Old 07-08-2005, 07:21 PM   #1
josh04
Member#: 89288
2002 Rex
Default Underdrive pulley???
Does anybody know who has an underdrive pulley that has any problems or loves it to death. Because I just bought a Unorthodox Underdrive pulley. And I'm not sure exactly what it would do besides underdrive the voltage. I know their is faq, but I want to know more through other people not just one person.
josh04 is offline   Reply With Quote
Old 07-08-2005, 07:45 PM   #2
wht052.5
Member#: 79527
2005 2.5RS(I NDTRBO)
Chipped Crystal Gray
It's lighter as well. Might affect idle.
wht052.5 is offline   Reply With Quote
Old 07-09-2005, 04:23 PM   #3
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
None of your accessories will work as well, i.e. your alternator will make fewer amps, your power steering will assist less and your AC will blow less cool. Also, you might want to consider reading this.
Al_Smokemcrack is offline   Reply With Quote
Old 07-09-2005, 04:30 PM   #4
sidewayz
Member#: 5810
2001 S366 2.5RS
dont sweat it.
113k on my .1 rs with ZERO probs.. and I have all my pulleys underdriven
albite my windows go up a bit lower but who cares
sidewayz is offline   Reply With Quote
Old 07-10-2005, 01:42 AM   #5
cudaeh
Member#: 53815
2000 impreza 2.5 rs
metallic red
i have a cheap a$$ 'bomz racing' pully. It weighs 1lb. I notice a smoother acceleration, it feels a bit more powerfull. the only down side i see is at night when you pull away from a light the headlights get brighter... thats all i notice.. I just installed a didgtial volt meter and at 700 rpm with the ac going windshild wipers on headlights on and radio on the voltage is 12.7 volts.. so you wont run into an issue with your battery discharging.
cudaeh is offline   Reply With Quote
Old 07-10-2005, 04:01 AM   #6
SLAKKER2282
Member#: 89008
1998 SUBARU 2.5RS
RALLY BLUE PEARL
I also have the cheap Bomz pulley and after the amazingly easy install, I do notice a bit more. It also brightens the headlight after moving from a stop. I dont see it as a big deal.I noticed no other negative effect. The ac is still amazing and the power steering hasnt gotten any harder. I am really happy with it. Just wait until you hold the original pulley in one hand and the new in the other. Youll feel the difference.
SLAKKER2282 is offline   Reply With Quote
Old 07-10-2005, 09:31 PM   #7
DragonRM
Member#: 14365
Just a lighter pulley will give you almost as much performance without screwing up your electrical system at all.
DragonRM is offline   Reply With Quote
Old 07-10-2005, 09:54 PM   #8
jwan01
Member#: 63855
2004 PSM WRX Stg 2
95 L Project Car
Lightened is better, IMO
Mr Josh $90 shipped
Cobb i think about 125 + shipping
jwan01 is offline   Reply With Quote
Old 07-10-2005, 11:37 PM   #9
DragonRM
Member#: 14365
can get a full set from Holland Engineering (pro-ecm) for like 149 (not sure on price) from Larry at www.imprezars.com
Old 07-11-2005, 01:10 AM   #10
Sic 2.5rs
Member#: 86715
2001 GM6 RS
Silverthorn
I've got a full set of unorthodox underdrive pulleys. I dropped .2 seconds in the1/4 but the lights do dim at idle. Full set of pulleys weigh 1.4 pounds stock pulleys were more like 7lbs.
Sic 2.5rs is offline   Reply With Quote
Old 07-11-2005, 08:39 AM   #11
Pat L.I.
Member#: 20498
2006 WRX TR
i have the GFB lightened and underdriven pulley set. Yes it dims your lights slightly at idle, ac does not work as well unless the car is revving alot.
This doesnt bother me as i rarely use the AC. I liked the gains i got from the set.
Pat L.I. is offline   Reply With Quote
Underdrive pulley vs Lightened pulley sc00ter Newbies & FAQs 21 05-20-2008 08:20 PM
Underdrive Pulleys/Lightweight Pulleys UGotBoost? Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-22-2003 10:32 AM
Underdrive pulleys AND lightened pulleys? jhayzhon Normally Aspirated Powertrain 1 10-10-2001 07:50 AM
('93-'01) Short throw shifter or Underdrive pulley? Opinions needed! Robmat Impreza Forum 11 05-21-2001 12:56 AM
Unorthodox Underdrive Pulley / Belt kits for SVX Boxer4Racing SVX Forum Archive 21 02-18-2001 06:36 PM
