Old 07-12-2005, 10:47 AM   #1
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Wirelessly posted (BlackBerry7100/4.0.0 Profile/MIDP-2.0 Configuration/CLDC-1.1)
Its time I start looking at my options for brakes, and I'd like to stay under the one-grand mark. Right now, I'm trying to piece together a setup consisting of FHI 4 pots, SS lines, slotted and cryoed rotors for the front and back, and upgraded pads all around.
My real question is whether or not the FHI's will fit under my BBS RK 17x7's. Any help would be great. Thanks!
Teh Legacy is offline   Reply With Quote
Old 07-12-2005, 10:49 AM   #2
Teh Legacy
Member#: 9853
to keep your mouth
shut.
One more question- what are the benefits of using 2 piece rotors? It does save weight, correct? What else?
Old 07-12-2005, 11:57 AM   #3
iON Performance Inc
Vendor
Member#: 7673
97legacygt - The FHI 4pots should fit underneath your RK's. When you move to the FHI 4pots you're also upgrading your 10.9" rotor to 11.4".
2-piece rotors have several benefits associated:
(a) reduced unsprung weight to improve suspension responsiveness
(b) reducing rotational inertia to allow for quicker acceleration (in + & - direction)
(c) isolating heat from the braking surface from the hub/bearing assembly, thus increasing the service interval for the hub/bearings for a longer period of time
(d) increasing fuel efficiency
(e) lower operating costs in the long run (ie: replacement discs are fairly inexpensive)
(f) better brake cooling
iON Performance Inc is offline   Reply With Quote
Old 07-12-2005, 01:35 PM   #4
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Ion- PM me with a price on said rotors if you carry them. Thanks.
Old 07-12-2005, 04:27 PM   #5
iON Performance Inc
Vendor
Member#: 7673
97legacygt - Email sent (Note: quoted for 2-piece rotors for 4pot, 1-piece rears, 4pot CF/kevlar pads, rear pads, 6line F&R SS kit, cryo. Slotted discs.)
Will Brembo BBK's fit under the BBS RK's? Teh Legacy Brakes, Steering & Suspension 1 05-11-2005 06:40 PM
RacingBrake 4-Piston Calipers: 50% lighter than FHI 4-pots, Fit under OEM WRX Wheels! AZP Installs Suspension/Brakes/Handling 70 04-26-2005 01:33 PM
Would Subaru 4 pots fit under the previous Legacy GT rims? teck7droid Brakes, Steering & Suspension 19 02-06-2005 10:53 PM
want to know if subaru 4 pots fit under stock rims d0gsoup Brakes, Steering & Suspension 11 11-13-2003 10:19 PM
Will 4 Pot brakes fit with stock RS Wheels Greg 99 Brakes, Steering & Suspension 2 11-19-2000 06:33 PM
