Old 07-09-2005, 11:26 PM   #1
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
Default Emanage Ultimate July 12!!!
O my god.
for those of you that appreciate the next generation, or what should properly be described as a revolution for anyone interested in tuning cars......
check out the emanage ultimate.
http://www.mohdparts.com/emanage/ult...res/index.html
The thing has completely blown my mind. It has features and the ability to do things that aftermarket forced induction has never seen.
I don't care what it costs I will have one the day it comes out. Anyone who has ever worked with a emanage or a utec will realize the power of the emanage ultimate. It dwarfs anything that is currently in circulation by so much its not even compairable.
my mind is blown....
Todd
did I mention my mind is blown?
Hitokiri is offline   Reply With Quote
Old 07-09-2005, 11:57 PM   #2
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
the most amazing features to note:
- it will allow you to convert MAF car to MAP entirely...... no bull**** this time. It allows full customization of airflow sensor output for the stock ecu - as well as emulation of the air temp sensor in the MAF for the stock ecu.
- airflow correction for bigger injectors is now done by trimming the injection pulses to the injectors after the ecu....... up AND DOWN..... Did that blow your mind yet? If it hasn't yet it should have... NO more ignition modifications by the stock ECU seeing corrected load values.... in fact, no more issues with airflow correction AT ALL!!!! OMG!!!! can you imagine it!!!!!
- it has special maps to control coolant temp and intake air temp modifications......
- it has special maps for ingition modifications under throttle pump conditions!!
- it does remote map switching!!!
- it has a map that modifies the fueling to compensate for differing loads at different vehicle speeds!!!! can you achieving yout target AFR perfectly at any speed, in ANY gear!!!?!?!?!?!? I can't
- it datalogs at 50 times / sec!!!!! and also has programming to display the actual ingnition timing!!!! no more logging the stock ecu and applying your ignition modifications to it!!!! It does it for you!!!
- It reads and displays knock!!!!!
- there are so many features.... go look for yourself....
I need to go to bed..... my brain hurts...
Old 07-10-2005, 12:51 AM   #3
dvang
Member#: 84188
05 legacy
caravan full of kids now
stop smokin so much weed than..
dvang is offline   Reply With Quote
Old 07-10-2005, 01:37 AM   #4
rac
Member#: 48594
1997 us2.5L ver3 sti
white
I think I'll keep my Autronic sm4
rac is offline   Reply With Quote
Old 07-10-2005, 03:08 AM   #5
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
you gotta admit its alot for $550
fully mapable AFR target and autotuning
indifidual cylinder spark and ignition trim maps
in a piggyback!!... for $550???
Old 07-10-2005, 03:16 AM   #6
rac
Member#: 48594
white
Yes Very cheap/feature.
I would like to see more use of per cyliner fueling, i might hook up 4 egt sensors one day just to have a look.
Old 07-10-2005, 05:11 AM   #7
1SIKWRX4U2NV
Member#: 24358
I miss boost...
*cough-cough* ultimate began shipping the end of last week...though the first car to be tuned with it is almost done.
1SIKWRX4U2NV is offline   Reply With Quote
Old 07-10-2005, 10:18 AM   #8
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
i am sooo excited. Mine is shipping out this week
Old 07-10-2005, 07:34 PM   #9
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
now...if only there was a way to raise redline...
IllNastyImpreza is offline   Reply With Quote
Old 07-10-2005, 10:19 PM   #10
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
IT DOES IT!
is our readline fuel cut? or ignition cut??
if its a fuel cut redline (which it most likely is) then there is a good chance the ultimate can raise it.
greddy emanage ultimate... jasonjkl Engine Management & Tuning 10 11-27-2005 09:08 PM
anyone running the emanage ultimate? IllNastyImpreza Normally Aspirated with bolt-on Forced Induction Powertrain 21 10-27-2005 01:30 PM
Greddy Emanage Ultimate $600 shipped jeffg Private 'For Sale' Classifieds 1 09-27-2005 01:23 PM
Greddy Emanage Ultimate?!?!? wannabejdm Engine Management & Tuning 1 09-06-2005 11:08 PM
Emanage Ultimate 1SIKWRX4U2NV News & Rumors 17 06-29-2005 12:58 PM
