Old 07-09-2005, 05:25 PM   #1
mavx5
Member#: 55384
2007 335i
Question Rear Diff Fluid leak - 04 STi
I went to Mr. Tire earlier this week to get a flat tire taken care of, when the tech noticed that the rear diff was leaking fluid. So, I took it to Subaru near my house, and they gave it a look over. They said that "someone" overfilled the reservoir, and it was leaking out.
Now since I don't work on my car, and I do all my maintenances at this Subaru dealership, I'm guessing that they overfilled it during my 15K service.
They said it shouldn't harm anything, but my confidence in them isn't all that high anymore. Does anyone have any thoughts? Does overfilling the rear diff reservoir cause any damage in the short or long term?
mavx5 is offline   Reply With Quote
Old 07-10-2005, 01:35 AM   #2
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
I have a hard time understanding how they may overfill the rear diff. It's near impossible. The rear diff is the easiest fluid change, especially for a dealership since they have the right tools. You don't have to measure how much you need to fill it.
There are two plugs in the back of the case, a top and bottom. All they have to do is drain it from the bottom plug, the tighten the bottom plug back on. And fill the diff from the top plug until it pours out. It just needs to be level with the top plug. It's not bad if it's a bit over the plug, which will drain out after you fill it.
I do not blame you for a lower confidence in them. In fact it's so hard to believe, that I think they might be hiding something.
Here is a pic to give you an idea.
-paK +3
Pakin is offline   Reply With Quote
Old 07-10-2005, 02:50 AM   #3
Vew
Member#: 74229
2004 PSM WRX
Yeah... I agree with the guy above. You basically fill it until it leaks, let the excess drain, and cap it. Maybe they didn't torqe it correctly or use the Three Bond stuff. It's a liquid gasket you're supposed apply to the threads before recapping it. Kinda expensive, like 15 bucks at the dealership.
Vew is offline   Reply With Quote
Old 07-10-2005, 04:07 PM   #4
mavx5
Member#: 55384
2007 335i
Thanks for the input folks! I think I'll set an appointment with another Subaru dealership in the area and have it checked out.
Old 07-10-2005, 06:32 PM   #5
ADR 04STi
Member#: 51918
2015 Audi S3
Daytona Gray
Question
Pakin: Thanx for the above instructions. Ill be changing mine very soon.Very handy.
ps: Do you have others? Front Diff & Center. .I could use them too.
ADR 04STi is offline   Reply With Quote
Old 07-11-2005, 01:48 AM   #6
majmun
Member#: 18298
2004 STi
The front and center differentials share lubrication with the transmission.
majmun is offline   Reply With Quote
Old 07-11-2005, 02:36 AM   #7
JPX
Member#: 44504
1996 Legacy L Sedan
My Legacy's rear diff has been leaking for years. It is coming from the passenger side between the diff body and the seal plate. I had intended to change it when I changed the wheel bearing, but the parts were not available and I needed the car back on the road.
How the hell can anyone overfill that thing? As Pakin's procedure shows, the oil spills out when you reach capacity.
JPX is offline   Reply With Quote
Old 07-11-2005, 10:39 AM   #8
singletrack
Member#: 42440
04 Impreza WRX STi
Platinum Silver
Why did they change the oil at 15k miles? The schedule does not call for that...
singletrack is offline   Reply With Quote
Old 07-11-2005, 06:58 PM   #9
mavx5
Member#: 55384
2007 335i
I am not sure, that is the "story" they gave me. They probably thought I didn't know better (at the time, I had no idea if they were telling the truth or not). I've already set an appointment with another subaru dealership 10 miles away. Lets see what they have to say...
Old 07-11-2005, 07:25 PM   #10
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
...overfilled the rear differential? wow...it takes skills to do that. You must've had one masterful technician working on your car...
And I don't know about that Three Bond liquid gasket stuff, I simply cleaned off the threads, torqued it down to spec, and I haven't a drop of gear oil from the rear.
eltrouble is offline   Reply With Quote
Old 07-11-2005, 09:59 PM   #11
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Yes, you don't exactly need any sealant for the drain/fill plugs. They are pipe threads, which are tapered and provide the sealing.
-paK +4
Old 07-25-2005, 05:49 AM   #12
Blue_Diamond
Member#: 55255
2003 MY04
WRC BLUE
one thing you can do is clean the oil off the rear diff and see if it comes back... i had a prob with mine also and subaru said that the guy who filled the rear diff prob forgot to wipe off the excess... but i already checked that by wiping and cleaning it so that i couldn;t see any oil... but then it came back so it had to be leaking...
Blue_Diamond is offline   Reply With Quote
Old 07-26-2005, 09:08 PM   #13
sjrhee
Member#: 68010
2004 WRX w/ Cobb 2.5
Wierd...I thought rear diffs are a sealed unit? Where would it leak from? if it's from the drain/fill plug area, it could mean the bolt was cross threaded.
sjrhee is offline   Reply With Quote
Old 07-28-2007, 08:47 PM   #14
20swrt
Member#: 50186
9804 WRX, RS25 coupe
WR Blue
Default overfill differential
Actually, its very easy to go beyond 0.8 quarts when filling up the differential. I actually just overfilled mine - and im a newbie. My driveway is slightly inclined. So when I filled it up - i consumed about 1.2 quarts. I guess overfilling rarely happens at dealerships coz they have lifts.
So experts - let me know how bad is this. Even with normal levels - part of the gear is immersed in oil which in turn lubricates the rest of the differential. This is unlike our engines where overfilling actually causes slushing/foaming which is bad when crank is splashing the oil around.
20swrt is offline   Reply With Quote
Old 08-04-2007, 12:54 AM   #15
proletariandan
Member#: 88436
in t he market again
There's no way its going to spill out if it is a little overfilled. There is a vent at the very top of the axle cover but it is WAY above any amount you could get in through the fill hole. My rear diff was leaking on the car I just bought and on closer inspection I found out that the rear axle cover was cracked from the drain hole to the bottom where it seals against the axle/differential housing. The previous owner or whoever he had change his fluid clearly tightened the bolts too much as the recommended torque is something like 35ft/lbs and I had to use my foot on a large ratchet to get both plugs out. I probably could have just HondaBond'ed the crack but I decided to play it safe and replace the cover/gasket and thanks to that decision my car has been on ramps/jacks for more than a week waiting for a gasket
proletariandan is offline   Reply With Quote
Old 09-06-2007, 01:40 AM   #16
Triplex
Member#: 153459
2005 Impreza STI
gray
Nice Info guys Thanks!
Triplex is offline   Reply With Quote
Power steering fluid, manual tranny fluid, and rear diff fluid ex_boyometric Vancouver Impreza Club Forum -- VIC 17 03-09-2008 05:54 AM
04 WRX Rear Diff Fluid Change - Ok to use Mobil 1 Synthetic? SC2000 Transmission (AT/MT) & Driveline 2 02-21-2008 02:18 PM
Tranny Fluid and Rear Diff Fluid? Stellar1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 03-07-2005 12:22 AM
Rear diff fluid & tranny fluid rich22 Service & Maintenance 7 05-06-2004 10:04 AM
WTB: Redline Tranny fluid and Rear Diff fluid RimRockaz Bay Area Impreza Club Forum -- BAIC 11 07-16-2002 03:19 PM
