while staying out of boost will give you the best mileage. I tried this for a painful and nerve-wracking tank of gas in my legacyGT while watching the instanteneous mpg display. When decelerating, my mpg shot way up and just inching up on the gas while accelerating kept the fluctuation in mpg fairly moderate. I averaged 25.6mpg for the entire tank of gas. I am usually around 20-21mpg. I won't do it again though - I did not buy the car to putter around.
kilroy is offline   Reply With Quote
Old 07-08-2005, 03:13 PM   #13
nate.the.great
Member#: 72031
lol, he never complained about the gas usage. he just asked for what speed he should set the cruise on in order to get maximum mpg. please read before you post.
nate.the.great is offline   Reply With Quote
Old 07-08-2005, 03:14 PM   #14
infantsam
Member#: 51280
2015 WRB WRX
KNSBrakes
The most efficient driving speed is about 40-45 MPH. This is the point where the exponentially growing aerodynamic drag begins to require much larger power to overcome and thus hurting fuel economy. Tire inflation, alignment settings, and most importantly driving style will affect your ultimate mileage but the maximum efficiency is not too hard to calculate. Since you can't drive 45 everywhere you go then increasing your driving efficiency i sa good way to save gas. 65 vs 75 will make a difference - accelerating smoothly and coasting to a stop instead of running up and slamming the brakes will also help. Tire inflation as mentioned can cost as much as 10 percent. Rid your trunk of any cast iron that is just bouncing around also.
With only a small amount of attention I'd think that most drivers could save at least 10 percent - maybe more if you are a tailgating, on the gas, on the brake, always hitting it at the stop light kind of driver.
infantsam is offline   Reply With Quote
Old 07-08-2005, 03:38 PM   #15
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
I believe the mileage ratings on the sticker are averaged at 62 or 65 mph in the highest gear.
Car vs. Driver is offline   Reply With Quote
Old 07-08-2005, 03:49 PM   #16
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Yes, I believe it is torque peak in your highest gear. Try some aerodynamic mods if you want to get it even higher (read: less drag/downforce).
Old 07-08-2005, 03:51 PM   #17
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
Everything you wanted to know:
http://www.fueleconomy.gov/feg/drive.shtml
And I was wrong about the speed in my post above according to this link
Old 07-08-2005, 04:15 PM   #18
infantsam
Member#: 51280
2015 WRB WRX
KNSBrakes
That info is a little 'watered down' - The efficiency curve looks awfully suspicious as it shows peak at 55 - 60 - the most common speed limit.
Peak engine torque is not necessarily peak efficiency - iirc the EJ20 has to run pretty darn rich to put out that high torque number so while it's making more torque/power it is not necessarily at peak efficiency. How much fuel do you ahve to dump to get that torque? Also, the peak efficiency of the engine alone is not enough - it's the whole car we are concerned with.
What you are trying to optimize is:
Maximize the distance travelled
Minimize the drag - both parasitic and drag related
Keep the engine speed in it's efficient range
Old 07-08-2005, 04:23 PM   #19
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Sorry, I was talking about an NA vehicle... if you've got an STI, you should be loaded enough not to worry about fuel effeciency.
Old 07-08-2005, 04:29 PM   #20
infantsam
Member#: 51280
2015 WRB WRX
KNSBrakes
If I had an STi I'd only complain about all the fun I was having.....
Old 07-08-2005, 04:37 PM   #21
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
Or you'd be complaining that everyone and their mother thinks you want to race them. Soccer moms seem to be the worst offenders in their SUV's and mini vans.
Old 07-08-2005, 04:56 PM   #22
infantsam
Member#: 51280
2015 WRB WRX
KNSBrakes
ugh - you said Stupid Useless Vehicle and brought up my favorite subject
I am particularly unhappy when I have door dings 'above' the door handle because you know who did that to you
Old 07-08-2005, 05:11 PM   #23
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
That reminds me of something that happened to me a number a years ago when I was much more likely to freak out on someone ...
I parked my car in a lot and was about to get out when I noticed the woman next to me (in the passenger side) was waiting to get out. So, being a gentlemen, I motioned her to go aheand and get out of her car before I got out of mine.
Well, at that point, she flings the door open and it slams into the side of my car. Instantly, I was pissed. But, what pissed me off even more is that she started to walk away like nothing had happened. So, I jumped out of my car and was basically said "w-t-f?" (Really, I just wanted an apology). And her reply, "What do you expect? You're in a parking lot." and walks away.
I'll not get into what went down AFTER they went into the store ... but it just goes to show that people basically suck.
/hijack
Old 07-08-2005, 05:19 PM   #24
infantsam
Member#: 51280
2015 WRB WRX
KNSBrakes
oh please stop sucking me in to the hijack
I wouldn't have let that vehicle travel out of the lot without some sort of maintanence - nothing too costly but enough to get my point across...like air out of 2 tires, loosen gas cap if its an OBD 2 vehicle without a locking door - ya know ...fun stuff like that..
Old 07-08-2005, 05:20 PM   #25
Prod
RIP
Member#: 59328
1967 M35A2
duh, winning
I did the same exact thing in my LGT, and came to the same conclusion. I'll pay for 20 mpg vs 25 for the fun factor.
Ok, I just pulled a muscle in my brain. OT astrophysicists and know-it-alls, hear me! Asinine Off-Topic 91 04-29-2009 09:54 PM
calling all electrical know-it-alls... USB charging question WRXVT Off-Topic 8 04-07-2008 05:41 PM
calling all know-it-alls gf8rallywagon Normally Aspirated Powertrain 8 12-17-2005 07:43 PM
Question for the server-class hardware know-it-alls Bottom Feeder Off-Topic 7 05-16-2005 09:16 AM
Question for the OT credit rating know-it-alls Corn-Picker Off-Topic 3 05-31-2004 11:44 AM
