Old 07-09-2005, 02:26 PM   #1
Zebceponaf
Member#: 71371
'98 OBS
Exclamation 98 impreza 2.2 timing belt questions
Quick question here, I've got everything off right now except the TB tensioner. Looking at the guides I've seen (endwrench) their tensioner is different than the one on my car. Anyone know how mine works? Diagrams/links/drawings would help alot.
Thanks,
Ray
Zebceponaf is offline   Reply With Quote
Old 07-10-2005, 11:36 AM   #2
kheff46
Member#: 66739
2002 WRX wagon
your tensioner should have a piston(in the center) with a hole drilled through the side of the tensioner body and the piston shaft. you can just undo the tensioner and remove. but you must compress the piston back in before reinstalling, so you can "pin it" (insert allen key of the 1.5-2.5mm size all the way through piston and both sides of the body). you'll need a bench vise or brake press to compress it probably. you should be able to route belt fine and may have to install the toothed idler pulley(drivers side bottom) last. you may need to hold pulley at an angle to find the threads in the block with idler bolt. put bolt into hole then straighten pulley as you thread bolt in! VOILA! you should have no prob., but make sure your timing is still on the marks, i had to redo mine. somehow the drivers side cam jumped a tooth while trying to insert the idler bolt. but the second time it took less than an hour to do! pm me or keep postin' if you need help!
kheff46 is offline   Reply With Quote
Old 07-10-2005, 03:33 PM   #3
cooparu
Member#: 67767
2010 WRX
Red
http://www.geocities.com/ak_monkeybo...9709A29988.pdf
Maybe this will help. I have a 97, and it seems that Subaru went from the type I have (and the one in Endwrench) to this new type sometime in 97. When I downloaded the service manual, it had info for both types of tensioner.
cooparu is offline   Reply With Quote
Old 07-11-2005, 10:40 AM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Just compress the piston slowly. I believe they suggest ~3 minutes for the full compression.
If you bang it hard and fast, you "may" blow the seal.
Old 07-11-2005, 12:05 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I highly recommend against re-using that tensioner. That new style with the integrated pulley is known for going bad and making it clack when re-used. A number of guys I know have retro'd theirs to the old pistons style because of this...
Old 07-12-2005, 09:22 AM   #6
kheff46
Member#: 66739
2002 WRX wagon
if his car is a 1998 wouldn't that be the "new" version?
what does the old style look like? and why is it better? thanks!
Old 07-13-2005, 12:30 PM   #7
cooparu
Member#: 67767
2010 WRX
Red
Old 07-13-2005, 07:36 PM   #8
kheff46
Member#: 66739
2002 WRX wagon
definately not the same as mine!
thanks for the pics!
$60: 95 - 98 2.5L timing belt, oil filter, Haynes manual, headlight bulb, grill clip 98GTlegacy 1993 - 2001 Impreza Specific Parts 0 03-07-2010 01:07 PM
Timing belt question on '00 2.2 eppoh Service & Maintenance 0 02-01-2010 07:02 PM
2.2 L timing belt & engine damage 2000ImprezaWagon Service & Maintenance 6 08-29-2007 04:29 PM
96 impreza 2.2L timing belt and water pump installation guide sjtangb21 Normally Aspirated Powertrain 0 03-25-2005 09:36 PM
2.2 and 2.5 timing belt DJIMPREZA Normally Aspirated Powertrain 3 02-02-2004 05:55 PM
