Old 07-09-2005, 07:42 PM   #1
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Default Aeromotive Adjustable FPR
Okay, I think I am finally going to ditch my stock FPR and get the Aeromotive Adjustable FPR for $149.00 at a local shop. To my understanding, all I would need to do is get two barb fittings and connect both lines off my rails (parallel) to the FPR.
Is anyone here using this particular setup? If so, please let me know how you like it or perhaps throw out some advice. Thanks.
-Brett
2001 RS (Stock EJ25), TD04L, E-Manage, RC440cc, WRX Fuel pump
ExecNav is offline   Reply With Quote
Old 07-10-2005, 03:44 PM   #2
darioc
Member#: 35695
02 RST
98 Outback 92 Wrangler
i can sell you one that i have for $40. its a 4:1 rrfpr. i just dont need it anymore. let me know if you are interested!
darioc is offline   Reply With Quote
Old 07-10-2005, 04:56 PM   #3
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
How is your rising rate FPR anything like the aeromotive adjustable FPR?
-Brett
Old 07-10-2005, 05:19 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
You will need a special fitting to adapt the hose off of the stock fuel rail. If you look at the stock FPR, you will see that it screws into a flange on the end of the fuel rail.
Any particular reason you want to ditch the stock FPR?
Old 07-10-2005, 06:02 PM   #5
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
When I did my parallel lines, I had to hack that bracket off anyways and relocate it. I have an adapter on that flange with a barb fitting on it that will allow another input. I have two fuel lines running into my FPR right now. Both are rubber fuel injection line. With a couple barb fittings that screw into the FPR, this thing should go right in.
I suspect that with the 440 cc injectors and the WRX fuel pump, the stock fuel pressure regulator is getting a major workout at idle. I can actually hear air hissing out of the FPR and I have no clue how or why.
It would also be nice to have a little more control of the fuel pressure. The 1/8 npt for a gauge wouldn't hurt either.
-Brett
Old 07-11-2005, 09:27 AM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
This hissing would indicate a leak in the vacuum side of it, with the vacuum line form the manifold.
In our case, it would be as easy as putting hose barbs on the FPR and putting it in line, yes. Though you have to be aware that the fittings that go into the FPR need to be o-ring seated, as they are not tapered thread, nor do AN fittings bottom out in them. They sell special fittings just for that purpose.
Old 07-11-2005, 10:40 AM   #7
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
I have replaced that hose twice now and the hissing is still there so I do believe it's the dry side of the FPR... still an issue regardless...
Thanks for the info on the barb fittings. I'll be sure to add Orings to my Christmas list.
-Brett
Old 07-11-2005, 11:38 AM   #8
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Well, the fittings on the unit are AN fittings with o-rings on them specifically. Kinda strange, it goes against what an AN fitting really is, yet they still call it AN. *shrug*
Kinda like this:
FS: Aeromotive A1000 fpr fdrx7 Engine/Power/Exhaust 2 11-23-2007 03:44 PM
fs: GTSpec intercooler splitter(gc/gm) and aeromotive adjustable FPR akcel Private 'For Sale' Classifieds 0 04-02-2005 05:40 PM
fs: greddy EGT w/probe,greddy fp w/snsr, aeromotive adjustable fpr, and some gc stuff akcel Private 'For Sale' Classifieds 5 10-08-2004 02:16 AM
Adjustable FPR (bolt-on) JustDSM Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-01-2003 07:36 PM
Will this MSD adjustable FPR work along with the Vortech FMU? scootr Normally Aspirated with bolt-on Forced Induction Powertrain 4 11-15-2001 11:48 AM
