![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 59353
Vehicle:2003 2.5 TS-Turbo Pearl Ridge Blue |
Hello guys and gals, quick question. How do you remove the wheel studs? Just pound them out with a hammer? Should I remove the brakes and rotors too? I have one stripped and I don't think trying to just use a die it is such a good idea, or will that work? Thanks for your help, again with a dumb question.
#2 |
Member#: 28716
SCIC
Vehicle:2006 STI |
Seems like you know what to do. Generally, the rotor has to come off which means the caliper has to come off too. You can use a die if the threads aren't buggered too much, but use your better judgement.
#3 |
Member#: 18777
Vehicle:2002 WRX Wagon Sedona Red Pearl |
They have a notch on the back of the hub. Spin the wheel so that the broken stub lines up with the notch and bang it out. I have done it without taking the rotor off but it does make it a lot easier.
#4 |
Member#: 32018
SCIC
Vehicle:2008 M3 Sedan Interlagos Blue |
yeah I pounded it out with a hammer, kind of scary since you got to hit it very hard. I removed the caliper and rotor before doing it
#5 |
Member#: 59353
thanks a lot guys! came out just fine, although pounding in a new one is a bit tricky, you sortof have to hit it at an angle.
#6 |
Member#: 61088
E. Canada
Vehicle:2003 Impreza WRX World Rally Blue Pearl |
When removing a wheel stud, I put an old closed end lug nut over the stud before using a BFH. It prevents musrooming the stud end.
When fitting a new stud.. why not use an openended lugnut, wrench it down and have it pull the new stud into place? |
#7 |
Member#: 22412
SWIC
Vehicle:2012 Legacy 2.5GT Ice Silver Metallic |
Nice writeup for a rear one on scoobymods
http://www.scoobymods.com/forums/showthread.php?t=4247 |
#8 | |
Member#: 24069
Vehicle:2013 Legacy Blue |
#9 | |
Member#: 18777
#10 |
Member#: 67004
SCIC
Vehicle:02 vf30 pnp wagon silver and cf |
subscribe for future info
| Thread Tools | |
| Display Modes | |
| Removing Studs from Top Hat | motocooney | Brakes, Steering & Suspension | 15 | 03-13-2010 09:57 AM |
| Got turbo stud out using stud remover *pic* | jobber | Factory 2.0L Turbo Powertrain | 8 | 08-01-2008 09:54 AM |
| removing studs for up pipe removal | turbo_wagon | Factory 2.0L Turbo Powertrain | 5 | 12-21-2007 07:32 AM |
| where to remove stud? | vrgs | Vancouver Impreza Club Forum -- VIC | 32 | 11-26-2007 11:18 PM |
| removing studs | soobster_2003 | Newbies & FAQs | 3 | 11-18-2007 09:49 PM |
