Old 07-10-2005, 07:07 PM   #1
pux888
Member#: 8356
02 STi swap
12 WRX limited
Default sbc-id and EWG ?
im running a tial 38mm w/ a 7 lb spring, i cant reach more than 22 psi then down to 20 at redline. anyway my real ? is when i was setting up the warning level on the bc i set it to 10psi at 100% to see how well i would react. by doing so it spiked to over 23psi, instead pulling boost. it will not pull boost at any level. do i have the lines going to the WG wrong? it controls boost well but i dont understand why the safety function doesnt work.
pux888 is offline   Reply With Quote
Old 07-10-2005, 08:01 PM   #2
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
If you want to run that much boost I would get a stiffer spring. Usually you don't want to go over twice the pressure of the spring. Now on my car i have been able to reach 25lbs of boost with a 7lb spring and it held rock solid so i'm not sure if thats your exact problem though. Might want to try a stiffer spring though.
dan avoN7 is offline   Reply With Quote
Old 07-10-2005, 08:12 PM   #3
pux888
Member#: 8356
02 STi swap
12 WRX limited
well thats not really the ? im trying to find out why my safety features are not working on the sbc w/ the EWG.
SBC ID and Power Meter ID and Turbo Timer jaywrx Private 'For Sale' Classifieds 13 08-15-2003 04:33 AM
Difference between Blitz SBC-ID and SBC-DC? Dougeefresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-30-2002 12:00 PM
Anyone with SBC-id and PM-id use the RPM Boost function?? Need Help!! smiles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-16-2002 10:20 AM
Blitz SBC-ID and power meter id installed DreamWalker Interior & Exterior Modification 0 10-31-2001 12:39 PM
what do you guys think about the Blitz SBC-id and Power meter-id? illmatic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-25-2001 11:02 PM
