#26 |
Member#: 84489
NWIC
Vehicle:2005 Toyota Corolla 2005 CBR600rr |
My initial, un-thought-through reaction would be to whip out my key and return the favor....... but that would only be gratifying untill i get the police called on me. what should you do in that situation?
#27 |
Member#: 81620
Vehicle:2004 350Z 406WHP/350WTQ |
Get creative.
#28 |
Member#: 30733
TXIC
Vehicle:2007 tiny car striped |
Theoretically it is a hard question to answer. Most engines are actually quite inefficent at low throttle settings. This is one of the main limitations of a gasoline engine and why a dodge viper cruising along at 55 mph would take alote more gas than a similar car with a smaller engine cruising at the same speed. They are both putting the same power to the ground but the bigger engine is less thermally efficent due to pumping losses. Most other losses increase with speed: aerodynamic, friction, etc. You really need to test a specific vehicle to know what the efficency vs speed curve would look like. "an accurate measurement is worht 1000 expert opinions".
#29 |
Member#: 51280
South East
Vehicle:06 VF-39 is good |
I hear that - but look at the 25% increase in MPG you get from 'nerve -wracking' attention (thats huge btw). So just do the little things some of the time - like every stop light is not a 0-60 test , you don't have to be in front of everyone all the time, use the AC after you cooled the car w/ the windows down for a mile or so - that kind of thing and you can save some pretty big bucks
If you average 1000 miles a month and go from 20 to 22 mpg (10% increase) you would save about $12/month. Not huge but essentially free money.. Cut 100 miles out of your monthly average by saving a few trips here and there and you'll save another $50/month. The average car costs about $.50/mile to operate. I try to make them worth it. |
#30 | |
Member#: 51280
South East
The courts never like people who try to take the law into their own hands - But hey it's easy to trip and fall over an anthill and drop your sledgehammer on the windshield of a nearby vehicle ![]() |
#31 |
Member#: 84489
NWIC
so it would be a good idea to call the police even if it is just a dent? would the cops just laugh at you and tell you to stop wasting their time?
#32 | |
Member#: 58773
NESIC
#33 |
Member#: 51280
South East
If I had a DENT and saw who did it I would definitely call the cops - I'm sure there is a way to force someone to do something and get the name of their insurance company or something. I'm pretty sure the law says that you can't just go around effing peoples stuff up and then play dumb.
#34 | |
Member#: 39790
NESIC
Vehicle:2004 WRX Sti Blue |
If you guys still want to criticize me, go ahead. I do wonder how long it will take for you to change your mind, perhaps when gas hits $3, $4, or maybe $5 dollars a gallon. Will you still be so critical of trying to save a buck or two??? Thanks to everyone for the answers so far |
#35 |
Member#: 18941
NWIC
Vehicle:2005 Lotus Elise Orange |
There absolutely will be some optimal speed where you are travelling the fastest, loading the engine the least. As far as aerodynamics go (I have extensive education in aerodynamics) the best speed is standing still (duh). So basically the best speed is the slowest speed thats....uh...... I've lost my point.
Best gas mileage is going to be highest gear at highway speeds with the engine revving at a normal range. Drag will be high, but theres nothing you can do about that. |
#36 |
Member#: 50221
Vehicle:I'm on internets Racin on ur bandwidth! |
One of my buddies took a '91 civic hatch, did some light modding and engine management (all geared towards fuel economy, not speed), a wind-tunnel-proven aero kit.. and a peice of thin sheet metal covering his entire underbody. He sealed up every single hole/crack except for intake/radiator (both had funnels so that no air could get inside the "bubble").
this combo netted him 80 mpg on a gasoline civic ![]() |
#37 | |
Member#: 67536
NESIC
Vehicle:00 AW GM6 And a bunch of parts |
I can't believe this conversation has gone on so long about gas mileage. You're best mileage comes when you've overcome most rolling resistance and are experiencing the least amount of wind drag. That's about 50 mph, or for almost every road going car, the very bottom end of their top gear. I believe this was actually covered in an issue of that Subaru "informational" magazine owners get recently Although one thing I did notice is that cruise control usually nets me a good 1-2 mpg better than the same speed if I use my foot for the throttle. I guess I vary the pressure more than I realize, but it's good to know since there isn't a highway in CT people do 55 mph on. |
#38 |
Member#: 81620
Yeah, if 55 is optimal, I'm screwed. THe road I take to work is at least 80 in the slow lane or you'll be run off the road and killed.
#39 |
Member#: 16272
NESIC
Vehicle:2004 WRX Wagon WRB |
I read somewhere that 55mph is the best speed. This is part of the reason why that was the speed limit on the highways. Also if you were worried about gas the WRX is not a good choice. It is not aerodynamic overall not to mention that big thing sticking out of the hood probably doesnt help things at all.
#40 | |
Member#: 84489
NWIC
![]() Yeah im a smartass |
#41 |
Member#: 46135
Vehicle:02 WRX Powered by Sti V9 Spec C |
There is stuff you can do to save gas:
-never decelerate (unless there's ice and you have to), always bring it to neutral and coast down, if there's not much traffic around you. The same if you're crawling in stop and go, try to avoid to accelerate and slam on the brakes. There is a disadvantage in doing an emergency stop while the gearbox is in neutral however. -staying at the top of the torque curve gets you a bit lower gas mileage than just under-revving a bit. But the savings are more consistent between various traffic situations (town-interstate mix) The climbing into the torque curve should be done by feathering the gas pedal. The torque curve that I speak of is not the maximum torque curve. For a turbo car there should be 2 types of curves. The on-boost curve, with the factory quoted max torque, then lower curves for less than floored accelerator and an off boost, where you open the trottle without putting load on the engine and stay N/A. What this means is when in light traffic on the parkway, use a gear so that you're just under max torque quoted RPM. When a hill comes up, let the car slow a bit, or use extra speed acquired from the previous downhill. -Dont put cruise on, A/C on or open windows, use the fan -Check tire pressures and slightly over-inflate maybe 1-2 PSI. In Europe, where you usually read gas mileage on every brochure distributed for any car, they give an in-town value, Out-of-town value and a mixed situation. The out-of-town value was usually quoted for 80-90 Km/h. I remember many friends and neighbours testing what was best, for gas mileage, with all different small displacement engines (including boxers) and they all confirmed 80-90. Something like a 2.5 used to be considered a bit on the larger side and might not exactly fit. But I would doubt it differs by more than 5-10 Km/h, therefore 6 MPH. I say it's probably 60 MPH for an Sti. Vlad |
#42 |
Member#: 87950
Vehicle:2005 STI Gone....Somewhere in MS |
Since the cruise control won't engage until the vehicle speed reaches 25 mph anything under that is ruled out. The faster you go the more resistance in everything, tires, wind, engine friction, transmission friction, etc. The more resistance, the less mpg. So I suggest 25 mph in the lowest numerical gear ratio the engine will smoothly move the car. Lugging along with the engine struggling to keep up a 25 mph speed probably isn't as good as a gear where the engine can move the car steadily and w/out extreme effort.
Just stick me in the gear head, know it all section, my wife does. hwy61 |
#43 | |
Member#: 4429
E. Canada
Vehicle:2006 9-3 SC Aero |
#44 | |
Member#: 24038
South East
#45 | |
Member#: 24038
South East
#46 | |
Member#: 46135
Let's consider a normally aspirated car for a minute. A lot of times, the increased momentary fuel consumption is associated with Lower (deeper) vacuum. If you look at the vacuum gauge that some normally aspirated cars have, when you suddainly floor it, the vacuum will really go deep. That's how theose "economy" gauges some cars have are hooked up too. My point is that one of the deepest vaccums is when you use the engine to decelerate. Even with a turbo car, the same applies. It will not be as bad of a consumption as in wot but right up there. As far as consumption in idle, that's actually the minimum consumption. With carbureted cars there used to be a separate jet, just for idle. The main emulsion tubes used for normal driving are not even in the same category size wise. |
#47 | |
Member#: 71191
Vehicle:2005 WRX Wagon Platinum Silver Metallic |
Mark |
#48 | |
Member#: 84489
NWIC
They should show that in driver's ed as what not to do. |
#49 |
Member#: 66580
65mph in top gear.
#50 | |
Member#: 38397
Vehicle:2002 Lovemachine Silver |
| Thread Tools | |
| Display Modes | |
| Ok, I just pulled a muscle in my brain. OT astrophysicists and know-it-alls, hear me! | Asinine | Off-Topic | 91 | 04-29-2009 08:54 PM |
| calling all electrical know-it-alls... USB charging question | WRXVT | Off-Topic | 8 | 04-07-2008 04:41 PM |
| calling all know-it-alls | gf8rallywagon | Normally Aspirated Powertrain | 8 | 12-17-2005 06:43 PM |
| Question for the server-class hardware know-it-alls | Bottom Feeder | Off-Topic | 7 | 05-16-2005 08:16 AM |
| Question for the OT credit rating know-it-alls | Corn-Picker | Off-Topic | 3 | 05-31-2004 10:44 AM |
