Old 07-11-2005, 11:03 AM   #1
Ramon_12345
Member#: 72021
1999 JDM GC1 IMPREZA
WHITE
Default IAC Valve?
Yesterday morning I started the car to go to church and no sooner than I started and moved off, the engine revs started to “beat down” like if the car wanted to cut-out and I even smelt petrol. However as I continued to drive the car the problem vanished.
This morning I started it and the same thing happened however I noticed that it only occurred initially when I eased the car forward and stopped. However as I continued to drive the car, the problem seemed to have vanished as I could drive in stop-and-go traffic without any incident.
My question is, what could be the problem? I suspect a sticking IAC valve however any other suggestions would be greatly appreciated.
Thanks.
Ramon_12345 is offline   Reply With Quote
Old 07-11-2005, 01:09 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 5MT EJ22T AWIC Swap
what year & model car do you have? AT or MT?
Legacy777 is offline   Reply With Quote
Old 07-11-2005, 01:13 PM   #3
Ramon_12345
Member#: 72021
WHITE
1999 Impreza. Automatic Transmission
Old 07-11-2005, 01:33 PM   #4
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
There are so many things that can cause that. An IAC is a good place to start, though. Search around and you should be able to find a procedure for cleaning it. I know I saw it in here, I just don't remember where, exactly.
Al_Smokemcrack is offline   Reply With Quote
Old 07-11-2005, 03:35 PM   #5
El_Kameleon_G
Member#: 87103
2005 Impreza RS RWD
Plat'num Plus...SOLD!
how long do you warm up the car for?
El_Kameleon_G is offline   Reply With Quote
Old 07-12-2005, 01:47 AM   #6
Ramon_12345
Member#: 72021
WHITE
I usually just get in and drive at about 50 km/h until the engine gets to its normal operating temperature and then I usually drive faster if I have to but I don't until the car is warmed up.
IAC valve replacement? Pi7467mp Service & Maintenance 12 03-05-2005 08:53 PM
Need an IAC valve asap! Someone please send me one! Si2WRX Factory 2.0L Turbo Powertrain 0 07-13-2004 02:09 PM
IAC valve subiekid Subaru Conversions 1 10-04-2003 08:00 PM
Looking for IAC valve for 2002 WRX pjcoregon North West Impreza Club Forum -- NWIC 0 05-20-2003 12:46 PM
2.2 ECU on 2.5 motor.. IAC valve problem Murray Engine Management & Tuning 6 12-30-2002 11:01 PM
Message Board Statistics All times are GMT -4. The time now is 12:45 AM.
