Old 05-17-2012, 12:42 AM   #2501
vicious_fishes
Member#: 158864
2003 SOHC destroker
can someone give me a brief rundown of how running E85 allows you to run more boost?
vicious_fishes is offline   Reply With Quote
Old 05-17-2012, 12:52 AM   #2502
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
subscribed...
punchjamesarnol is offline   Reply With Quote
Old 05-17-2012, 01:01 AM   #2503
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
http://www.iwsti.com/forums/3016597-post3.html
This was helpful to me.
mccanixx is offline   Reply With Quote
Old 05-17-2012, 01:32 AM   #2504
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Pump gas is so energetic that it rarely allows you to run whatever boost level nets you the most flow from the turbo. You generally have to turn the boost down a couple of pounds to keep the temperature lower so that you don't run into detonation.
Remember, tuning for power is about finding that right combination of AFR, boost, and timing that yields the most power without detonation. While running more boost on a given setup might net you more flow from the turbo, the tendency to pre-ignite might force you to add so much fuel or pull out so much timing at this higher boost that you actually lose power.
E85 doesn't have that problem, in general you can run whatever boost you want, and whatever timing you want, and as long as you keep the AFR around the low to mid 11s (gas AFR) it won't detonate (there are exceptions, but compared to pump gas that's what it feels like). This lets you run the optimum boost level for your turbo to maximize flow, not the optimum boost level to prevent detonation.
Old 05-17-2012, 01:51 AM   #2505
vicious_fishes
Member#: 158864
2003 SOHC destroker
posted in the other thread eggroll
Old 05-28-2012, 07:29 AM   #2506
Mr645
Member#: 320769
2012 WRX 5 door
That and a lot more are explained in detail on the first page of this thread
Mr645 is offline   Reply With Quote
Old 05-28-2012, 09:05 AM   #2507
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
The OP's answer to the question is on the first page, but frankly I think 95% of what he's written is from the perspective of someone that just wants to run E85 to save money and maybe get a little performance boost. I've seen better explanations by tuners in other threads on why E85 is a great performance fuel.
To my (limited) understanding, E85 has three main advantages that allow you to run higher boost and thereby higher power:
1) more det resistance (base ethanol octane is 118 per OP although E85 is ~100).
2) lower energy density means more fuel added per HP means more heat is absorbed by the fuel as it is vaporized which cools the intake charge.
3) burns cooler, again helping engine temperatures and allowing more boost.
Some tuners I've seen suggest the performance advantage of tuning for E85 is as good as Q116 race gas despite its relatively low octane of 100.
Now if only the government would regulate the ethanol content and the octane of the gasoline portion of E85 more closely, it would be a more reliable performance fuel. Some racers won't touch because of the variability and risk of damaging their race engines. I found an interesting article in a non-subaru forum that runs through all the ways E85 is not controlled and just how risky it is to use. I would consider the water/gasoline tester a minimum to run it, but there's no easy way to test if the gasoline portion of the blend was made with 87 or 93 or whatever gasoline.
Frank
Frank A is offline   Reply With Quote
Old 06-12-2012, 04:58 PM   #2508
Red_Wrx
Member#: 158658
2 words: Volumetric efficiency
Red_Wrx is offline   Reply With Quote
Old 06-26-2012, 12:00 PM   #2509
SVT_WRX
Member#: 164830
G61 III OVE 58e
Default 139,000 Miles (35,000 on E85)
Here is a pic of the piston after the dude I sold it to blew the motor by switching it to pump gas and forgetting to turn down the boost controller:
Remarkable. They look almost brand new.
SVT_WRX is offline   Reply With Quote
Old 06-27-2012, 12:04 AM   #2510
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
Sucks about the piston but man that is impressive! Sooooo clean!
907Bum is offline   Reply With Quote
Old 06-29-2012, 06:49 PM   #2511
Rabid_Machina
Member#: 167278
2004 WRX
looking for a ballpark figure on what a 2.0l with a big 18g w/ supporting mods externally gated with 3 port EBC, ported IM and Ex. Mani's with 1200cc injectors would make.
currently sitting a 307.8whp 284.5wtq on a dynocom.
are bigger injectors necessary?
if so, i will go bigger. also plan on upgrading clutch.
what are some things i should be concerned about? my concerns are rotating assembly and tranny.
have a set of blast plates that i hope will help prevent trany flex as i go up on power.
i've read most of the first few pages, and kind of understand. it can get quite overwhelming with all the information given.
Rabid_Machina is offline   Reply With Quote
Old 07-01-2012, 09:26 PM   #2512
Il Capitano
Member#: 299619
2011 Evo X
WW
I read the whole thing, but the conversion seems to good to be true. So all I need is a fuel pump (walbro 255) and 1000cc injectors plus a e85 tune? Also, can I run e85 on a stock 2012 wrx turbo with no problems? Thanks!!
Il Capitano is offline   Reply With Quote
Old 07-01-2012, 09:37 PM   #2513
Member#: 51961
2005 STi
2012 WRX
Walbro 255 is only good for 850cc injectors, I would go for a DW300 instead. But yes, that's all that's required.
Old 07-01-2012, 09:51 PM   #2514
Il Capitano
Member#: 299619
2011 Evo X
WW
Alright, I'll look into it. Thanks for the tip man.
Old 07-02-2012, 06:00 AM   #2515
RavingLunatic
Member#: 76673
2006 Impreza WRX STi
Crystal Grey Metallic
I'm running dw300 and 1000cc top feed injectors. According to my tuner, that's the bare minimum. He normally likes 1200cc top feed
RavingLunatic is offline   Reply With Quote
Old 07-08-2012, 02:52 PM   #2516
ShugSTi
Member#: 187128
http://forums.nasioc.com/forums/show....php?t=2277357
ShugSTi is offline   Reply With Quote
Old 07-08-2012, 04:29 PM   #2517
Member#: 51961
2005 STi
2012 WRX
Originally Posted by ShugSTi View Post
...and your point is? You can't just quote somebody and then post a link to a 220 post thread with no explanation and expect anybody to know what you're trying to say.
Old 07-09-2012, 02:36 PM   #2518
Silver_04_WRX_SC
Member#: 67198
2004 Baja Turbo
I am about to get tuned on the 20th. My mods are Walboro 255lph pump, modded 07 WRX injectors (740cc I think??) and a VF48. The tuner said that I would need a DW300 and 1000 injectors to run e85...is that true?
Thanks
Silver_04_WRX_SC is offline   Reply With Quote
Old 07-09-2012, 03:24 PM   #2519
WRX 2002
Member#: 11211
2004 STi
Rally Blue
Thanks
I was tuned for 489WHP in my STi with 1000cc injectors and a external Walboro 255lph pump with GT3076 turbo, I would think you would be fine with a VF48 turbo.
WRX 2002 is offline   Reply With Quote
Old 07-09-2012, 04:27 PM   #2520
stalkerz
Member#: 242207
Just got my car tuned with e85, my tuner have to de-tune the car to 23psi because we were running a little lean on 24psi+. He said that he try to add more fuel but that didn't help and he think we ran out of pump.
What do u guys think? I thought the dw300 should be sufficient at this power level. Will Walbro400 solve my problem?
Car detail 06 STI
Access Port
ID1000
Aeromotive FPR
DW300 pump
Blouch 20gxt 3" 8cm2
tgv delete
70mm short ram
FMIC
GT Spec UEL headers+upipe with Tial 44mm
3 inch catless TBE
fully built motor(nitride crank, CP piston ,Eagle rods, ACL Bearings, Supertech Valve Springs&retainers, BC272)
stalkerz is offline   Reply With Quote
Old 07-09-2012, 06:57 PM   #2521
RavingLunatic
Member#: 76673
Car detail 06 STI
Access Port
ID1000
Aeromotive FPR
DW300 pump
tgv delete
70mm short ram
FMIC
3 inch catless TBE
You didn't find your intake to be limiting? What numbers are you making? I had bought a walbro 460 (E85 Compliant) but was told that I was not going to make enough power to run it, so I ended up with the DW300 too. If you need the pump let me know. I have on that is brand new never installed. I need to sell it. PM me if your interested.
Old 07-09-2012, 10:34 PM   #2522
stalkerz
Member#: 242207
according to my tuner I can go up to 27psi with a bigger pump like Walbro400, but I'm kind of shock to find out that the dw300 is ran out of fuel on my setup
Old 07-09-2012, 10:38 PM   #2523
RavingLunatic
Member#: 76673
from what I have seen, the Walbro 400 is not e85 compatible. the 460 is
Old 07-09-2012, 11:39 PM   #2524
stalkerz
Member#: 242207
question is, I don't think I should be running out of pump below 25psi on a 20gxt
Old 07-10-2012, 08:49 AM   #2525
Silver_04_WRX_SC
Member#: 67198
2004 Baja Turbo
Thanks for the post.... Should I really try to push this tune then? They want me to spend some $$ and get Meth...but e85 is highly abundant in SC.
What do you need to do to use E85 fuel? wantsti Rocky Mountains Impreza Club Forum -- RMIC 37 02-20-2014 01:27 AM
E85 fueling question- 850cc + fpgreen...adjustable FPR? Blown95ImpalaSS Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-29-2009 07:37 PM
E85-Fueled Z06, 30th Anniversary Corvettes to Pace 08 Indy 500 AVANTI R5 Non-Subaru News & Rumors 0 12-27-2007 01:56 PM
E85 fuel available now in Arvada 9/22/06 hotrod Rocky Mountains Impreza Club Forum -- RMIC 9 09-25-2006 02:29 PM
E85 Fuel in Austin? When? dromango Texas Impreza Club Forum -- TXIC 8 06-29-2006 01:32 PM
