Old 08-09-2001, 01:27 PM   #1
hkwan
Member#: 7536
2005 WRX STi
Default Anyone tried this - Power Bleeder?
Wondering if anyone has experience/comment with this -->
http://www.motiveproducts.com/ordernow_bleeders.htm
hkwan is offline   Reply With Quote
Old 08-09-2001, 01:40 PM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Yeah...I was thinking of getting one of those. It would make bleeding the brakes alone SO much easier.
Old 08-09-2001, 01:55 PM   #3
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Lightbulb speed bleeders
If youre worried about bleeding the brakes, go to pep boys and pick up some speed bleeders, they are one way valves that just let you pump the brake pedal. Really EZ.
trhoppe is offline   Reply With Quote
Old 08-09-2001, 02:00 PM   #4
mav1c
Hoodbridge!
Member#: 560
OK...I'm sure you meant "pump the brake pedal", but being as lazy as I am, that means you have to pump the brake pedal, go down and check the fluid, go pump the brake pedal, etc, etc. That would take forever!
Old 08-09-2001, 02:07 PM   #5
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Talking
nono, I meant the gas pedal thats how you bleed your brakes isnt it?
hehe
I measured that on my eclipse 10 pumps of the pedal was enough to get the fluid low and then I would refill. Did about 10-15 pumps per wheel, you have your brakes bled in 10 mins.
Old 08-09-2001, 03:00 PM   #6
hkwan
Member#: 7536
2005 WRX STi
isn't the kit at pep boy cost ~$45? If so, why not go with the Power bleeder?
Old 08-09-2001, 03:02 PM   #7
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Lightbulb cause
With the speed bleeders you don't have to carry around some bigass thing with you, just a little length of hose and you can use a mountain dew can to dump the fluid into.
Old 08-09-2001, 03:19 PM   #8
hkwan
Member#: 7536
2005 WRX STi
You know what, Trhoppe, if you look closer, you will notice that you don't have to carry that big ass thing (I assume you are talking about the white plastic container) with you. It stays in the front, holding fresh fluid for delivery to the master cylinder. All you do is carry your Mt. Dew can and a wrench for loosening up the brake nipple. Even easier than the speed bleeder.
Old 08-09-2001, 03:22 PM   #9
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Talking uhhhhm
Okay, my bad. What I've seen before for a "power bleeder" was a hookup to the nipple at the caliper that let you pump your brake pedal w/o having to open and close the nipple every time. How would this thing enable you to not have to open and then close the nipple every time you pumped your brake pedal?
Old 08-09-2001, 03:52 PM   #10
hkwan
Member#: 7536
2005 WRX STi
You know what, you don't even need to pump the brake pedal anymore.
The container gets pressurized by you (with the pumping mechanism on the container) and the fluid would get delivered to the master cylinder through the attached tubing. All you do is to go around 4 corners of the car, loosening the nipples. When the nipple is loosen, the old fluid in the system would get pushed/flushed out and replaced by the fresh fluid from the Power Bleeder. A true one-man operation.
Just wondering if anyone has tried it. My car is too new to have the fluid replaced. I would be purchasing it in approx. a year.
Old 08-09-2001, 04:01 PM   #11
milkman
Member#: 8066
Y2K RSt
Sedona Mars Red Pearl
Default Re: cause
No don`t use mountian dew cans they can start a fire use coca-cola caffeine free only
milkman is offline   Reply With Quote
Anyone have a power bleeder? scooby2.0t Mid Atlantic Impreza Club -- MAIC 0 03-05-2008 10:18 PM
Anyone Have a Power Bleeder - MD MD04WRX Mid Atlantic Impreza Club -- MAIC 0 05-26-2007 10:29 PM
Has anyone tried this? Die Civic Car Care & Detailing 16 12-31-2000 10:40 AM
Has anyone tried this....... AndyL General Forum Archive 0 10-10-2000 01:08 PM
Crazt sunroof idea...Anyone tried this?? Eric SS General Forum Archive 15 08-07-2000 11:42 AM
