Welcome to the North American Subaru Impreza Owners Club Wednesday May 27, 2015
Old 07-09-2005, 01:37 AM   #1
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Default What do non-2.5GT BDs have instead of side skirts?
My side skirts have just about had it on the ol' '97 2.5GT - they're faded a bit, and probably 1/2 the clips on the back are broken. They've gotten warped a bit since the clips aren't holding them in place properly, so the driver side one in particular I occasionally catch with my heel when I get out of the car, which of course doesn't make the warping any better.
If I pull the side skirts off completely, I'll be left with a bunch of holes along the rocker panel where the pop-in white clip thingies go to hold the 2.5GT skirts on. Do the non-2.5GTs have different rocker panels, or are there inserts of some sort to plug those holes?
Thanks,
Pat Olsen
'97 Legacy 2.5GT sedan
Old 07-09-2005, 08:17 AM   #2
AFBeefcake
Member#: 27874
2002 WRX 6MT 312whp
05 LGT
Well when I compare a 98 GT to a 97 L. On the L the holes that the white clips go into are not there. So If you wanted to put the side skirts on a L you would have to drill the holes. So it would look like you would have to have the holes filled if you removed your side skirts.
AFBeefcake is offline   Reply With Quote
Old 07-09-2005, 02:56 PM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Just pull the rocker coversd off and buy new clip pins.
Oh, BTW, I am looking to score a set of TE-37's, 15 x 7 for autoX use.
How much of a difference in gearing do you find? I believe the ones I am getting are 225/50-15 which are the same size as yours. I am hoping to avoid 1st gear usage in autoX.
Old 07-09-2005, 04:25 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Bummer.
The problem is that a number of the slots on the rocker skirts that the clip pins slide into have gotten torn/cracked. So new clip pins wouldn't really help the situation, if I want to fix it I would need to get new skirts, which kinda sucks.
Honestly, 225/50-15 is the only size I've ever run for auto-x and open track, so it's tough to say how much of a gearing advantage there is. Obviously there is one, the numbers don't lie. I very, very rarely have to use 1st gear, but I think that's a matter of course design more than the car specs. Other than high-revvers like S2000s or ITRs, I think my gear selection is typical of just about everyone else out there - mostly 2nd gear, 1st on really slow corners, occasional burst of 3rd on a really fast section.
Pat
What would OT do? ATM gave me a $10 instead of a $20 2k2 Off-Topic 26 11-01-2008 09:12 PM
what kind of side skirts are they? vvafivv Interior & Exterior Modification 4 12-28-2006 01:39 PM
00-01 2.5RS (sedan) door pannels and side skirts and a pillar:) lots of stuff Keith Private 'Wanted' Classifieds 5 04-23-2004 01:49 AM
greddy lip...what kind of side skirts and and rear lip? JLWRX Interior & Exterior Modification 6 10-23-2002 11:19 AM
Why do rally drivers sit on left instead of right? Tribol Motorsports 1 06-15-2002 05:59 PM
