Old 07-11-2005, 11:06 PM   #1
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Default DBW pedal assembly questions...
Im thinkin about going wrx heads w/ a P&P or sti heads...
if i do sti heads which makes more sense i want to get the DBW enabled hydra
i found a dbw TB for cheap..now all i need is the pedal assembly...
does anyone have a hookup for everything ill need to make it work in my RS
lemme know
thanks
alex
Old 07-12-2005, 01:38 AM   #2
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
The DBW is not worth the time and effort. You will have crappier throttle response, more difficulty with downshifts and a whole bunch of extra wiring/headache getting that pedal box in.
You can get the hydra set up for whatever crank/cam trigger setup you want sans the DBW.
no-coast-punk is offline   Reply With Quote
Old 07-12-2005, 03:02 AM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
thanks for the info sir
alex
will a DBW/USDM sti pedal assembly work in Legacy GT? Leggy_09 Transmission (AT/MT) & Driveline 0 09-01-2009 09:50 AM
FS:KY DBW Throttle Body and DBW Pedal Cf Scoop 02KyRex Engine/Power/Exhaust 6 07-13-2009 05:15 PM
WTB: non-DBW gas pedal assembly triple_s1x Private 'Wanted' Classifieds 1 04-04-2009 08:07 PM
WTB: non-DBW gas pedal assembly triple_s1x MWSOC Private Classifieds 0 04-02-2009 10:10 PM
2006 STI intake manifold, DBW throttle body, wiring harness, DBW pedal Cstmboxermotorsports Engine/Power/Exhaust 0 12-11-2006 07:52 PM
