Old 07-11-2012, 11:46 PM   #2551
subiidude
Member#: 141472
2008 shagg wgn STI
OG FP20g+e85 corn booze
+1 for the golan fuel filter its worth every penny e85 is some dirty stuff....
subiidude is offline   Reply With Quote
Old 07-12-2012, 05:54 AM   #2552
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
Originally Posted by the suicidal eggroll View Post
I've already run the numbers, according to every Walbro 255 flow chart out there, 65 base is fine for my flow. I can't raise the pressure any higher though.
How high are you guys running your AFR? E85 isn't like gas, max power is in the low 11s rather than gas's mid 12s. Mine is running a little richer than that right now anyway, which would explain part of the high IDC.
I run my base at 50 psi. My afr was actually in the high 10's gas calibrated afr. Both my pumps run parallel in tank. My system seems to have plenty of fuel so I'm not sure what the differance would be. My injectors are low imp 1250cc. I'm running a stock 05 sti fpr but I'm pretty sure its not being over ran because I run a fuel pressure gauge also and it seems pressure rises 1:1 on the gauge. Perhaps your getting voltage loss somehow to your pump. Or maybe your making a ass load more hp than you think .
fastblueufo is offline   Reply With Quote
Old 07-12-2012, 07:48 AM   #2553
Silver_04_WRX_SC
Member#: 67198
2012 Audi S5 Cabi
Grey
Originally Posted by WRX 2002 View Post
I would think you would need a 255 pump, its recommended upgrade at the best of times. as for the injectors I'm not sure with vf48.
I'm sure I'm near the limit with my 1000cc injectors & GT3076, will check when I get the car back.
I already have the 255, they are recommending the dw300 FP. And 1000 injectors before they will tune the car. But it's money I don't have to spend. (Since I already have the 255 and the modded blue injectors)
Anybody else, what are the fuel requirements for e85 and a VF48 turbo?
Silver_04_WRX_SC is offline   Reply With Quote
Old 07-12-2012, 08:13 AM   #2554
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
What is the flow of your light blue modded injectors? I imagine around 850cc...
That is more than sufficient for you VF48. Who is going to tune your car? If they are recommending a bigger pump and 1000cc injectors for a vf48 I may stay away from them.....
My walbro 255lph was good to about 480whp...
Old 07-12-2012, 08:16 AM   #2555
Silver_04_WRX_SC
Member#: 67198
2012 Audi S5 Cabi
Grey
Draco, I have a free dyno tune. Which I know them well, so I trust them. They just said the dw300 was designed for e85.
And I have not had the injectors flow tested, but going off from here they should be around 740cc.
Old 07-12-2012, 08:33 AM   #2556
juanmedina
Member#: 133146
I had my 255lph in the tank for 4 years, I pulled it to install my walbro 460lph. The pump looked like new and there was no rust what so ever, I sold it and its currently running on someone else car .
My old light blue modded injectors used to flow 860cc, I have a set of stock light blue injectors laying around that I can sell and you can modded them. I hope they are not trying to sell you id1000s they only flow 860cc...
Since its a so call free tune they are trying to sell you something that you don't need. 740cc will be enough at our elevation.
GL
Old 07-12-2012, 10:51 AM   #2557
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Where the hell can I buy one of these? I've looked all over and I can't find a distributor that has them in stock.
WRXt4cy is offline   Reply With Quote
Old 07-12-2012, 10:58 AM   #2558
Member#: 51961
2005 STi
2012 WRX
I got my 40-08 from Jay Racing. They still have that model in stock, but a few of the others are out:
http://www.jayracing.com/index.php?m...acturers_id=43
Old 07-12-2012, 11:05 AM   #2559
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
Magnafuel has nice ethanol/alcohol compatible filters as well. Summit sells them, or you can probably call magnafuel direct and order.
http://magnafuel.com/products/access...ters/index.htm
http://www.summitracing.com/search/B.../?autoview=SKU
cnstman is offline   Reply With Quote
Old 07-12-2012, 11:49 AM   #2560
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Yeah - this is the only distributor I could find and they are out of stock on the 5/16th barbed fitting one.
When I go with a bigger turbo, I'll do my fuel system and switch to AN fittings but that's not happening real soon so I need to find something with hose fittings.
I emailed Golan to see where I can get one.
I'd love to find a filter with a clear case so I could check it without opening it up but such a thing doesn't seem to exist.
On a related note: For people with the 08+ WRX/STi and older Legacys that have the white fuel pump housing - have you ran into any issues with E85 and the built in paper filter that lives inside that housing? I didn't see a way to remove/replace it. Could this be an issue with extended E85 use or should it be fine?
Old 07-13-2012, 05:22 PM   #2561
jayoung
Member#: 124649
2011 STi
Plasma Blue Pearl
Cool Looking for blessing/comment from your experience.
Hi Guys,
Here is my build idea. Nothing has been ordered yet though...
Car: 2011 STi Cobb Stage 2, catless Invidia DP, stock catback.
Deatschwerks DW65c (Flows 265 litres per hour, Fits in cleanly, no modification)
Deatschwerks 1000cc Top Feed Injectors
NGK 2309 Spark Plugs
GrimmSpeed EBCS
AEM 35psi Boost Gauge
AEM Digital Wideband UEGO Gauge
Daily driver, not looking for a rip saw. Want it dependable and between 300WHP/WTQ and 350WHP/WTQ on E85 tune.
Please be constructive as well as honest.
Thanks and regards,
-J
jayoung is offline   Reply With Quote
Old 07-14-2012, 12:07 PM   #2562
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
^ you should have NO problem hitting/beating your goal...will more than likely be WELL over that goal in wtq
just fyi...the ngk iridiums have been known to have issues when running E85. i would recommend going with the ngk coppers. the part number you are looking for is LFR6A.
amalgrover is offline   Reply With Quote
Old 07-15-2012, 09:46 PM   #2563
jayoung
Member#: 124649
2011 STi
Plasma Blue Pearl
Thanks Amalgrover,
What kinds of issues, bad stuff like preignition? Is it because the coppers are hotter?
Regards,
-Jim
Old 07-15-2012, 09:57 PM   #2564
amalgrover
Member#: 183480
2009 Forester XT
some people never have issues with them, but alot of people have had issues with the iridiums misfiring and fouling out faster than the coppers.
Old 07-16-2012, 11:32 AM   #2565
jayoung
Member#: 124649
2011 STi
Plasma Blue Pearl
Understood, thank you!
On another note, what is going to happen to E85 with the drought situation?
Skyrocketing prices? Shortages/production cut backs?
I live in Wisconsin and we have an E85 station about every 500 yards. We're absolutely a corn state. It's pretty bad here but we're no where near as bad off as some of the farmers to the South and west.
Old 07-16-2012, 01:17 PM   #2566
02RexWI
Member#: 165141
I've noticed a lot of our E85 stations around here disappearing (renew E85), but you can still find E85 fairly easily.
The prices are the drawback. It's not much cheaper than regular unleaded recently, but it's cheap compared to race fuel.
-Mark
02RexWI is offline   Reply With Quote
Old 07-16-2012, 02:00 PM   #2567
jayoung
Member#: 124649
2011 STi
Plasma Blue Pearl
-Mark
Hi Mark, where are you located?
Kwik Trip and PDQ are in for the long haul. So they say.
I have a Kwik Trip 1/2 a mile from me, a PDQ 1/2 mile from where I work, and there seems to be a station near all the autox/track events I run save for AIR in Shawano and Blackhawk Farms.
Old 07-16-2012, 02:13 PM   #2568
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
E85 prices are up in the Des Moines area. They were down as low as 2.68 I think but are currently hanging around 2.99. Premium for comparison is around 3.59 right now. At a 60c difference, it costs me just slightly more to run E85 than premium when I average around 16 mpg. I can get about 18.5/19 with all highway and save a little money running E85.
Our E85 has gone to 70% ethanol everywhere though, probably to keep the cost down. Last year we were seeing around 90% at this time when gas prices were way up.
I'm headed to Denver, CO tomorrow, running E85 the whole way. I've got a Zeitronix ECA so I'm going to see what the E content is as I fill up along the way.
Old 07-16-2012, 02:18 PM   #2569
jayoung
Member#: 124649
2011 STi
Plasma Blue Pearl
You Iowa guys have it the BEST. :-)
Is this the one you have? Like it / love it / hate it? Worth it?
http://www.zeitronix.com/Products/ECA/ECA.shtml
Old 07-16-2012, 02:33 PM   #2570
RavingLunatic
Member#: 76673
2006 Impreza WRX STi
Crystal Grey Metallic
-Mark
If your converting for price over performance, you doing it wrong. Besides most of us need 93 octane. Where i live, E85 is about a dollar cheaper than 93 octane. If i put regular in my car, my engine will tell me to go f**k myself.
RavingLunatic is offline   Reply With Quote
Old 07-16-2012, 02:41 PM   #2571
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Haha - I assume you mean the price difference and not the E content right?
Yup - that's the one I have and its been solid so far. I've had in for a couple weeks. I snagged the needed sensor for cheap from a Tahoe sitting in a local salvage yard so my total cost for the project wasn't that bad. Its one of those things that I've spent money on that I really feel like was a good investment. I was always worried about drastically changing blends or pumping in a bad mixture, like only 30% E or something since the regulations are so poor and they know that a true FFV wouldn't be hurt if this happened. I didn't want to have to always get a sample of fuel and test by hand. The only reason I didn't do it sooner was that the cost for a new sensor is really high, higher than the ECA itself. Once I realized I could find a used one and was able to get it cheap, I was good with the price of the ECA itself.
Here's how I mounted everything in case you're interested since you have a GR as well:
Edit: If my fuel lines / FPR look funny to you, its because I switched out my stock FPR with an '05 STi FPR.
Old 07-16-2012, 02:48 PM   #2572
02RexWI
Member#: 165141
Obviously we know about the advantages of E85, hence the reference to race fuel. No need to be a dousch.
jayoung: I'm in Neenah, we've probably seen each other at an Auto-x, I drive a SWP 07' STI. Used to drive a WRB 02' WRX.
I usually fill up on E85 when leaving Appleton for Shawano, but I have taken a 5 gal. gas can with me before to be safe.
I'm not running E85 on my STI, but my WRX was on it for a long time before I parted it out. It's hovering around $3.12/gal. currently, with premium around $3.65/gal.
That only puts E-85 at about 15% cheaper, and with a drop in mileage of about 25% you definitely aren't coming out ahead from a monetary perspective.
Old 07-16-2012, 02:50 PM   #2573
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
How much is the zeitronix and tahoe FF sensor? Im looking to get a similar set up.
smeerone is offline   Reply With Quote
Old 07-16-2012, 02:59 PM   #2574
jayoung
Member#: 124649
2011 STi
Plasma Blue Pearl
Looks good, what kind of plumbing modification did you need to get the 'hoe sensor in?
Old 07-16-2012, 03:00 PM   #2575
RavingLunatic
Member#: 76673
Not trying to be one, hence the reference to premium fuel. Which is what most of us use.
Why are you converting then?
What do you need to do to use E85 fuel? wantsti Rocky Mountains Impreza Club Forum -- RMIC 37 02-20-2014 01:27 AM
E85 fueling question- 850cc + fpgreen...adjustable FPR? Blown95ImpalaSS Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-29-2009 07:37 PM
E85-Fueled Z06, 30th Anniversary Corvettes to Pace 08 Indy 500 AVANTI R5 Non-Subaru News & Rumors 0 12-27-2007 01:56 PM
E85 fuel available now in Arvada 9/22/06 hotrod Rocky Mountains Impreza Club Forum -- RMIC 9 09-25-2006 02:29 PM
E85 Fuel in Austin? When? dromango Texas Impreza Club Forum -- TXIC 8 06-29-2006 01:32 PM
