#1 |
Member#: 30512
Vehicle:01 2.5rs black |
Greetings. I have a 2001 impreza 2.5 rs 5 speed, and two of my modifications have been a lightweight crank pulley and a lightweight flywheel. Although for about a year they never threw a misfire code, it seems that they have been recently. I have been planning on selling my car, so the other day I cleared my misfire code and went to smog it. It passed every test perfectly, visual, emissions, ect but I failed because of a "CEL/MIL" error and it elaborated by saying "this vehicle failed the MIL/Check Engine Light Test due to failure to successfully complete all OBD self tests. My understanding is that because the code had been cleared so near to the smog, that maybe it hasnt gone though enough cycles to have performed these tests. Since then I have driven 115 miles with no misfire codes being thrown, is that long enough that the ECU can go trough its two cycles? How many miles/how much time does it take for an ecu to finish its tests? Thanks in advance for your help.
-Colleen
#2 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
How did you clear the codes?
#3 |
Member#: 30512
I stopped by a dealer and they cleared it for me.
#4 |
Member#: 832
RMIC
Well,
That's the right way to clear it. Sounds like you had a stored pending CEL... |
#5 | |
Member#: 30512
#6 |
Member#: 14365
Vehicle:2000 2.5rs Silverish :D |
Might have another pending cel? Something might be wrong with your car that's not the pulleys... and did your dealer charge you? Go to Autozone or something... they pull codes for free.
| Thread Tools | |
| Display Modes | |
| Reset ECU question | nhmtns | AccessPort | 2 | 09-26-2006 10:15 PM |
| reseting ecu question | adrian559 | Engine Management & Tuning | 3 | 10-21-2005 05:31 PM |
| reseting ECU question | vapore0n | Factory 2.0L Turbo Powertrain | 7 | 10-15-2002 04:18 PM |
| ('93-'01) After resetting ECU question... | Hyudra | Impreza Forum | 0 | 09-29-2001 02:53 PM |
| Some reseting ECU questions... | IBO | Normally Aspirated Powertrain | 12 | 07-15-2001 04:37 PM |
