![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 56758
Vehicle:04 04 WRX - WRB 03 LLBean Outback - Green |
Hi I just got a set of tires/rims mounted (Fuzion ZRi 225/45R17 / Rota Torques) and the wheel shop said that they mounted fine - but the installer said that he used to have a Montero and Eagle Talon and thought that the wheel tape might not work as well as hammer on weights.
He offered for me to come back to have the hammer on weights if I had a vibration problem... Anyone know if he's talking smack or any advice?
#2 |
Member#: 43853
NESIC
Vehicle:2004 WRX Sedan Stg 2 Platinum Silver |
the stick on weights work just fine. you can also have them put the hammer on weights on the inside of the rim, but certainly there should be none on the outside.
#3 |
Member#: 7922
Vehicle:04 CTS-V b/b/b 99 GMC Highrider |
Your installer isn't smart. AWD has nothing to do with how a wheel balances. I always request stick on weights.
#4 |
Member#: 28716
SCIC
Vehicle:2006 STI |
It's true, clip-on weights balance better since they're at the farthest points of the rim, but I suggest you take that little hammer and strike his forehead if he gets near your rims with it.
Like it's been mentioned, stick-on weights work just fine and even a lot of OEM wheels require them. I've seen some new Hondas with 3 oz (12 squares) of stick-on weights on the outer section...maybe some of those wheels have air pockets in the casting. ![]() |
#5 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
....I've ballanced a few wheels and as long as the inside of the wheel is cleaned well before putting the weight on, they will work and stick well.....and wheel design has some impact on the ballance as posted above----the farther apart the weights can be, inside and outside, the better....
....but the assclowns that insist that the weights can't be seen from the outside are the real winn4rs ![]() |
#6 |
Member#: 56758
Thanks for the input guys....
However, is there any recomendation on what to do if I get a bad vibration over 30mph like he was talking about. Unfortunately, this guy was highly recomended by another Suby owner in the area... If I knew this was going to be an issue I probably wouldn't have had them do it. Granted the guy gave me the option that if I did have problems I could bring it back and he'd try again with the hammer on weights. Unfortuately... my basement flooded this weekend and everything from by basement is in my garage blocking my jacks, stands, and air compressor (to take off the stock lugs and wheels). Anyway, if someone has recomendations on how to effectively balance in case I have balancing issues Id appreciate it. |
#7 |
Member#: 28716
SCIC
Vehicle:2006 STI |
Are you actually getting a bad vibration over 30 or are you just being paranoid?
There is no reason at all for stick-on weights to be an issue. If you have a problem, go somewhere else. I'd be wary of the guy anyway since he recommends using clip-on weights on your Rotas...that's crazy. If it'll make you feel any better, go to a shop that uses this. |
#8 |
Member#: 29355
NWIC
Vehicle:2003 GD6 Hate chall but i'mma maintain |
by the way, how are you liking the fuzion ZRi? i hear they are terrible...
| Thread Tools | |
| Display Modes | |
| STI stock bbs and tape weights? | ShadowDancer | Vancouver Impreza Club Forum -- VIC | 9 | 10-14-2009 02:19 PM |
| Info: Kazera / Kuhmo weights and stock wheel weights. | powerlabs | Tire & Wheel | 6 | 07-29-2005 08:32 PM |
| STi - say no to tape weights | re92 | Tire & Wheel | 1 | 04-17-2004 04:02 PM |
| Tape-weighting in/around Nashua NH? | North Ursalia | New England Impreza Club Forum -- NESIC | 1 | 04-23-2002 03:01 PM |
| rims tape weight. and rotation | bratmantlz | Brakes, Steering & Suspension | 7 | 08-08-2001 02:26 PM |
