Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Old 09-27-2005, 11:24 AM   #126
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Is there any way to figure out what the octane blend is for 30% Ethanol?
The formula I'm using now even using the 118 blend octane rating with 93 octane premium fuel show I should have 99 octane, but you are saying that the octane rating goes down the more ethanol we blend..
Revision is offline   Reply With Quote
Old 09-27-2005, 11:27 AM   #127
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
i was wondering that also
i also wonder if the gas you start with has 10% ethanol in it, does that dimishish the mixing octane rating of the e-85 as you start to add.
cnstman is offline   Reply With Quote
Old 09-27-2005, 03:59 PM   #128
s_nold
Member#: 22649
2008 Spec.B
Angry
I stopped by the only e-85 pump in my area yesterday to get a splash of the good stuff...and well they priced themselves right out of the game. $2.79/gal for e-85 when 91 octane was going for $2.84/gal. CRAZY...
s_nold is offline   Reply With Quote
Old 09-27-2005, 05:30 PM   #129
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
I wanted to ask this and see what I might be able to do. I can't sell any kind of conversion "kit" per-se. But, can I post the information, test results, and parts used on my website without any reprocussions? I figure they can't nail me with anything bad if I'm giving away the info and listing the already-available parts I used.
HamFist is offline   Reply With Quote
Old 09-27-2005, 05:42 PM   #130
hotrod
Member#: 14141
2002 Impreza WRX
s_nold ---- It appears that there have been so many folks trying out E85 lately that we've created something of a shortage (at least that is my guess from the pricing I've seen) It's sort of a good news bad news thing -- increased demand will only help get more pump outlets opened up, bad news its putting a squeeze on a very good price split we used to have.
Hamfist --- I would think there would be no problems.
On the octane issue -- I just figure the octane based on a simple 100 octane for the ethanol fraction, and leave it at that. I see no point is splitting hairs over is my tank at 94.5 octane or 95.1 octane. Bottom line is does a specific blend prevent detonation in your car if it does that's all the info I need.
Larry
hotrod is offline   Reply With Quote
Old 09-27-2005, 05:57 PM   #131
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
I don't see a problem with that. Reason being is that you are not a company selling the parts to make said "kit". Your just providing information on what you used on your car.
I have plans to heavily modify my car and get up to around 400hp. If i use E85 (which i plan on). I'm going to need 1200cc injectors to handle all that. It might be easier to do some staged injection with the Hydra and add 1 or 2 more injectors.
Old 09-27-2005, 06:59 PM   #132
tmarcel
Member#: 7555
I'm a little lost now on the way the E85/gas octane # is being obtained. Anyway, with the way you were calculating the octane rating, what would E10 work out too?
tmarcel is offline   Reply With Quote
Old 09-27-2005, 08:09 PM   #133
Revision
Member#: 242
MY05 PSM GGA !STOCK
Assume that all regular Premium gas is 10% ethanol and 93 octane
E85 is 85% ethanol
WRX gas tank is 15.9 gal
Assume that our blend of E85 is 100 octane
To get 30% ethanol in a tank use this formula as a percentage of your tank.
((10% ethanol * 11.9 gal premium gas) + (85% ethanol * 4 gal E85)) / 15.9 gal tank = 28.9% ethanol final concentration
to figure out octane using the same percentage method
((11.9 gal premium gas / 15.9 gal tank) * 93 octane) + ((4 gal E85 / 15.9 gal tank) * 100 octane) = 94.8 octane final concentration in your tank.
Old 09-27-2005, 11:04 PM   #134
hotrod
Member#: 14141
2002 Impreza WRX
I just re-located the source that I was refering to from memory -- I miss-remembered the blending octane slightly --- its not 118 but about 112.5, but as you dig deeper in the text of the report you find that there is no one representative blending octane value.
Check out the following:
http://www.eere.energy.gov/afdc/pdfs/6968.pdf
Otane response page 3-6
Energy content on page 3-9
Materials compatibility starts on page 3-14
Lots of other good info but that should get you started.
As you will note the octane effect of added ethanol (like other octane enhancers) changes depending on the blending stock it is added to.
Larry
Old 09-29-2005, 07:27 PM   #135
Keshav
Member#: 1654
1998 GC8 Unicorn
MV Agusta Brutale S
Wikipedia has this very interesting bit in one of their Ethanol articles about how Brazil has been affected by its own ethanol fuel industry. They've been using it as an automotive fuel for decades.
http://en.wikipedia.org/wiki/Ethanol...ian_experiment
Keshav is offline   Reply With Quote
Old 10-02-2005, 01:36 PM   #136
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Side note of interest...I had a little "fun" on recent cold saturday night. I succeeded in getting about 16mpg. I've never gone through 1/4 tank that fast. The funny thing is, it still gets 25-27mpg on the hwy. Still having cruise and A/C just rocks . Being delivery-boy it still manages about 22mpg in the city.
Old 10-08-2005, 01:47 AM   #137
bennettsweb
Member#: 59466
Ham - Not the best results for me of late.. seem to be loosing power. Granted I need a new clutch, but when it does stick I'm getting about 20 MPG at less than normal power. I need to put the hotter sparks in tonight. I really get the feeling I need to tune to get the most outa this stuff so now that I have my new clutch purchased I'll be looking into a piggyback of some kind. I wonder how much a difference your torque chip is making on your setup... maybe it was made for E-85
72psi sounds way too much!! Is that relative to vac at idle or just straight off the gauge? I’ve been up to 55psi which is about 48 on the gauge at idle and I think it’s running rich… you think I might be on the lean side? I don’t know how much the pressure really matters anyway if the ECU is going to correct the map anyway, but it seems to be an issue with my setup.
I’ll pull the old sparks tonight and “read” them.
bennettsweb is offline   Reply With Quote
Old 10-10-2005, 10:36 AM   #138
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Heck yeah you're lean!!! I have to run high pressures just to get the right mixtures. I'll be upgrading to WRX injectors(440's) over the winter. I'm actually running about 80psi base pressure. No problems so far. The way I've got it crimped on the returen line, though, my pressure drops to about 60 at WOT. It's basically pouring the stuff in, which is good. Around town, I'm still getting about 20mpg without my foot in it. 3,000miles on the stuff and so far so good .
Old 10-10-2005, 12:36 PM   #139
krees23
Member#: 95154
2005 Subaru WRX STi
For those running a high percentage of E85 in their fuel tank, how does the ECU cope with getting the right A/F ratio? Does it just advance the timing until it detects knock and backs off from there? For E85, what is the proper A/F you'd be looking for when running a wideband sensor?
Thanks in advance for any info on the above.
krees23 is offline   Reply With Quote
Old 10-10-2005, 01:47 PM   #140
cnstman
Member#: 9548
2004 WRX STi
read the first few posts by Hotrod
Old 10-10-2005, 02:05 PM   #141
krees23
Member#: 95154
2005 Subaru WRX STi
Thanks... I should have reviewed the beginning.
Old 10-11-2005, 05:52 PM   #142
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
My goal with a blower has been to make the most power with the least amount of boost. Once I tune things there, then I can up the boost with smaller and smaller pulleys until the car is plenty fast. Solid 14.0/high 13's at this altitude using all stock components is a good accomplishment. Putting 200 to the crank on an n/a 2.5 I think is pretty damn good with a stock block, bolt ons, and a fuel change. With 5psi, I should be around 275hp. With 8psi, I should be at about 310hp. I've already maxed my stock injectors with running the ethanol. But, I found I can swap WRX injectors in with a cheaply modded fuel rail (thanks, ty ). Will I have enough fuel flow with WRX 440's, or should I step up to 550's? The fuel rails will accept either.
Old 10-21-2005, 12:51 PM   #143
tmarcel
Member#: 7555
Just wanted to report back to this thread on how the 2.0L VW engine has been running. I was up to 50/50 mix of E85/gasoline. No problems from the ECU as far as CEL's. I decided to stay at that mix since it was running fine and there's no way to hook up the WB to this car as it's completely stock.
So, the day before yesterday I filled up on the 50/50 mix again. However, this time I used E10 in place of the regular 87 octane and of course the normal E85. I'm assuming the E10 has a 10% mix of ethanol regular gas? Anyway, I thought that the slightly higher ethanol content might not make a difference.
Last night while driving, I accelerated from a traffic light and the CEL came on. I checked the code and it's P1128 for a long-term "fuel trim lean code" via the MAF sensor. To me, I don't know if this is from the E85 or not? Here's a quote for the code: "One of the most common codes we see on OBD-II Volkswagens is P1128, a long-term, fuel trim lean code. Any unmetered air introduced into the engine can cause P1128 to set.”
I added 4 gallons of 87 octane gas on top the mix and I cleared the code and it has not reappeared. What do you guys think? Man, I really need to read a bit more on E85
Old 10-21-2005, 04:20 PM   #144
icantdrive75
Member#: 69663
2004 WRX
Java Black Pearl
Yep its from the E85. I don't remember what causes it but I remember reading that E85 does cause that to happen. I bet someone else will explain it in more detail.
icantdrive75 is offline   Reply With Quote
Old 10-21-2005, 05:33 PM   #145
Revision
Member#: 242
MY05 PSM GGA !STOCK
Go back to page one of this thread and read Hotrod's explaination of what happens to stock cars running E85. Basically you were running lean because you were running more ethanol than the computer/injectors could compensate for.
Old 10-24-2005, 12:48 AM   #146
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Ethanol carries oxygen in it. That would be "unmetered oxygen" if you think about it. It didn't pass by the MAF .
Would you guys mind goofing off with this a bit? I'm trying to get the page "tuned right". The sound files open okay for some but not for others. It's optimized for IE.
http://www.gt-labs.net/e85conversion.html
Old 10-24-2005, 12:19 PM   #147
tmarcel
Member#: 7555
Good point! I was trying to understand the MAF/O2 relationship or was it just some weird VW code
Old 10-27-2005, 10:50 PM   #148
hotrod
Member#: 14141
2002 Impreza WRX
The fuel trim code takes a while to come up from what I can tell. The fuel trims need to stay at max for a few days (at least on a WRX before it will throw the code).
It will clear in a few driving cycles after you add enought gasoline to get it off of max fuel trim.
The code is because the ECU is running maximum allowed enrichment to get to stoich mixture under light throttle cruise. If it took that long to throw the code you are near the limit so you could likely get away with slightly less E85 on a continuous basis.
Larry
Old 10-27-2005, 11:01 PM   #149
tmarcel
Member#: 7555
You've got to be right on this one, Larry. The CEL light never reappeared since then . Defnitly must've been it!
Old 10-28-2005, 12:05 PM   #150
trininox
Member#: 62131
2005 Impreza WRX STi
Crystal Grey Metallic
News Her she goes
Deleted
trininox is offline   Reply With Quote
What do you need to do to use E85 fuel? wantsti Rocky Mountains Impreza Club Forum -- RMIC 37 02-20-2014 01:27 AM
E85 fueling question- 850cc + fpgreen...adjustable FPR? Blown95ImpalaSS Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-29-2009 07:37 PM
E85-Fueled Z06, 30th Anniversary Corvettes to Pace ‘08 Indy 500 AVANTI R5 Non-Subaru News & Rumors 0 12-27-2007 01:56 PM
E85 fuel available now in Arvada 9/22/06 hotrod Rocky Mountains Impreza Club Forum -- RMIC 9 09-25-2006 02:29 PM
E85 Fuel in Austin? When? dromango Texas Impreza Club Forum -- TXIC 8 06-29-2006 01:32 PM
