Old 08-25-2005, 01:13 AM   #51
Phy6
Member#: 2219
2007 Exige S
zaxrex, I usually don't go out that way, but it's like 15-20 mins from me. I will try that on a weekend!! Im in MD near VA (exit 3 south 5 miles)
Phy6 is offline   Reply With Quote
Old 08-25-2005, 08:53 AM   #52
hotrod
Member#: 14141
2002 Impreza WRX
I've got some gallon jugs of reagent-grade ethanol. Can I dump these into my gas tank--like I do w/ xylene and toluene for an octane enhancer, or would EtOH not mix well?
It should mix okay as long as the gas tank has no trace water in it. That being unlikely given the age of the vehicle. The E85 also includes some corrosion inhibitors etc.
If you make an effort to get things mixed, like pour the Etoh in, and then top off the tank with gasoline, or go a bit easy for a few miles so normal driving stops and starts turns etc. give the fuel time to mix well, I wouldn't expect to have much problem.
As always with the do it your self stuff just like the toluene there is some small risk of mishap. For most of us its much easier to get the E85, as unless you have a direct connection to an industrial user of ethanol its not cheap if its not denatured due to BATF regs.
Larry
hotrod is offline   Reply With Quote
Old 08-25-2005, 12:45 PM   #53
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
jblaine is offline   Reply With Quote
Old 08-25-2005, 04:23 PM   #54
s_nold
Member#: 22649
2008 Spec.B
What would the effects of WI have on E85? Any serious negatives? another performance boost? anything?
s_nold is offline   Reply With Quote
Old 08-25-2005, 05:35 PM   #55
icantdrive75
Member#: 69663
2004 WRX
Java Black Pearl
With E85, I don't think WI would be necessary...but I'll let someone else handle this one.
icantdrive75 is offline   Reply With Quote
Old 08-26-2005, 07:27 PM   #56
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
well, alcohol injection is suppose to "raise"/simulate the octane level of your fuel...E85 is already effectively 105 oct...so you do the math
but as far as the water goes, it breaks down the ethanol over time....not sure how fast though or what would happen under combustion...any Chem E's in here?
Old 08-26-2005, 08:55 PM   #57
hotrod
Member#: 14141
2002 Impreza WRX
WI would probably not be necessary for its customary usage to raise octane, ---------- in considering the question there may be an application for it.
If you ran E85 on a gasoline tune you'd be very lean and WI might allow you to do that no harm no foul ----- Hmmm food for thought.
You'd still get the CEL
Larry
Old 08-27-2005, 12:41 AM   #58
s_nold
Member#: 22649
2008 Spec.B
Perhaps the WI would allow for better gas milage, cool the intake charge, and maybe still clean the cylinders?
Old 08-27-2005, 11:34 AM   #59
Jon [in CT]
Member#: 2992
02 WRX Sedan
Although E85 has a pump octane rating of about 100, it's still not knock-proof and, for example, you shouldn't try to eliminate that huge restriction in the air intake path that's known as the intercooler.
I expect that if you're optimizing your fuel enrichment map and ignition advance maps to produce best torque for E85, you'd still run into some load/rpm conditions where knock prevents the use of best torque settings and that is where water injection would help produce more torque.
Jon [in CT] is offline   Reply With Quote
Old 08-30-2005, 11:57 AM   #60
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
With gas prices jumping another $0.30 this week due to the hurricane, anyone thinking of creating an AP map to run wastegate only, 7psi, on stock injectors and E85?
Another question would be, what is the max boost you can run with E85 on stock injectors and stay under the 80-90% duty cycle mark? 10psi?
Revision is offline   Reply With Quote
Old 08-30-2005, 12:26 PM   #61
TheMadScientist
Member#: 23717
2005 Big red
I have my Utec setup for a lean burn cruise and wastegate boost. I can't get E85 so I can't comment.
TMS
TheMadScientist is offline   Reply With Quote
Old 08-30-2005, 12:27 PM   #62
hotrod
Member#: 14141
2002 Impreza WRX
Oh about 30 psi as long as you didn't go over 5000 rpm. J/k
Seriously alot more boost than you need to go very fast.
I regularly run around with my boost at 12-14 psi on 100% E85 and have all the performance I need for highway driving and some fun.
Octane wise E85 will support just about any boost level your turbo is capable of producing. If you include an upgraded (or crushed fuel pressure regulator to bump fuel pressure) you can probably run over 20 psi to about 4000 rpm, and 15-16 psi to redline. Due to E85's higher octane it will tolerate leaner mixtures than you can get away with on most gasolines.
Larry
Old 08-31-2005, 12:35 AM   #63
Homemade WRX
Member#: 33782
96 bastard child
I really want ethanol where I live...damn it
Old 08-31-2005, 11:01 AM   #64
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Just to chime in and whore my post count
This simulates the same experiment I read about somewhere on the internet about finding an E85 approved oil. I now use mobil 1 synthetic, which is E85 approved. The old, cheap pennzoil I was running wasn't approved for it. I filled 2 test tubes with about a tablespoon of E85. The one on the left turned a bit of a cloudy white with Mobil1. According to that experiment I can't find the link to, that's what E85 approved oil does. The other was this watery brown color with E85 mixed with dino oil. Regular oil dilutes with E85. The synthetic oil actually looked like a water/oil mix, with the oil suspended in the mixture rather than sitting on top.
I'm also going to the dyno this weekend to test the full E85 tune .
HamFist is offline   Reply With Quote
Old 08-31-2005, 11:32 PM   #65
Homemade WRX
Member#: 33782
96 bastard child
well, gas prices jumped $.50 a gallon today, thank you Katrina
Old 09-05-2005, 06:37 AM   #66
Revision
Member#: 242
MY05 PSM GGA !STOCK
Just filled up again after running 25% ethanol mix. Car seems to like running 95 octane.
Got 23 mpg in mixed driving. Normally, I get 20-22mpg in mixed driving.
Car is stock, except for a RiftsWRX tuned AP.
Old 09-07-2005, 12:17 AM   #67
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
bump for sticky, please!
cnstman is offline   Reply With Quote
Old 09-07-2005, 06:50 AM   #68
fmowry
Member#: 54604
2004 FXT
Cayenne Red (sold)
So is the price of E85 going up with the price of gas or is it jumping less?
Frank
fmowry is offline   Reply With Quote
Old 09-07-2005, 10:02 AM   #69
Homemade WRX
Member#: 33782
96 bastard child
Frank
it will go up, it is 15% gasoline
Old 09-07-2005, 11:07 AM   #70
fmowry
Member#: 54604
2004 FXT
Cayenne Red (sold)
I want to know how much it has gone up. Gas has already gone up %20. If the %15 gas in E85 only goes up %20 that's %3 total cost increase.
Frank
Old 09-07-2005, 12:55 PM   #71
cnstman
Member#: 9548
2004 WRX STi
edited to stay on topic.
Old 09-07-2005, 01:27 PM   #72
hotrod
Member#: 14141
2002 Impreza WRX
In my area still priced at about 75% of pump premium, $2.39 for E85 and $3.29 for premium over the labor day holiday.
Lets keep the cost of oil discussions out of this thread, better posted to one of the other threads. I'd like to keep this focused on the tech side of E85 tuning.
Larry
Old 09-07-2005, 01:40 PM   #73
cnstman
Member#: 9548
2004 WRX STi
Larry
sorry larry, i am in COS so i would hope my e-85 is comparable to your price. anyone using e-85 on a sti yet? if so what percentage mix.
Old 09-07-2005, 01:47 PM   #74
OneArmedScissor
Member#: 18958
08 STi
Black as my heart
we should start a website on e85
like www.fueledbycorn.com
and put stickers on our cars to spread the word. If we want e85 to become a reality it will take lobbying and common knowledge. Most people have no idea what e85 is and it really could be a solution to our fuel problem by drastically reducing fuel consumption.
OneArmedScissor is offline   Reply With Quote
Old 09-07-2005, 06:55 PM   #75
hotrod
Member#: 14141
2002 Impreza WRX
There are web sites dedicated to E85 !
http://e85forum.net/
Larry
What do you need to do to use E85 fuel? wantsti Rocky Mountains Impreza Club Forum -- RMIC 37 02-20-2014 01:27 AM
E85 fueling question- 850cc + fpgreen...adjustable FPR? Blown95ImpalaSS Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-29-2009 07:37 PM
E85-Fueled Z06, 30th Anniversary Corvettes to Pace 08 Indy 500 AVANTI R5 Non-Subaru News & Rumors 0 12-27-2007 01:56 PM
E85 fuel available now in Arvada 9/22/06 hotrod Rocky Mountains Impreza Club Forum -- RMIC 9 09-25-2006 02:29 PM
E85 Fuel in Austin? When? dromango Texas Impreza Club Forum -- TXIC 8 06-29-2006 01:32 PM
