Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 07-12-2005, 03:59 AM   #1
pinter
Member#: 86472
1998 2.5RS, 2x 1995
Impreza Coupe
Default Clutch problems, need help
I have a 98 2.5 RS with 80,000 miles on it. I got the car in March, then the clutch pedal was firm from the top to the floor. Over the past 3 weeks or so I started noticing the clutch pedal started to feel softer near the top. On Saturday I was driving the car and the clutch went to the floor and stayed there. I was able to get the car to my friends house.
So I figured either the master or slave cylinder went bad. So I replaced both today and that didn't fix anything. The clutch has no resistance for the top half of travel, then it gets firm, at this point there is a squeeking noise. I'm not sure if this is from the new slave cylinder or the pressure plate. Also when bleeding the clutch, no matter how much I bleed it there always seems to be air in the line. I am using a vacuum bleeder. I checked the line from the master to slave cynlinder for leaks, and it checked out fine.
So my question is, what is broken on my car? Is the pressure plate bad? Do I just need to power bleed it? Or what else could it be?
Thanks
pinter is offline   Reply With Quote
Old 07-12-2005, 07:45 AM   #2
Ne14korn
Member#: 38929
1993 impreza
green now, will be pink
how are your seals?
Ne14korn is offline   Reply With Quote
Old 07-12-2005, 01:09 PM   #3
pinter
Member#: 86472
1998 2.5RS, 2x 1995
Impreza Coupe
All the seals are good as far as I know. Any I should check specifically?
Old 07-12-2005, 10:17 PM   #4
nwsurfwakeskate
Member#: 66117
1998 Legacy GT wagon
Bright Red
hey I'm having the exact same problem on my 98 legacy GT with 112k miles. I just got it back from having work done, they replaced the master cylinder and replaced the fluid but suggested that the slave cylinder be replaced soon. I adjusted the pedal engage point slightly from under the dash on my car, just to get it so that the pedal doesn't have to be pryed back up off the floor each time I shift. the only problem with doing that is it makes your clutch engage almost at the end of its stroke. I'm really interested to hear what you find out and if you can determine just what is causing the problem. I ended up spending $335 just changing out the master cylinder and doing fluid, the slave is the next to get changed if I don't come up with any new options soon. good luck, and I hope your repairs are less expensive.
nwsurfwakeskate is offline   Reply With Quote
Old 07-13-2005, 04:00 AM   #5
Ne14korn
Member#: 38929
1993 impreza
i think its the primary seal in the master cylinder...not sure. just check to see if the seals are seated, not cracked or stretched too much, or that they are not rolling over. i should know since i have ase certs. in november. erica
Old 07-13-2005, 02:18 PM   #6
pinter
Member#: 86472
1998 2.5RS, 2x 1995
Impreza Coupe
Thanks, I'll check the master cylinder seals. Even though it is brand new.
Old 07-14-2005, 06:52 AM   #7
Ne14korn
Member#: 38929
1993 impreza
i look it up in my text book to be sure
MY02 Wagon: New clutch...problems...need help bwawuz Transmission (AT/MT) & Driveline 6 11-17-2006 10:32 PM
Detailed description of my clutch problem need help Norcalrallyist Subaru Conversions 1 10-04-2006 09:59 AM
clutch problem - need help Willis Normally Aspirated Powertrain 8 05-04-2001 07:11 PM
('93-'01) Clutch problem need help dvs81n Impreza Forum 0 04-24-2001 07:13 AM
('93-'01) clutch problem, need help. Scooby25 Impreza Forum 3 04-14-2001 03:58 PM
