Old 07-12-2005, 03:45 AM   #1
StealthfishWRX
Member#: 57473
04' REX (RETIRED)
Default 205/55-16 can it change to 225/50-16?
Hey I have the stock rims and tires on.....car is badly condition, I have the stock rims and was saving up for rims and tires later, can I change it to 225/50-16 from 205/55-16? The surface is wider but I don't know the stock rims was only meant to handle 6.5in wide for the inner rim? can someone help me and any suggestion? I tried finding the Falken Azenis RT-215 but they stop production. anyother suggestion on tires for stock rims, but really good tires for racing(not street racing)maybe......at the 1/4 track and every day drive? thanks lots, stealthfishwrx.
StealthfishWRX is offline   Reply With Quote
Old 07-12-2005, 09:10 AM   #2
UltimateLurker
Member#: 82488
06 Lotus Exige
If you're asking if a 225/50 will fit on your stock wheel, the answer is yes. If you're asking if you can increase the wheel width with after-market wheels, the answer is yes as well, up to about 8.5" without rolling the quarters, but you must be careful with the offset, the closer to +50 the better, as an 8.5" +35 won't work without rubbing. Most after-market wheels that are 8.5" wide are going to be in the +45 to +48 range, which will work just fine, and on those wheels you can fit a 235 without rubbing (depending on the specific tire).
UltimateLurker is offline   Reply With Quote
205/55/16 RE's to 225/50/16 RE's On USDM Pinks nightcrawler60 Tire & Wheel 8 04-27-2010 09:29 PM
Can I run one 225/50/16 when everything else is 205/55/16? maxipad Tire & Wheel 2 03-12-2009 02:58 AM
FS 16 inch ASA rims + tires 225/50/16 RacerX Wheels/Tires 5 09-08-2007 10:36 AM
Anyone regret going to 225/50-16 on stock wheels? edh Tire & Wheel 14 01-20-2005 09:08 PM
205/55/16 in the front and 225/50/16 in the rears ok? Or vice versa? SinhCredible Tire & Wheel 31 11-16-2004 04:48 PM
