Old 07-12-2005, 08:58 PM   #1
tdt3607
Member#: 91156
Default help with understanding engine type#'s
can anybody tell me the difference between EJ251,EJ255,EJ257....
I just purchased an 04 legacy 35th anniv edition with a EJ251 engine (auto.non turbo)
In attempting to buy some modest performance parts it appears that the EJ251 is never listed as an engine used on an 04 legacy.Im confused-seems the 251 was used in the late 90's?I understand that the 25(first 2 digits)is the engine size (2.5) WHAT do the other digits refer to?
THANKS
tdt3607 is offline   Reply With Quote
Old 07-13-2005, 11:55 AM   #2
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
My '99 Legacy 2.5 GT (non turbo) uses an EJ25 Phase I Engine that displaces 2.5 Liters. I know that Subaru intoduced a revised engine block known as the Phase II, and that the Turbo charged WRX STi uses a modified version of this same engine block. My uneducated guess is that the extra digit is a "revision number" specifing the different "flavours" that the EJ25 Phase II engine is now available as. I am sure someone else can tell you more about those different numbers though.
Jonathan is offline   Reply With Quote
Old 07-13-2005, 01:09 PM   #3
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
You Legacy is at the end of a model year. IIRC, the breakdown is as follows:
EJ257 – turbo block, semi-closed deck, used on 04-05 STI and 05 XT Legacy’s (including OB).
EJ255 – NA version block, used on same years but for non-turbo. Also I believe recent Impreza RS’s used the EJ255
EJ251 – NA version block, years prior such as your 04’ Legacy…
xcntrk75 is offline   Reply With Quote
Help with understanding advanced concepts? offset Proven Power Bragging 10 06-17-2004 08:25 PM
Help with an Engine Stand cfwdfw North West Impreza Club Forum -- NWIC 5 04-08-2002 12:51 AM
help with check engine light sethiscope Service & Maintenance 3 02-08-2002 10:09 AM
Help with check engine code Meche 2.5RS Normally Aspirated Powertrain 1 10-10-2001 06:20 PM
Help with STi engine mounts... kaos200 Normally Aspirated Powertrain 12 09-09-2001 12:16 AM
