Old 07-11-2005, 09:32 AM   #1
83Rabbit
Member#: 5050
Default Pass side inner cv boot 1994 AWD impreza
how hard are they to replace? Can I do just the boot or do I need to do the entire axle? Whats involved? Thanks in advance.
83Rabbit is offline   Reply With Quote
Old 07-11-2005, 01:14 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
I'd recommend just replacing the whole axle. If the boot is torn at all, you really can't say with any definitiveness when it torn, and how much dirt/grime got in there and contaminated the grease/bearing. You can pickup reman'd axles for like 55 bucks. I'd recommend www.cvaxles.com
As for what's involved. Jack up the car, remove the sway bar mount to the A-arm, loosen the bolt holding the front part of the a-arm to the chassis, remove the big nut holding the axle to the hub, punch out the spring pin on the axle, wiggle the axle out, re-assemble. Note, the axle has a chamfered end that the spring pin goes INTO. If you try to punch it in from the other side, you'll be sorry. Note, when you drive the spring pin out, drive it out from the NON-chamfered side.
Legacy777 is offline   Reply With Quote
Old 07-11-2005, 04:25 PM   #3
83Rabbit
Member#: 5050
chamfered?
Im not sure I understand the spring pin thing an where it goes into...
Ive replaced many a honda and VW axle...
Old 07-11-2005, 10:04 PM   #4
Legacy777
Member#: 4800
there's a cylindrical pin that makes sure you don't get any side-to-side movement of the axle on the axle stub.
When you look at the axle, and you'll understand what I mean
Split Inner CV Boot latigre Car Care & Detailing 2 06-03-2010 01:46 PM
Inner CV boot repair? dlh1999 Transmission (AT/MT) & Driveline 44 10-22-2007 02:24 PM
Great .... torn inner cv boot .. LegacyGt05 South West Impreza Club Forum -- SWIC 11 04-11-2007 11:21 AM
need new front inner CV boots - Phoenix, AZ gharari South West Impreza Club Forum -- SWIC 16 10-13-2006 10:09 AM
Smoking turbo turned out to be a torn inner CV boot (long post) Paulie Transmission (AT/MT) & Driveline 8 05-12-2006 04:52 PM
