Old 07-11-2005, 06:16 PM   #1
snoodge
Member#: 63774
2004 WRX Wagon
Default aligment issues....
so I take the subie to the dealer for that overpriced 30k service. I had irregular wear on the front left tire, bald on the inside but normal on the outside and adjacent tire. Pressure is not an issue, I check it regularly. I thought it was a camber issue or something and I finally get the call that my alignment was off, and this is what caused 1 tire to wear out in one section. So now the 500$ service has quickly turned into 900$. So my question is wether or not their explanation seems right and if it's possible for me to persue this a warranty issue. help before my head and wallet explode. thanks.
snoodge is offline   Reply With Quote
Old 07-11-2005, 06:30 PM   #2
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
alignment is covered one time under the 3/36 warranty, they should not charge you unless there was an outside influence such as a pothole or curb that caused it to go out of alignment.
Oh and if they cover the alignment they should cover the tire as resultant damage.
Samirr76 is offline   Reply With Quote
Old 07-11-2005, 06:34 PM   #3
snoodge
Member#: 63774
2004 WRX Wagon
he said the alignment warranty is only good till 15K!?
Old 07-11-2005, 08:50 PM   #4
Samirr76
Member#: 4835
2003 Baja 5MT
wrong its 36k
TRUST ME!
there is no 15k warranty on ANYTHING.
adjustments are covered for 3/36 just like everything else.
the dealer may be confusing subaru warranty with some other mfr if they a multi-brand dealer.
Heated Seat Issue?!? maxpower_454 Interior & Exterior Modification 11 06-05-2010 08:05 AM
IT Folks: having internet issues elucas730 Off-Topic 26 06-03-2010 02:24 PM
02 impreza headlight wiring issue garinhash Electrical & Lighting 4 06-02-2010 12:49 PM
aligment issue... MPREZD Newbies & FAQs 8 02-25-2006 12:38 AM
Need Wheel Aligement and Wheel Fix, any suggestion?? H5N1 Vancouver Impreza Club Forum -- VIC 3 12-15-2000 11:32 PM
