Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 07-09-2005, 02:11 AM   #1
syoung0298
Member#: 84772
2005 GDB STI
Default Help: Just installed Hydra on 05 STI: throttle feels unnatural
As noted in the message heading, I just finished installing a hydra on an 05 STI and everyhting seemed OK until I took the c ar out for a spin. The first thing I noticed was that the throtttle did not seem very responsive and lacked crispness. Almost like there was a 1 second lag before the throttle responded. I did make sure that I calibrated the throttle before testing and verrified that these settings were OK. In fact they were. The other thing I noticed is that when I shut the car off it seems to sputter a bit before turning off. Almost like an older carburetored car with a sticky throttle or choke.
What adjustments should I look into to fix my throttle response issue and the rough shutdown issue.
Any help would be greatly appreciated.
syoung0298 is offline   Reply With Quote
Old 07-09-2005, 04:19 AM   #2
supermarkus
Member#: 6971
2008 WRX STi
SSM
your best bet is to get in touch with Phil at element tuning asap.
supermarkus is offline   Reply With Quote
Old 07-09-2005, 08:48 AM   #3
syoung0298
Member#: 84772
2005 GDB STI
Just shot Phil a PM..
Anyone have any insight?
Old 07-09-2005, 12:56 PM   #4
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
According to your PM it sounds like you may have altered your map accidentally so I sent you the original to restore it.
The throttle does feel different with the Hydra vs. the OEM ecu due to the different acceleration rates. The OEM ecu has a very high acceleration rate while the Hydra has a linear throttle. The OEM ecu will give your more throttle than you give it while the Hydra will be smoother so it takes more pedal angle to feel the same as the OEM ecu due to the difference in acceleration rates. Most will only notice this right off of idle. I noticed yesterday on a car I tuned this was most pronounced and we found that his BOV was open during idle and until it snapped shut the throttle was dead for a second but unfortunately no way to adjust this BOV.
There are so many other adjustments that can be made, such as ignition timing which we send out about 3-4 degrees shy in some areas so that AFR can be verified and adjusted without fear of detonation. Once this is confirmed ignition timing can be increase. Also make sure you’ve turned on the “closed loop” function as this isn’t enabled since some customers rush the install and don’t install the WB.
Call during the business week and I can guide you in making adjustments or send me an email [email protected]
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 07-14-2005, 03:33 PM   #5
supermarkus
Member#: 6971
2008 WRX STi
SSM
any update on this?
Just installed VF22 on the STi has a coolant leak...please help ioeth Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-24-2008 10:53 PM
just installed vf39 on a 02 wrx CEL mistaanime Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 12-11-2007 01:09 PM
Kartboy rear endlinks installed on 05 STi: dchou Brakes, Steering & Suspension 4 03-22-2006 11:05 AM
Just installed GC's on MY03- problems 2003forcefed Brakes, Steering & Suspension 21 04-01-2003 02:18 PM
Just installed SS brake lines & clutch feels softer I drive a WRX wagon Transmission (AT/MT) & Driveline 3 04-10-2002 04:07 PM
