Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 07-12-2005, 02:16 PM   #1
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Default going usdm sti heads...questions w/ manifold
ok im most likely going to get a hydra
i know ill need
hydra for 04+sti w/ AVCS W/O DBW
shielded wire for running wire to the new cam sensors
the heads
the coils
tgvs
ok but now the q's
will i need a new crank sensor?
is the new cam sensor hard to come by?
is the clip in harness i have for my 99 RS ecu the same design as the sti one <most likely no way>
if not, anyone know of a cheap place to get the plugs so i can plug them into the hydra? <after i change all the pins>
will the wrx intake manifold work with the sti heads?
if so will my RS TB work with the wrx intake manifold?
will my stock wrx headers work with the sti heads
is there another actuator i need to know about for hte avcs or is it built in part of the heads
thanks a lot
hopefully someone can answer all those for me
id research a lot more but im at work and need to get back to work
cya
alex
Difference between 04-06 USDM STi heads and 07 heads? wittmer25 Built Motor Discussion 6 09-11-2007 07:02 PM
jdm ver. 8 sti heads vs usdm sti heads Peeblesmx445 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 56 12-17-2005 10:00 PM
fully ported usdm sti head vs spec c head amiller Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 23 09-30-2005 06:34 PM
V8 heads vs USDM STi heads 2000wrx General Community 5 05-10-2005 03:53 PM
ver 8 heads vs. USDM STi heads ebeck Subaru Conversions 10 04-17-2004 01:45 PM
