Old 07-12-2005, 01:33 PM   #1
Siper2
Member#: 1134
2007 BMW 328xi wagon
Impreza GC8 Quick question: Oil drain plug size, with gauge pack?
Hi guys.
The oil drain plug requires a much larger-diameter wrench to remove, when the car is equipped with the OE performance gauge pack. It has an oil temp gauge, and the wire connecting to the plug replaces the whole plug...
I think it's 27mm?
29mm?
Someone please let me know. My car is an '00 RS. Wanna go to Sears tonight and pick one up. I've been using an adjustable wrench, and don't want to, anymore. Thanks.
=S2=
Siper2 is offline   Reply With Quote
Old 07-21-2005, 08:50 AM   #2
Siper2
Member#: 1134
bump
Did go to Sears, didn't find any larger than 19mm. But I know 19mm is too small - I own one and tried it.
Old 07-25-2005, 10:45 AM   #3
Siper2
Member#: 1134
Oh, c'mon, someone must know.
Old 07-25-2005, 11:06 AM   #4
Pghrally
Member#: 19393
why don't you put your adjustable on it, then use the small gauge on the adjustable to see what size it is? if it doesn't have the engraved gauge, measure it, then head to the craftsman online store and order the proper wrench.
For example:
http://www.sears.com/sr/javasr/produ...id=00942933000
Pghrally is offline   Reply With Quote
Old 07-25-2005, 11:33 AM   #5
Siper2
Member#: 1134
Didn't know how accurate that would be. (And no mine doesn't have the gauge.)
Old 07-25-2005, 12:06 PM   #6
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
IIRC, it's 22mm. I use a deep socket with a slot cut in the side of it for the wire.
jac04 is offline   Reply With Quote
Old 07-25-2005, 12:11 PM   #7
z&cobb
Member#: 12344
2002 2JC
blue
27 mm
I bought a Craftsman wrench about 90,000 miles ago. Since it was so long I cut it in half and slotted the closed wrench end so the wire would pass through. I just use the open end most of the time, however.
Since I change the oil and filter every 3000 miles the shorter wrenches can be used without raising the car. It does take a bit of poundage though to get 32 foot lbs out of the short wrenches, but it also keeps you from damaging something if you tend toward Neanderthal mechanical finesse.
z&cobb is offline   Reply With Quote
Old 07-25-2005, 12:16 PM   #8
Siper2
Member#: 1134
Heh.
I don't torque it to spec, I just put the crush ring in and torque it to "quite hand tight." Basically, tight enough... not over-tight.
27mm, okay cool. I'll go hunting.
Old 07-26-2005, 08:15 PM   #9
RLRaven
Member#: 41808
03 WRX, 07 2.5i,
03.5 Mazdaspeed Protege
27mm fo sho
RLRaven is offline   Reply With Quote
Old 07-27-2005, 07:55 AM   #10
jac04
Member#: 49895
09 Forester
Originally Posted by jac04
IIRC, it's 22mm.
Obviously I didn't remember correctly - it's 27mm....but you guys already knew that.
Old 07-27-2005, 08:12 AM   #11
Siper2
Member#: 1134
Thanks again!
Rear differential oil fill and drain bolts, same size as the oil drain plug? scooterforever Transmission (AT/MT) & Driveline 4 01-24-2005 06:06 PM
Oil Drain Plug Size AlanTheWoo Service & Maintenance 6 06-10-2002 08:54 AM
Oil Drain Plug Thread Size daytontp General Community 10 01-04-2002 11:35 AM
oil drain plug size tofu86 Service & Maintenance 3 11-26-2001 04:39 PM
Oil drain plug size... Suba-RAW Newbies & FAQs 4 09-30-2001 03:25 AM
