Old 07-12-2005, 08:36 PM   #1
SBoneWRX
Member#: 11251
2003 BMW ///M5
It's Like a Pastel Black
Default CEL out of nowhere
I was driving today and out of nowhere the check engine light came on. I'm not entirely sure why or how it happend. It's a 2002 WRX, 31,000 miles with no problems while I drive. Last year, I was out of the country and didn't drive the car for a month, and when I started it up, black smoke came out of the exhaust. This caused a CEL, which the dealer explained was the black smoke and a faulty 02 sensor.
I still haven't dont the 36,000 mi. maintenance on my car, could it have anything to do with the CEL? There was no black smoke this time, I've been driving regularly, and the CEL came on mid-drive. It might not have anything to do with the CEL, but the CEL did come on shortly after I turned on the A/C.
Any help would be appreciated.
SBoneWRX is offline   Reply With Quote
Old 07-12-2005, 08:40 PM   #2
ms3p
Member#: 51596
2014 FiST
2006 SV650S blue hotness
YOu will get nowhere like that.
Go to Auto Zone and get the code checked, THEN come back and post what it is if you want some advise.
ms3p is offline   Reply With Quote
Old 07-12-2005, 08:56 PM   #3
23b_Rex
Member#: 79394
02 gda
wrb
do the 30k maintanence... get the code pulled and check it here
23b_Rex is offline   Reply With Quote
Old 07-13-2005, 11:35 AM   #4
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
A CEL can be caused by a loose gas cap. Did you tighten your gas cap? (Now you see why we need the code)
bofh is offline   Reply With Quote
Old 07-13-2005, 05:58 PM   #5
DrtJnky
Member#: 78652
2005 WRX Wagon
WR Blue
What area of MD are you in. I have a code reader with definition and data display.
DrtJnky is offline   Reply With Quote
Old 07-13-2005, 07:06 PM   #6
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
first of all....finish up your 30k maintenance, and get the code checked.
If you're lucky, it could just be a harmless random CEL that you can just clear with a scanner and be done with it.
eltrouble is offline   Reply With Quote
Old 07-14-2005, 12:32 AM   #7
kcook
Member#: 78074
2005 STi
if u get a CEL .. how do u check for the code???
kcook is offline   Reply With Quote
Old 07-14-2005, 12:33 AM   #8
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
Take it to Autozone, ask them to check it for you, it should be free. But DON'T clear it until you verify that the problem is either fixed, or not a problem at all.
Old 07-14-2005, 01:37 AM   #9
nasiocracy
Member#: 91237
My WRX does that. I usually hit the gas and it goes away.
nasiocracy is offline   Reply With Quote
Old 07-14-2005, 10:20 AM   #10
23b_Rex
Member#: 79394
02 gda
wrb
^ what's the code?
Boost cut @ ~10psi out of nowhere, help! 02rusWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-12-2007 02:09 PM
Studdering problems... out of nowhere. WRXGuyInUSA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 11-05-2006 03:14 PM
Boost problem out of nowhere Porkchop-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-16-2006 09:53 AM
Help please, a pr0n ad keeps popping up on my work computer out of nowhere.. STR8OUT Off-Topic 20 12-15-2003 04:30 PM
low boost out of nowhere???? dubluv17 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-29-2003 05:44 PM
