Old 07-10-2005, 09:16 PM   #1
LIDGUY
Member#: 26900
1988 Fiero Countach
G5 Rally Car
Default Water Pump Failure
I am posting for a friend deciding whether to self repair a failed water pump on his daughter's mid 90's legacy 2.2 or have it done professionally. He is weighing the probable cost of professional repair (any estimates/ guesses?) v. the difficulty of doing the job himself having no experience with Subarus. He has had much past experience repairing and rebuilding Ford and Alfa fours but was unsure how long or intensive the repair might be on the flat four layout were he to get a manual a go for it himself. Any thoughts?
LIDGUY is offline   Reply With Quote
Old 07-11-2005, 09:17 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
You gotta take off the timing belt to get at the pump. Once the belt is off, replacing the pump is cake.
Here's instructions for replacing the belt
http://www.main.experiencetherave.co...ming_belt1.jpg
http://www.main.experiencetherave.co...ming_belt2.jpg
http://www.main.experiencetherave.co...ming_belt3.jpg
http://www.main.experiencetherave.co...ming_belt4.jpg
http://www.main.experiencetherave.co...ming_belt5.jpg
http://www.main.experiencetherave.co...ming_belt6.jpg
http://www.main.experiencetherave.co...ming_belt7.jpg
http://www.main.experiencetherave.co...ming_belt8.jpg
Also, here are pictures of the motor, which should give him some visuals of what he's going to need to do.
http://www.main.experiencetherave.co.../images/ej22t/
If he has had some mechanicing experience and has tools, he should be able to handle it. You're probably looking at, at least 400 bucks to replace the pump.
Also, depending on the miles, and if the t-belt has recently been replaced, it's probably be a good idea to replace the belt, and the front cam & crank, and rear pass cam o-ring seal.
Here's pics of my timing belt job. I also replaced the o-ring behind the oil pump.
http://www.main.experiencetherave.co...ges/timingbelt
If he's got any questions, just holler.
Josh
Legacy777 is offline   Reply With Quote
Old 07-11-2005, 09:30 AM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
I did it on my 98 DOHC 2.5L, not really any problems, it is just a little more work than doing the timing belt.
IIRC, I bought a new Bosch water pump for ~60 and did all the belts/hoses as well while at it.
I just used ramps, made it easy to get to the top and bottom of the engine. I think it was ~2.5 hours total while having some beers as well.
Old 07-11-2005, 11:26 AM   #4
LIDGUY
Member#: 26900
1988 Fiero Countach
G5 Rally Car
Much appreciated guys
Old 07-11-2005, 11:53 AM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Yeah,
pretty striaghtforward work. With his experience, your buddy should have no problems. If Charlie did it in 2.5 hours, he could do it in 2...
Old 07-11-2005, 12:52 PM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Matt, bite me.
Water/meth injection water pump question atomic4877 Water/Methanol Injection, Nitrous & Intercooler Cooling 3 09-24-2009 05:29 PM
Groing from NA Legacy Water Pump to WRX Water Pump lgt2000 Normally Aspirated with bolt-on Forced Induction Powertrain 2 06-25-2007 09:38 AM
Water pump gasket failure pilfflip Legacy Forum 11 01-15-2007 10:32 PM
FS: Water pump and oil pump jblaine Private 'For Sale' Classifieds 2 09-28-2005 12:35 PM
Water pump failures? overdose Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-30-2003 11:41 PM
